Old 02-08-2010, 09:40 PM
EnigmaticEngineer EnigmaticEngineer is offline
Time to Build - 1969 Wagoneer Arizona
I thought I would go ahead and start my build thread...the last couple parts are trickling in and I hope it will be like the tv show Overhaulin You know...7 days later I have my dream ride lmao
Anyways...
http://s196.photobucket.com/albums/a...ep%20Wagoneer/
Here is a Bunch of Before pictures and there will be more to come. (These pics cover most of the vehicle, but I will have more specific close up before and after pics along the way)
The jeep has a virtually perfect body (2 small dents and absolutely No cancerous rust anywhere on the vehicle. Front fenders were removed by PO and primered, then re-hung improperly but that is an easy fix. Just shy of 50,000 original miles.
Intended Phase 1 modifications (yea...i have Phases lol) include...
SPOA Front on 4in lift springs. Rears going inboard on some Chevy 1/2 ton truck rear springs...prelim measurements say I should be close to a perfect level ride height (hopefully a bit tall in the rear if I am off...tried to bias the math in favor of that...) Brake lines and lengthened but stock driveshafts...all painted to avoid further surface rust.
1977 Wagoneer Dana 44's fully rebuilt/POR15'd with Cheapie Ebay Mini Spools front and rear (spools in hand now) Moog ball joints, high steer with 3/4in heims instead of TRE's all new seals (bearings are all in good shape front and rear) with 3.90 gears and 35x10.5 tires. I will be doing my own Mill/Drill/Tap on the knuckles as well as all the rest of the work other than having the front bench seat recovered.
Engine/Trans/Transfercase (Buick 350/TH400/Dana 20) being removed/cleaned/inspected/painted/resealed. Hopefully have HEI and 4 barrel intake in hand before engine goes back in but if not, Points will be re-set up and out comes my dwell-o-meter ( )and vacuum gauge to tune the dizzy and 2 barrel carb respectively. Maybe, just Maybe a mild cam and headers if I find a reasonably priced pair (cam would require a 4bbl intake and HEI or I won't bother)
While engine is out I will be stripping the interior/doors/windows/windshield and tailgate for paint. Was going with an OD Green but a friend recently gave me 2 gallons of single stage PPG 'bright white' so I'm buying primer and shooting the vehicle completely white interior and exterior...dash...engine bay...door jams...engine is probably going white also...I will see leaks easier that way POR15 will coat the frame and underbody with 'Truck Bed Liner' coating the interior floor board, rocker panels and anywhere else I deem necessary along the way (till I run out of my 1 gallon can of it I guess lol)
Going to re-do a bit more than half the wiring (only the Headlights/Stop/Tail/Turn, Wipers and Heater/vent controls will remain) and a basic Fuse block/Relay Block will control Extra Lighting/Gauges/Stereo/Winch/On board Air/any other accessories...
Then reassembly will happen. And I will hit the trails and determine what Phase 2 should have (definately including a built D60 front and 14b/D60 rear to match with 4.11's or 4.56's, full spool rear and selectable locker in front) That is probably the majority of Phase 2 actually lol...maybe some fine tuning to the rest of the vehicle while the axles are out...Hydroboost....Diesel Swap maybe (another most likely for phase 2 is the Diesel...i'm hooked on the idea)
And yes.....I know...its all bench racing (crawling?) until its happening and pics are up...it is all coming soon and I can't wait to start as I've been anxious to get my jeep built for over a year now. The pile of parts I have right now is significant but it is all straight foreward work...nothing horribly custom or complex...just a matter of investing the time, blood, and elbow grease.
Questions/Comments/Insults/etc all welcome of course as that is what build threads are for.........for me to brag a little and for you to tell me where I'm retarded
Thanks for reading, more to come in short order (day or three before I actually start on the axles which is the 1st order of business for the build)
Nathan in Northern Az.
P.S. Thank you very much to everyone who has responded to my constant questions about high steer, paint, suspension, mini spools, etc. I do appreciate everyone input, opinions and advice. And thank you to the people who have purchased parts from me (you know who you are) as the money I made from those purchases goes directly into my Jeep Wagoneer project....I'm currently unemployed and couldn't build this if I didn't have parts you guys wanted
Old 02-10-2010, 07:58 AM
Cool, this means I get to be the first subscriber to watch....
If you need a hand with anything, just holler, I'll find a way to come assist, and take notes...
46 cj2a
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 02-10-2010, 09:38 AM
I had planned on tearing the new axles down to install the spools, get the knuckles ready to machine, etc but they are still under the donor waggy and its Snowing at the moment at my house (well, sleeting...) and it doesn't look like its going to let me work outside.
But soon...Very soon
Thanks for the offer to help,
Nathan.
1969 Jeep Wagoneer
Currently Sitting and Possibly for sale.
Photobucket
Facebook: EnigmaticEngineer
Gmail: EnigmaticEngineer
Old 02-10-2010, 09:45 AM
jeeping1974's Avatar
Why a mini spool in the front and POR15 both axles? The POR15 won't hold up that well to being dragged over rocks. Maybe go with a roll in bedliner on teh axles as it is cheaper and easier to fix when it gets scratched.
03 GMC 2500HD - DD/toy hauler
06 Street Glide - Cruiser
Old 02-10-2010, 10:02 AM
orangecherokee's Avatar
if you're focusing on axle housing paint, you've got your head in the wrong place. the weak link is those D44s. just shoot it with the Krylon touch. Glossy black seems to work best and stays on better than the flat. concentrate on how not to blow up the outers.
Old 02-10-2010, 10:21 AM
Not a Rock Buggy...
This is a Trail Rig, not a rock buggy...and I am perfectly aware of the strength of Dana 44's. The Mini Spools are cheap traction until I can build a set of fullsize axles. (Already have a 14B rear with 4.11s', still trying to find a Passenger Side Drop D60 front)
As as far as POR15 goes, If I sprayed krylon over the surface rust, it wouldn't last a month. Roll on bedliner would do the same thing...I chose POR15 because I can clean the axle housings well and paint them and forget them...It is a bit more expensive than Krylon, but cheaper than having the housings sandblasted and then hitting them with Krylon/Duplicolor/etc. As far as rocks go, it is just as easy to touch up (as I have a Gallon of POR15). POR15 is much more durable than most anything in a spray can as well.
Always a bunch of Nay-Sayers to tell a man where he's messing up before he's even started
Nathan.
P.S. I purchased my 1969 Wagoneer for $700 and put another $100 in a waterpump and starter. I purchased the 1977 parts donor waggy for $100. I sold the 401 that was in it for $500 and have made over $100 selling misc parts. Still have the Trans/Transfercase up for sale. So as it stands, I have $300 bucks in my jeep and axles. (Not counting Mini Spools and other parts/pieces) I don't think I'm doing to badly considering I will have a completely painted/locked up/built Wagoneer for under $1000...
1969 Jeep Wagoneer
Photobucket
Old 02-10-2010, 01:08 PM
Nathan.
So? BFD. You're in Arizona and if this is just a "trail rig" then you should have zero worries about scraping the paint off of your axles or rusting. I've never seen an axle tube rust through and I've owned plenty of beater axles.
#2 ...
if you didn't want comments then maybe you shouldn't have posted this little string of words. I'm not trying to be an Great Googley MoogleyGreat Googley MoogleyGreat Googley MoogleyGreat Googley MoogleyGreat Googley Moogleyhole but if you'd like me to turn it up a bit I can. You're talking about paint. paint on an axle. does it have anything to do with the performance of the vehicle? no. if you want to make a show truck that can navigate trails just say that and we can move on. I figured you wanted comments/insults/etc on the actual performance of the vehicle.
Old 02-10-2010, 01:44 PM
...Questions/Comments/Insults/etc all welcome of course as that is what build threads are for.........for me to brag a little and for you to tell me where I'm retarded
Does the wink mean you don't want those things?
If so, maybe this is better suited for Gen Tech.
If not, you sort of have to take what comes back, it goes with the territory.
I'll toss my two cents out on building a 63-73 rear post mount wag into a decent DD/Trail Rig.
You got a lot of plans, don't make the same mistake I did.
Dump the shorter front springs and move the front hangers to accommodate something longer now. The shorter front springs don't flex real well and if you break a main spring 300 miles from home your not going to find an easy replacement.
Old 02-10-2010, 02:05 PM
Murphy's Avatar
Murphy Murphy is offline
Take it all with a grain of salt mate. And if you hit a hornet's nest with a baseball bat, duck and cover.
Old 02-10-2010, 05:50 PM
Lol...its not about being a Show Truck
#2 ...
Well, to be honest, it Does seem like you are trying to be an A-hole, or a Know It All/You should do it 'My Way' type. I want to hit the axles with a coat of something so it has a clean look...Easier to see a leak, damage, etc if the surface is one consistant color. It certainly isn't about Looks alone, our FSJ's very rarely win beauty contests. It isn't because I fear the axle tube is going to rust through either. "but if you'd like me to turn it up a bit I can"!?! How old are you? You sound like the HS bully...'Want me to beat you up again?' lmao
I only mentioned the paint Once in my initial post...that I was going to paint the axles with POR15. You and another gentleman made comments to me about the paint, It was never a Focus...just something thats going to be done when I have the axles apart and cleaned....so No..my head is not in the wrong place.
If you are goint to Pick on someone because they want to paint something, you might want to find a Ricer Honda forum...you'll have a lot more fun with those people than me. You can't get under my skin by being Rude or Insulting regardless of how much you try. (when I said questions/comments/Insults....the Insults part was more of a friendly joke because after all, I thought we were all on the Same Team here...FSJ's...It was not a serious request for people to be Rude or tell me how to build my waggy.) I got my gallon can of of POR15 for 25 bucks...I'm such an IDIOT because I'm going to hit my axles with it, huh? You can hardly buy enough Krylon to hit the axles for that price.
BTW, why do they always paint diffs on new cars/trucks these days? Or frames...why are they painted? Hmmm...Protection? Clean Look? When people build a tube buggy why do they paint the chassis? Do you talk crap to people building full on buggies because they powercoat their diffs?
What you are doing is not Comments...Its just Rude and an attempt to be Insulting. I didn't expect attempts to be intentionally insulted by other lovers of FSJ's. I am not a child and this is by Far not my first build. You might have a ton of respect on this forum, I don't know..haven't been here very long...but I do know you sound like a child trying to insult someone over POR15 vs Rattle can.
Try to have a better day tomorrow so you don't feel the need to make useless and rude comments to another forum member, I've done nothing to you.
Nathan.
EDIT: If you got upset because I posted after you and Jeeping about the Why I chose the POR15 to paint the axles, axle strength and my Blatent Tease about Nay-Sayers, then I understand where the animosity is coming from.....but it isn't very mature. I wasn't being rude in any way and I do appologize if it came across that way.
The D44's Are temporary. And cost me virtually Nothing. Free axles, 108 Shipped for 2 mini spools, 4 balljoints (that I already had from a previous build that went a different direction) some rust preventative (say 5 bucks worth) and 30 bucks worth of seals. Oh...and 80 Shipped for the high steer arms/75 shipped for the 3/4 heims (which are Flat Too Big lol...didn't realize their size till I had them in hand) and 48 shipped for the stud kit for the high steer arms...Thats $346 bucks Total (unless I messed up my math) for fresh, ready to run, locked up Dana 44's. Some toyota guy/sammi guy/Wrangler guy would be glad to have them when I'm done with them for 6-700 so I double my money on the back end also. I don't (and won't) feel like an idiot for Painting them with a quality coating.
Lastly...The more I think about it, I have NO idea why you would be acting this way. I never said it is 'Just' a trail rig, just that that would be its main use. I don't find any shame in wanting something to look decent while performing above average. I sincerely appologize for what EVER I did to you that makes you feel the need to make attempts at insults towards me...I did think we were all on the same team here.
1969 Jeep Wagoneer
Photobucket
Old 02-10-2010, 05:58 PM
Thanks.
I appreciate the Constructive Criticism. I happen to already have a set of 4in lift springs for the front (factory length) so I'll have to run those a for a bit until I find a suitable replacement set. The rears are going inboard (under the frame...hope I'm using that term correctly) and I found a set of 88 chevy truck rear springs that have an almost perfect arc height that I will slap under it as soon as I pick them up.
And about the .... The wink applied to the Insults part which apparently some people didn't catch. I don't see any need for insults around here considering we all come here for a love of FSJ's. I am very open to Constructive criticism and welcome it when ever I get it (Like your spring advice for example)
And I am confident in my decision to use a paint designed to P.aint O.ver R.ust (POR15). If I put anything else over the rust (rattle can, bed liner, etc)I'm pretty sure it would Fall off before I rubbed it off on rocks. I wasn't trying to be a Jerk if some took it that way, just explained why I was going with the por15 over other coating options.
Thanks Tad...You have been helpful (both directly and from reading your other posts)
Nathan.
1969 Jeep Wagoneer
Photobucket
Old 02-10-2010, 06:00 PM
Always :D
But I won't run and hide, I'll swing back at the buzzin bazterds. And to be honest, I have NO IDEA how I hit a hornets by mentioning my intended use of POR15....you just never know with some people I guess.
Nathan.
1969 Jeep Wagoneer
Photobucket
Old 02-10-2010, 06:42 PM
What did you expect when you post this in your thread? I got the same thing in my build thread. you just let it be water under the bridge.
I was only asking a simple question and stating that something along the lines of a brush/roll on bed liner would be cheaper. I didn't know that you already had a gallon of PO15. In that case, yeah, use it. I've used the Herculiner stuff on some of my axles and I never had an issue with it falling off.
As for the spool in the front, turning may be a bit difficult.
Old 02-10-2010, 07:02 PM
Gotcha.
I didn't feel like you were insulting, the previous messages are not directed towards you.
I think the POR15 is a good decision considering all the factors of the situation. I didn't think you were rude about the POR15 either...you asked why. The other gentleman made it seem like he thinks I'm being 'retarded' for using it. I have had bad luck in the past taking short cuts with paint (rattle can over Rust most of the time) I don't have much experience with the Roll On Bed Liner products, but I assumed that since it isn't Intended to be applied over rust, that it might not work as well as I'd like it to over a rusty surface.
I agree with turning and the mini spool in front....I plan on only locking in 1 hub in normal trail driving, then I can lock in the other if I need the extra climb....after all, an open diff only gives power to one axle and its the one with less traction...this way I can have complete pull with one tire and both if it becomes necessary. Not a typical thing to do, but it was a lot cheaper than a locker of any sort and plenty durable for my intended use. (By trails I don't mean Serious Rock Crawling trails...I mean the ones that are 4x4 only that run through the forest, going out camping, to the river, etc...I'll build a buggy one day for the significantly extreme stuff...I don't really want to tear up my waggy...its a 69 with less than 50k original miles and a virtually perfect body.)
It is water under the bridge, of course...I expected teasing, or advice/constructive criticism, just not blatent insults or rudeness. Opinions are always welcome, just no reason for some people to try to make themselves feel better by degrading others. I never made painting the axles a focus, the other poster, for some reason, did. I don't feel I made an a-$s of myself mentioning my intentions although others aparently did.
Thanks for posting on my thread, I do appreciate all opinions even if I don't agree, just not ones that are intentionally rude or blatenly insulting.
Nathan.
1969 Jeep Wagoneer
Photobucket
Old 02-10-2010, 10:46 PM
gsmikie's Avatar
gsmikie gsmikie is offline
Auto Trannie God
u r going to do the trans while its out .......
Old 02-11-2010, 01:13 AM
Don't think I need to...
Less than 50,000 miles on it...just seal and filter...it functions flawlessly at the moment...
Is there a hidden problem to the TH400's that I am not aware of that should be taken care of regardless? Or are you thinking just because of its age...
I thought about it...I'm not sure its necessary.
Nathan.
1969 Jeep Wagoneer
Photobucket
Old 02-11-2010, 05:16 AM
X2
The TH400 is a great tranny and can handle a beating, but while it is out.... and good rebuild kits are cheap, it kind of makes sence. You don't want to remove it after x amount of miles after getting it all together and running.
Old 02-11-2010, 07:49 AM
I can't believe I read that whole thing but I did. Yeah, you're right I'm in high school. I play football and date the homecoming queen it's an awesome feeling being me each day
Most people know who I am on here and I am in no way the end all be all of FSJs. I learn something new each day about these machines. However, I have been around the block with them. Probably more than you. I've swapped axles 4 to 5 times, transmissions 4 times, a few transfer cases and some other stuff. I know what works and what doesn't when it comes to strength and longevity. Then you come on here after I tell you the truth about those axles and you run back a smart quip about "it's not a rock buggy". yeah well I figured that Mr. Sensitive. I'm not trying to turn the world into rock crawlers. In reality, FSJs are one of the worst rides for crawlers. They're big, bulky, heavy, have horrible departure angles and weak axles for their size. Most you see are cut up badly, missing body panels, chopped frames, etc.
you asked for comments and suggestions. I gave you that but you decided to go on the defensive right from the start. you set the tone chief, I'm just following suit. seems like you already know what to do so have at it. it's your world, I just live in it.
Old 02-11-2010, 01:25 PM
Wow...thought I was dealing with an Adult....
I can't believe I'm responding again...but here it goes.
I did not set this Tone, You did Orange...and I quote...
"if you're focusing on axle housing paint, you've got your head in the wrong place."
Cheif...You designed the suit, you didn't follow it. You know what they say about making assumptions right?
You made the assumption that I was some how Focusing on Paint when in fact I never made it a focus at all. I simply mentioned that I was going to hit the axles with POR15 and then you made a rude and useless comment about my Head being in the wrong place....Because I mentioned Paint on my axles?!?! Yea....
"This is a Trail Rig, not a rock buggy...and I am perfectly aware of the strength of Dana 44's."
My quote....do you really claim that THAT set the tone??? Ok...
or was it This...
"Always a bunch of Nay-Sayers to tell a man where he's messing up before he's even started "
I guess the wink offended you right? How dare someone try to tease back and keep the tone Light....Alrighty-Then.
Now that I know you are a child, it explains a lot and I sort of feel dumb now for wasting my time defending myself against someone who isn't done with puberty yet. You haven't even made it out of the drive way to be 'around the block' with this sort of stuff. And while you might have more experience with FSJ's, you have no where Close to the fabrication experience as I. Period.
"Yeah, you're right I'm in high school. I play football and date the homecoming queen it's an awesome feeling being me each day "
I've been out of HS for well over 10 years kid....dated 3 of the 4 homecoming queens and went to prom 4 years in a row...being a jock and dating A homecoming queen is not impressive and is NO reason to have 'awesome feelings' each day...I hope there is more to life for you than Football and your GF.
And lastly...if you have anything Constructive, Intelligent, Well Thought Out, and Relavent to my build, I'd love to hear it...but complaing about the Paint I'm using or telling me that Dana 44's lose outers when inexperienced drivers have a lead foot and get their rig-a-hoppin is not useful to me, or anyone else reading this.
Thanks for your time, get back to class and get good grades or you'll get a spankin.... (yes...another wink, I know how they offend you so)
Nathan.
1969 Jeep Wagoneer
Photobucket
Old 02-11-2010, 01:37 PM
I'll look into it.
X2
Agreed, I hate doing things twice...I bought 4 boxes full of random trans rebuild kits/clutches/etc at an Estate Auction for $13 bucks recently...TONS of the stuff is labled TH400 but I'm not an automatic tranny guy (torn a few down, never Built one...) Built many manual trannys, but no autos.
Anyone here have the necessary info on rebuilding a th400? I probably have all new parts other than gaskets (and I might have those...) I'm certain it is something I can handle, I just have no info to run with.
If anyone is an automatic tranny Guru (gsmikie) maybe I could send you a ton of pics of all the parts I have for auto trannys. (Literally, many boxes of Clutches/Plates/seals/bearings/etc) Maybe I could trade you some new in the package clutch plates n stuff for a copy of your video?
Thanks for the advice guys.
Gsmikie, if you'd like to take the time to peruse through pics of my auto tranny parts, maybe we could work out a deal (we are only a few hours from each other) where you could get a ton of new parts for building th350's n th400's for helping/showing me to do mine? Maybe? I'm a quick learner and a very competent machinist/engine builder. I'll do all the traveling.
Thanks again.
Nathan.
1969 Jeep Wagoneer
Photobucket
