Old 03-26-2011, 01:23 PM
jeeper54's Avatar
jeeper54 jeeper54 is offline
Altitude Change
I have a question for the carb gurus. The kid that is buying my waggy is planning on moving to Flagstaff after his discharge. The carb is a 2150 with compensator. Will that be sufficent for the altitude change? Runs good here at 1200 ft. but not sure how it will be at 7000ft. My son had a Edelbrock on his truck and our property is at 5800 ft. and the truck would run really bad. Would flood out and die several times before it would make the 8.5 mi trip off the highway. But the blazer with an electronic q-jet didn't even notice a differance. Just want the kid to know what to expect/do for the change. He's still out on sea duty and hasn't even got the waggy yet but his wife told me that he has already ordered a bunch of parts. His excitement about buying it makes me feel better abouit having to give it up.
Currently without
Formerly
1986 G.W. 360
1986 Eagle Wag
1985 G.W. 360
1984 Eagle Wag
1981 Wag 360
1978 Wag 401
1981 Cherk W/T 258
1966 Wag Super 327
Not counying XJs'.
[Did have a 94 & more recently a '97 GC with 5.2. for awhile. Just not the same! Now have the FSJ blues!
Old 03-26-2011, 01:36 PM
Tornado230's Avatar
Never had a problem running from sea level to up and over the Rockies passes.
Mine was a low elevation model (4,000 ft.)
Old 03-26-2011, 01:56 PM
FallonJeeper's Avatar
FallonJeeper FallonJeeper is offline
Ideally you would want to lean out the jets and advance the timing. It will run, just not peak performance.
Upgrade to an Edelbrock 1406. It's leaned out 2% already. Mine runs great at 4000 ft.
Old 03-26-2011, 01:57 PM
Serious Johnson's Avatar
If the jets & ignition timing are appropriate, it should handle that range more or less OK. Way back when I was running a carb (2150) and used to go from 1,000' to 12,000' each year, I stopped at my favorite bar at 7,000', advanced the ignition, and swapped to another 2150 I kept pre-jetted for altitude -- just quicker & less smelly than opening up the carb. The first time, when I neglected to do that, it killed the catalytic converter and the rig was making maybe 50 HP while getting about 2 MPG.
S.J.
"Carpe Mañana".
'83 Wagoneer
Change full time front hubs to manual hubs photos included haynesm General FSJ Tech 8 02-21-2011 02:44 PM
Quadra-TracTransfer case fluid change – do I need a gasket for the gear reduction uni p@55w0rd General FSJ Tech 1 09-29-2010 08:59 AM
FLINT! (yet another edel altitude question) brent General FSJ Tech 0 07-21-2006 10:53 PM
Altitude issues with MC2100 carb illegalFSJ General FSJ Tech 9 12-23-2002 04:10 PM
Front Axle Change Over For 70 Wagoneer Crazy_Jeepman General FSJ Tech 13 05-04-2001 05:18 AM
