Old 04-08-2003, 04:11 AM
Brown Bear's Avatar
Brown Bear Brown Bear is offline
Ok, this should do for a final topic starter.....show me your stuff......come on, you know you want to. <pete, you stay out of this > Show me and the rest of the world on every number you got for everything engine related. Be it 258, 360, 401, or even 4.0.... Know that water pump part number by heart now? Know what pieces you need to do the valley oil mod on the 360? Do your part to make our lives easier at the parts counter. Which would you rather do; just tell em the part number and get out in 15secs, or try to explain what a carb is to a walking pimple? IFSJA WANTS YOU.....and your numbers [img]smile.gif[/img]
NathanielButts
IFSJA Member #18
RIP-USS Minnow-The three hour tour is over.
MacGuyver - 1985 Grand Wagoneer
TFI, Edel Intake, Holley 80457S (yeah, it's shiney), K8600, K&N, Taylor Wires, Ford HD springs, and way freakin' cooooooool
Old 04-22-2003, 04:19 PM
rockjeep44's Avatar
The Advisor
Fuel Pump: Master E2182
For anyone running the holley fuel injection or needs an electric fuel pump above and beyond the "universal replacements" but don't want to pay the $105 or whatever for the Holley one, here's what you need.
I just replaced mine with it. It works great and keeps up with my 670cfm Holley and 350hp 360 engine.
-Andrew
Buggy Buildup
Originally Posted by welchct
Old 05-02-2003, 02:04 PM
viscacha's Avatar
viscacha viscacha is offline
Cool
Part numbers for a TFI ignition upgrade using Borg/Warner Select components.
TFI Upgrade for a 1986 J20 360V8
Parts Manufacturer - Borg Warner Select
Parts Make/Model - 1984 Ford F350 460V8 ECC ignition)
Cap adapter C194A 51-26303
Distributor cap C194
Ignition coil E92 (TFI)
Rotor D166
TFI Coil socket - Conduct Tite 85121 (Pep Boys)
Plug wires CH857 8mm 26-2602 (enclosed coil wire is for can type coil to snap on terminal cap C194. Ask for optional TFI coil wire. Keep the enclosed wire and old can type coil as a back up while trying out your'e new TFI upgrade).
steve
’86 J20
SOA, Dana 60's, F/R Lockers
Full High Steer, Ram Assist
Bunch of Other Stuff
Old 05-03-2003, 02:31 AM
Catfish33's Avatar
Catfish33 Catfish33 is offline
Don't forget numbers for the 230 "Tornado".
1997 Jeep TJ 5\" lift 33-12.50's, 1965 J3000 230 Tornado, 3 on the tree. http://s16.photobucket.com/albums/b2...ck%20Build-Up/
