Go Back   International Full Size Jeep Association > Tire Kickin' > Introduce Yourself.
Old 12-06-2017, 02:22 PM
Maliciousupload's Avatar
Maliciousupload Maliciousupload is offline
Noob!
Talking What's up people! 1980 J20 Jeep
So I have a 1980 J20 Jeep with a AMC 360 currently on propane that I am going to be converting back to gas and am looking forward to letting you guys know how my restoration goes with my true love. I am currently living in an apartment so repairs are difficult, i deal with a lot of obstacles and planning needed to accomplish a goal considering my work space and no prior mechanical training but someone has to do it right!
Old 12-06-2017, 03:03 PM
Don't have a clue about going back to gasoline from a previous LPG conversion. A local RV shop can prolly guide you toward an info source. So far a being new to wrenching I highly recommend you spring for an original 1980 TSM (factory Tech Service Manual) or a repop. Don't bother with a generic Haynes manual. They try to cover too many years to be of value for 80 specific specs. On he apartment dwelling thing I would source a friend or relative with a house/driveway and work a deal.
Old 12-07-2017, 05:42 PM
backroadin''s Avatar
Welcome! No better way to gain mechanical skills than to work on a Jeep.... you know, 'cause they never stop needing something!
That's how I learned!
Old 12-08-2017, 09:37 PM
BA_051 BA_051 is offline
Welcome to the forums! I concur to getting a factory TSM for your year, it will help a lot.
I have done a few conversions to and from propane, granted none of them were on jeeps, but all carb engines are very similar. Most were strait forward from LPG back to gas... Just remove the propane tank (after its emptied of course) and the lines/fittings/ect. The motor side was just as simple as replacing the LPG carb with a gas carb, installing either the mechanical fuel pump on the block or an electric pump, installing a factory tank with sender/pickup in the stock location and running 2 fuel lines and 1 wire for the sender. That was on '77 ford f100... A bit more complicated going from gas to LPG...
An ECM controlled motor, well thats a different story... quite complicated...
1974 Jeep J20, gladiator grill, 12v p7100 cummins, Modified He351, 4" strait piped, NV4500/Ford NP205, 14b front kingpins, 14b rear, 4.56's, 12" lift, 37x12.50x16.5's
1980 Jeep J10 Honcho Sportside - restore giobizio Build Threads 95 08-28-2019 04:30 PM
1978 jeep j20 Wittendorf1986 Build Threads 0 01-28-2015 10:11 PM
82 Jeep J20 questions Jeepin Badger General FSJ Discussion 7 06-30-2014 12:06 AM
1980 J20 Side Mirrors, where to get some? mknherhappy General FSJ Discussion 5 05-17-2009 05:25 PM
Registered Numbers So Far 2nd Day East Coast FSJ Invasion 50 06-02-2005 01:00 PM
