Old 11-17-2003, 09:41 AM
BlueduckFSJ BlueduckFSJ is offline
would like to know what is said re: what Zorm said.
1979 Cherokee Chief W/T \"Blueduck\"<br />360 AMC<br />Automatic <br />TH400<br />Quadra-Trac <br />Edelbrock Performer 4 Barrel<br />TFI Upgrade<br />Rhino Grille <br />D44 Front/Rear<br />33x12.50x15 on Rock Crawlers<br />4\" BJ\'s<br />Terra-Flex Swaybar Disconnects<br />Durabak in and out.<br />Tuffy Console w/ Pioneer CD<br />BJs Dozer Bumpers Front and Rear
Old 11-19-2003, 02:48 AM
firechero firechero is offline
someone drive to des moines and help me use my ac compressor to make some onboard air! [img]smile.gif[/img]
all sold out of jeeps
Old 11-19-2003, 03:05 AM
dnixon dnixon is offline
Dude you can do it. Just some cutting some snipping and some connecting. Nothing a FSJer couldn't handle. But just make sure your A/C is purged before you start cutting into the lines, its VERY serious if it isn't. You can take it to a place and they can make sure it's empty. You'll jack your self up if it has some R-12/134 in it. Just post if you come into an problems. I haven't done it myself yet but I dont't for see any problems..
All It Takes Is Money.
I'm the reason why you can only have Jeeps for Avatars. You're welcome.
Old 11-19-2003, 03:31 AM
jode's Avatar
jode jode is offline
JB Welder
Slowag- the check valve you posted is rated 2.5 GPM
Your compressor prolly does 8-12 CFM
You might want to watch that...
No FSJs for the time being - "I'm working on it, I'm working on it" (think Mike Meyers' SNL skit about the gut)
Old 11-19-2003, 05:57 AM
Yeah i didn't really check out that stuff to well. I was just seeing you guys could anything wrong there.. So thanks for your good eye. So far that place has the cheapest stuff i have found. But I am a little ways off from buying everything just yet...
Thanks again...
Old 11-19-2003, 06:18 AM
Sycho15 Sycho15 is offline
Isn't there a big space across from the gas tank to mount an air-tank? You know, on the other side of the driveshaft... One of the portable air tanks from Wal-Mart would probably fit there, mounted up-side-down (hung from it's "feet").
Also, you could use a big section of thick-walled PVC pipe. The PSI rating on PVC is very high since it is designed for carrying water, which doesn't compress. The only draw-back to PVC is that instead of denting, it'll shatter. Instead of cracking and leaking some air out, it'll pretty much explode if over-pressurized. Granted that is what the relieve valve is for...
1989 J5 "Murphy"
4.0L / AX15 / NP231 / GW D44s
3" lift / 31" MTs
Old 11-19-2003, 08:29 AM
Yeah you could put it on the other side but usually people have the exhaust running over there.. but if you don't i guess that would work.. but if you have tires over 29" in diameter then you won't need that stupid donut spare and when you remove the tire it provides a large area for mounting an air tank.. at least thats what i think i am going to do...
Old 11-19-2003, 08:32 AM
i just bought a york compressor with the intent to create on board air, but i need to research it a little more so i know whats going on
Old 11-19-2003, 11:26 PM
gladiator
Posts: n/a
Envision a rock, or piece of metal from the hwy coming back at speed and nailing that plastic air bomb under the vehicle. I think I would let someone else prove through use, this application before I would consider it. If the thing does grenade, those shards of plastic are closest to the RR tire. There are plenty of steel air tanks of all sizes available in the heavy truck wrecker yards with all the right bungs in them already.
Back to the original thread for a moment.
Regarding compressors, I have been noticing that some chrysler products have a V-twin type compressor with what looks like a separate oil sump. Has anyone used or checked these out as an alternate to the York compressor?
[ November 20, 2003, 05:30 AM: Message edited by: gladiator ]
Old 11-20-2003, 02:08 AM
Slim's Avatar
Slim Slim is offline
i mounted daul 5 gallon metal air tanks in mine ,,,under where the spare tires used to be ,,,,since the Jeep has a body lift ,,the tanks were able to tuck up nice and high
the tanks were easy to buy also ,,,just went to one the the Big Truck shops,,and they use them on all the semi's ,,,
77 Cherokee chief ,360 cid,quadra-trac,chopped /bobbed 12" , 8point cage, front exo ,d60frt 14bolt rear ,38.5x14.5x16.5 on beadlocks ,frt & RR winch,OBA ,SOA,shackle flip rear
** Island Rock Crawlers**
4WDABC Member
BCWF Member
Old 11-20-2003, 02:15 AM
Thats what i was thinking of doing and was told i shoudl try out by a friend. How much did they cost? Roughly? Did they have a few sizes. I don't have a body lift so I would like to have a longer but skinnier one to try to tuck it under the frame rails.
Old 11-20-2003, 03:03 AM
Slim's Avatar
yes they come in a few sizes and shapes,,,, they cost me $30.00(canadain) each brand new,,,and alread have all the holes needed for all fittings
4WDABC Member
BCWF Member
