Old 11-24-2005, 11:53 PM
John Baxter John Baxter is offline
Unhappy
Some advice needed
I have an 82’ wagoneer and the bonnet/hood is stuck down. There are two hood release two hinges, one on either side. The hood release lever does appear to release (there is a noise and the hood does move, but it’s mainly on the right hand side). The left side hood hinge (to which the hood release cable to attached to) does not release. I can force the hood up slightly from the left side, being able to move the release lever, but no matter how hard I try, the release lever will not move up far enough to release the hood. It just will not release the left side hood hinge. I’ve used WD40 and screwdrivers without trying to damage the grill, but I’m given up for the moment with the hope that someone has some suggestions that don’t include destroying the hood.
Thanks
John Baxter
Melbourne Australia
john baxter
Old 11-25-2005, 12:06 AM
Millerluck's Avatar
Get a long screwdriver and push in the arm that the cable pulls on.
It's about a foot to the right from center facing the grill.
See if that helps.
And welcome to IFSJA
Larry Miller
[ November 25, 2005, 06:10 AM: Message edited by: Millerluck ]
88GW "Mississippi" 401,Edelbrock heads,and stuff,
4" Skyjacker, BFG AT's,OBA,Air Horn.
'89GW "Mutt" wood for now, 360, 1405, Edelbrock cam,
4"Rusty's,3"body,33"BFG. Detroit Truetrack Warn Hubs
The Metal Workshop
http://www.themetalworkshop.com/index.html
Old 11-25-2005, 12:29 AM
andy d andy d is offline
Shade Tree Shaman
You need a long slender rod. you are looking for the 1/ 1/4" x 2" tab on the latch release bar that the cable attaches to. Lemme duck down stairs and get a measurement. The tab is 8 inches from the centre of the hood toward the left front wheel. To your right when you are facing the hood. If I did my metric conversion right. 8" is about 20 cm
Anyway, use the rod to push the tab toward the windshield. If this doesnt work, send me RT tickets and I'll fix it for you.
\'88 gwag,pure stock
Old 11-25-2005, 04:02 AM
RATTLERGUY RATTLERGUY is offline
If the Wag is right hand drive would the hood release be on the right side too?
Old 11-25-2005, 09:05 AM
WGNMAN123 WGNMAN123 is offline
not too big a deal. mine's broke too. i just keep a long slender screwdriver handy. yes , when facing the hood, it's a little to the right. i just slide screwdriver in, slide to right till i hit it, pull out a little to place driver flat on surface of latch, pop it with other hand - and woila! lift it open.
keep threatening to fix it, but i got bigger issues!!
my shop man calls it my 'under hood security system'...
WGNMAN123<br />If i aint fishin, I\'m wheelin;<br />if I aint doin either,<br />me and the FISHIN\'WAGON is havin a bad day!
