  #41
Old 11-30-2006, 04:23 PM
orangecherokee's Avatar
a chevy disc will work too and is larger than a Ford. I think the Chevy is 11" compared to the 10.5". i could be wrong but I think I'm right.
as for the hydro i could go into detail about it but it takes forever and i'm slightly annoyed with it even though it works. not beause of the set up but because of all the crap I had to go through.
Old 11-30-2006, 05:08 PM
Brad W.'s Avatar
Brad W. Brad W. is offline
chevy half ton is an 11" disc, yes.
Brad W.
1979 wag "Nightmare"
**project shelved indefinetly**
m715 ex-firetruck
**project shelved**
2001 Dodge Ram 2500 "Project Juggernaut"
24v-CTD/NV-4500/quad-cab/4x4
4" straightpipe, rollin on beadlocked 37's.
Old 11-30-2006, 05:41 PM
JeepsAndGuns's Avatar
Is the Jeep T18 input not 1 1/8 10 spline? I swear I remember it being that??
Old 12-01-2006, 02:05 PM
4x4fEvEr's Avatar
4x4fEvEr 4x4fEvEr is offline
called advance and it looks like everything including the throwout bearing , bushing, disk, new pressure plate is gonna run me around 330 bucks but thats centerforce stuff. im hoping i can crossreference centerforce numbers and come up with somebody elses disk. who should i go with?
#384180 on the disk
#cf361675 for the AMC pressure plate
4x4fEvEr's Avatar
i believe it is and the np435 is 1-1/16
Old 12-01-2006, 06:25 PM
Ok, got ya. I was thinking the ford was also 1 1/8.
Old 12-02-2006, 06:06 PM
Elliott's Avatar
Elliott Elliott is offline
Cowboy Up
Following directions at: http://medusa.ih8mud.com/NP205/Doubler.html I pulled the shift rail (and oil seals which I replaced) and modified my 205 for twin sticking today. It went real smooth just enlarging the notched sections ~7/16". Put back together, it shifted fine and did not allow the front axle to go in a different range then the rear axle... which is all good. I just did the notching with an angle grinder with a cut off wheel and then scotch brighted it smooth.
Old 12-04-2006, 07:03 AM
#384180 on the disk
if you find a good deal let me know please. i want the 15 finger pressure plate not the 3 finger.
Old 12-05-2006, 12:50 PM
4x4fEvEr's Avatar
i cant seem to crossreference that centerforce number or find a 15 finger right off hand either. this will require deeper investigation
Old 12-05-2006, 03:27 PM
coo. let me know.
Old 12-05-2006, 06:55 PM
4x4fEvEr's Avatar
lets see here: got my bellhousing (t-176) my two tranny (np435) two tcases(203 and 205) now im missing the clutch componets and the doubler. still gotta pull apart the 203 clean it up and open up the 205 to make sure all is well.
looking to purchase the clutch junk once i sell my t18
Old 12-06-2006, 01:21 PM
McRoth's Avatar
McRoth McRoth is offline
I take it there's no easy way to attach this to a Jeep 727 without special adapters?
Mike
78 WT Cherokee Chief Levis Edition, Rebuilt 401, DUI, Hickey Winch, Headman Headers, Dual 2 1/2" Exhaust.
88 Grand Wagoneer - SOA, D44HD & D60, 203-205 Doubler, Rear Disk Brakes, 36" H1 Double Beadlocks
02 VW Jetta TDI - DD
82 Mercedes 300TD
1953 Dodge B4-F 1 1/2 ton stake bed - Restoration Project
Old 12-07-2006, 08:24 AM
Elliott's Avatar
Cowboy Up
Haven't looked at the 727 but you can probably drill your 727 bolt pattern into a GM/Dodge 203 range box and find the correct splined input...
Old 12-19-2006, 11:25 AM
4x4fEvEr's Avatar
if the t-18 sale goes well ill have my clutch and related items ready to throw it together. pics to follow
Old 12-19-2006, 06:34 PM
oldyellowwagoneer oldyellowwagoneer is offline
Dodge 203's have the correct spline count and may just bolt on using the dodge tailshaft adapter. I have a dodge 203 and just used the dodge tailshaft and adapter in a jeep trans so the adapter is steel and not aluminum. Dennis
“Don't do anything by half. If you love someone, love them with all your soul. When you go to work, work your *** off. When you hate someone, hate them until it hurts.” Henry Rollins
Old 12-19-2006, 08:35 PM
Big-wagon87's Avatar
Big-wagon87 Big-wagon87 is offline
YEh I have a dodge 203 laying around too. took it off my dodge np435 I looked at the 203/205 doubler. my 205 is a dodge with a 435 adapter already on it. It just seemed easier to bolt the 205 up and look into a lomax kit later on. I checked into the clockrings and shafts needed to make a doubler. kinda high. $789 for $200 more I can have a lomax kit. but the 3 stick setup could be sweet. I never cleaned my 203 up to see what it would take to mate the 205 behind it.
Good ideas and sites on this thread Chris
87 wag on 44's 360 mod on propane, np435, 203/205 doubler w/lowmax
76 cherokee cheif 401
bunches of baby jeeps
Old 12-28-2006, 07:15 PM
4x4fEvEr's Avatar
cracked open the 203 today to separate the range box from the rest. the shifter linkage was a ***** to get unhooked. the only thing i need off the 203 is the range box and what gears sit inside it that are connected to the splined shaft that goes into the rear output right? that shaft sits inside the 205? i made a mess out of needle bearings pulling it apart. hope i didnt mess up
Old 12-31-2006, 06:26 AM
Elliott's Avatar
Cowboy Up
They aren't hard to separate, or shouldn't be, just back off/remove the bolts after removing the tail houseing, punch the pin on the shift rail, split the cases and stick a screw driver in there to pop off the shift acutator... if you bent it you don't need it anyway.
Keep all the large roller bearings for spares (there are some fine ones you can toss).
Here's NW Fab's guide to what you need and if you don't already have a large retaining ring remover... buy one now: http://www.northwestfab.com/203-205adaptorinstall.html
Old 12-31-2006, 02:15 PM
4x4fEvEr's Avatar
thanks elliot. all those large roller bearings have already been sent to that big scrap heap in the sky. going to read that article now
Old 01-07-2007, 07:19 PM
Elliott's Avatar
Cowboy Up
Ok... so who's got pics of where the shifters locate in relation to the tranny tunnel cover on a FSJ installation.... ???
