Old 04-07-2009, 12:45 PM
nice street carb. Holley 4180.
put this together recently. put it on last night. it's a 4180 holley-the 600cfm carb ford used on the mustangs and trucks in the mid 80's. great little carbs,with annular primary boosters,and a few other nice revisions over a typical 4160 model. some,like this one have 4 corner idle,others are of course 2 corner. either is good. this one has the later model,excellent choke system,it works very well.
i made a few changes to this one. i put a late style main shaft in it,with the standard universal throttle arm for easy hook up. i drilled the needed dowel hole in the main body to fit a secondary metering block in place of the typical metering plate. it now has 2 power valves like the early 4150's did. not really necesary,i may put a p/v plug in the secondary side and re-jet accordingly.
i put plain side hung 1850 bowls on,ditching the ugly ford bowls. holley wouldn't sell me a truck avenger style vent tube for it. butt-heads.
here's a shot of the annular boosters. i'll take one of these carbs over a 1850 or current model 3310 any day.
i put it on last night,did a quick idle mix adjustment. filled up and did my 104 mile round to the shop and back today. gassed up again,took 7.8 gallons.13.3mpg. not bad for a carb i've not dialed in yet.keep in mind this the 391 stroker,bigger cam,big valves in the heads,9.25cr pistons. it doesn't feel lean on the highway with the jets i used either. might bump up the secondary side a little.
once the headers and dual exhaust is on i may go back to the 780 holley that i removed.
Old 04-07-2009, 12:52 PM
mattmopar440's Avatar
Truck avenger mike you don't offroad at least not in your own rigs but when somebody has paid for them
13 MPG out of a 390 well the 401 does manage 12MPG
RISTOW THE CARB KING
87' Grand Wagoneer
80' J10 4BT/AX-15/208
74' J10 Go Grabber Green Sold
Inferior Chevy
Old 04-07-2009, 01:30 PM
NVJEEPER's Avatar
NVJEEPER NVJEEPER is offline
RISTOW THE TUNING KING
Damon
'85 Grand Wagoneer
Old 04-07-2009, 02:38 PM
Remember the avenger vent was copied off of what hot rodders were doing out in the field.
Old 04-07-2009, 02:58 PM
bowtieman55 bowtieman55 is offline
yep, we just use rubber fuel hose with holes/slits cut into it.
Old 04-07-2009, 04:33 PM
Jeepguy77's Avatar
Jeepguy77 Jeepguy77 is offline
That looks like the 4160 600 I just put on my truck.
hey Ristow do you know if the metering blocks are interchangable, i want to switch to a regular metering block with the standard idle screws so I have more adjustment possibilities.
Pierce,
77 J10 454, TH400, D20,
Old 04-07-2009, 04:40 PM
JERSEY JOE's Avatar
TRUCK AVANGER
RISTOW:
I was able to get a Truck Avenger vent tube out of the Holley folks. I told them I dropped my Truck avenger and damaged the vent. He did say that the tube was no a seperate part but he did send one to me.
I installed it on the Street Avenger that I got from Greg Taylor
1987 J-20 401 90% COMPLETED.
1970 AMX CURRENT PROJECT
Old 04-07-2009, 06:15 PM
trellis8's Avatar
trellis8 trellis8 is offline
Ristows' Minion
I appreciate you getting my rig all tuned up and all.
Old 04-07-2009, 06:25 PM
We used rubber hose with a T in the middle
Old 04-07-2009, 06:38 PM
scannman70's Avatar
scannman70 scannman70 is offline
I put a 302 in my 85 ford ranger a few years ago and took one of those carbs off. its somewhere in the garage in a box.
Didn;'t know they were good for jeeps too..
Old 04-08-2009, 04:18 AM
you're talking for the secondary side i s'pose? any 4150 secondary block will fit,but the calibration will be wrong if it's off a considerably bigger carb.
i s'pose,but...sigh,call me a boy scout and laugh if you like....i don't wanna have to lie to get one....
i thought you would. i'm gonna need it a while longer though,sorry for the inconvenience....
hmm..it appears i forgot about those rims again too don't it...
Old 04-08-2009, 07:41 AM
Headhoncho's Avatar
If I can't get mine working properly I'm shipping it to cheese country so YOU can do it.
JR
1966 mustang fastback
'07 Dodge Charger 3.5
Old 04-08-2009, 07:48 AM
trellis8's Avatar
Ristows' Minion
Would it be too much trouble for you to get it waxed for me also? A mint in the ashtray is a nice touch as well. Thanks!
Old 04-08-2009, 02:35 PM
Jeepguy77's Avatar
no I meant if I could change the primary metering block from the emissions block with the backwards screws to a regular block.
Pierce,
Old 04-08-2009, 03:25 PM
JERSEY JOE's Avatar
BOWL VENT
Ristow: not a lie. I do have a truck avenger and I did drop it. That's where I got the idea. I was able to fix the bent one after the replacement arrived.
Old 04-08-2009, 03:46 PM
Gambler68's Avatar
Rabble Rouser
Nice!! I'll get that big 750 out to ya soon, still havent got the Glad fired up, but I'm realllly close. All I have to do is hook up the tank, a little wiring, install the radiator and battery, and cross my fingers By then you should be tired of that little 600
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 04-08-2009, 03:52 PM
rebeljeep's Avatar
rebeljeep rebeljeep is offline
Nice setup ristow, what did you use to hook up your throttle and kickdown?
I have a 4160 I'm gonna put on my amc 360 this summer, trying to get parts together
Jared Jeepin 4 JC
1984 Jeep J10 360, transgo/cummins internals/lockup 727, 208 gone through
35" Maxxis Buckshot
6" BJ's lift, Rear Dozer II, weekend warrior
Working swapped in Air Conditioning
1999 Jeep Cherokee Sport 4.0/Aw4/np231
all stock 245k + and counting miles, daily driver
http://s735.photobucket.com/albums/ww354/rebeljeep/
Old 04-08-2009, 07:04 PM
send it over.
i've never had the pleasure of messing with one. i'll see what the books say if anything.
i was referring to myself. it would have been a lie from me,i don't have a truck avenger. no offense was intended.
just a ball stud for throttle and a bolt for the cruise clevis. i put the universal throttle arm on,so it hooks up easy. i use the chrysler style relocation bracket sometimes if the cable reach is a bit short.
Old 04-08-2009, 07:05 PM
Cub-Scout
87' Grand Wagoneer
Inferior Chevy
Old 04-08-2009, 09:10 PM
Jeepguy77's Avatar
ok cool i would just like to have more adjustment. the backwards metering blocks only have alittle adjustability.
Pierce,
