Old 07-29-2020, 06:14 PM
KdkGrizz's Avatar
KdkGrizz KdkGrizz is offline
Question Fuel tank vent valves
Has anyone out there ever successfully replaced either or both of the Fuel tank vent check valves with the tank still installed?
Was just thinking. If I don’t have any of the factory emissions on the vehicle do I actually need those 2 vent valves? Other than for rollover’s..
Yes I snapped off the hose nipple on both Valves installing the tank.. ugh
Kodi
82 WAGONEER It's a project
360ci 727 and NP208
The early bird may get the worm, but the second mouse always gets the cheese...
Old 08-04-2020, 02:37 PM
KdkGrizz's Avatar
Really no one has a comment to make on this one
Kodi
360ci 727 and NP208
Old 08-04-2020, 04:13 PM
SlowGear's Avatar
SlowGear SlowGear is offline
Assuming your 82 fuel tank is the same as an 88, I don't think you can access them without either dropping the tank or cutting new/enlarging the existing access port. There is just no room to get a hand on them from below.
Mike
88 Grand Wagoneer
Bone stock - except the missing stuff
Old 08-04-2020, 04:22 PM
PBG928 PBG928 is offline
If you drop tank from front with rear hoses attached you can tilt enough to replace them without fully dropping tank. Loosen straps and skid plate next to drive shaft as well.
1989 Jeep Grand Wagoneer
1986 Jeep Grand Wagoneer
1985 Jeep Grand Wagoneer (sold)
1978 Jeep CJ-5 (sold)
1968 AM General M35 (Sold)
Palm Beach Gardens, FL
Fuel Priming troubles...UPDATE: problem isolated Pman General FSJ Tech 0 04-02-2012 09:05 PM
Aftermarket Fuel Tank - Missing Vent? krek General FSJ Tech 4 11-08-2010 08:59 PM
69 Waggy Stalls When Warm kodyharrell General FSJ Tech 11 09-30-2009 11:07 AM
Upgrades/Tweaks to Improve MPG prayforsurf General FSJ Tech 33 01-04-2007 10:39 PM
filler neck questions again mark General FSJ Tech 7 08-25-2003 12:39 PM
