Old 08-03-2020, 07:50 PM
mantonas mantonas is offline
Heater Core Repacement 87 Grand Wagoneer
I did a search of the forums for this topic but did not find anything. I am in the middle of an air conditioning repair job and I need to repair an A/C hose with a crimp. It would make it easier to get to if I removed the heater core box, so I figured this would be a good time to replace the heater core. I have a 1984 factory service manual and it says you just have to remove the nuts holding the box to the firewall and it should come right off. I did that and the box does not want to come off. Before I start forcing it I want to make sure I didnt miss anything else holding the box on.
Any guidance? Thanks in advance!
Old 08-03-2020, 08:47 PM
Tripwire's Avatar
Tripwire Tripwire is offline
its sealed with goo, pry it off gently
Abort? Retry? Ignore? >
Old 08-03-2020, 09:44 PM
GWNashville's Avatar
GWNashville GWNashville is offline
http://www.ifsja.org/forums/vb/showthread.php?p=1720845#post1720845
There is a guy on E.bay that sells the copper heater cores and evaporator cores for $100.00. I bought a evap core last week it is beautiful, way better than that aluminum crap.
Richard
GWNashville
Email:alexhanmusic@comcast.net
1989 Grand Wagoneer 360 c.i.
727 Transmission
Sniper EFI Hyperspark
Serehill Rear Glass and Fog Light Harness.
Old 08-04-2020, 11:23 AM
Can you send a link to that Ebay seller? I bought a replacement heater core and you're right, it looks kind of cheap.
Also, I did a little more searching around about how to get that heater core box off and I think there may be two additional nuts or bolts that need to be removed that are accessed from inside the car, behind the A/C box. Can anybody confirm or deny this? I'm leaning toward not replacing the heater core now that I'm learning this since it's not leaking or blocked right now, but I will have to do it someday so I would like to know for sure.
Old 08-04-2020, 12:37 PM
SlowGear's Avatar
SlowGear SlowGear is offline
Yeah, you'll have to drop the AC housing under the dash to get at them, or at least I did.
More here: http://www.ifsja.org/forums/vb/showthread.php?t=149455
Mike
88 Grand Wagoneer
Bone stock - except the missing stuff
Old 08-04-2020, 03:54 PM
Bummer.
Is there any way to separate the housing under the hood and extricate the heater core?
Old 08-04-2020, 04:29 PM
SlowGear's Avatar
Pretty sure the whole thing needs to come out to split the housing.
Dropping the A/C housing wasn't a big deal. Contorting my body to reach the nuts under the dash was the worst part.
Mike
88 Grand Wagoneer
Old 08-04-2020, 04:34 PM
PBG928 PBG928 is offline
Note that all Four Seasons AC evaporators are all Aluminum despite pictures showing them to be copper. I ordered one from Team Grand Wagoneer several months ago baed on picture showing copper tubing. I got an all aluminum one and sent it back complaining that their website was wrong. I believe they changed picture and now show all aluminum ones. They work but you have to be careful not to over tighten them and damage the flares.
1989 Jeep Grand Wagoneer
1986 Jeep Grand Wagoneer
1985 Jeep Grand Wagoneer (sold)
1978 Jeep CJ-5 (sold)
1968 AM General M35 (Sold)
Palm Beach Gardens, FL
Old 08-04-2020, 09:40 PM
GWNashville
My evaporator came in today and it is Copper. Will send pic tomorrow. bschaetz (9834).on Ebay. There are two bolts under the dash, you'll have to drop the AC housing to get access to them,
Richard
GWNashville
727 Transmission
it lives heater- heater core bolt pics flying_squirrel General FSJ Tech 0 10-07-2012 11:23 PM
63-72 Heater Core Different Size? red mistress General FSJ Tech 15 01-07-2011 07:18 PM
replacing heater core only and/or assembly on firewall dutchman General FSJ Tech 18 12-24-2009 12:39 PM
heater core replacement questions beloth General FSJ Tech 3 11-02-2008 10:33 PM
Heater core in heater bypass line? fsj1978 General FSJ Tech 3 10-12-2007 09:34 PM
