Old 07-16-2020, 07:54 PM
KdkGrizz's Avatar
KdkGrizz KdkGrizz is offline
Hole in Plastic fuel tank
Looking for any information on repairing a hole in the plastic fuel tank in an 82 Waggy.
Kodi
82 WAGONEER It's a project
360ci 727 and NP208
The early bird may get the worm, but the second mouse always gets the cheese...
Old 07-16-2020, 10:54 PM
letank's Avatar
letank letank is offline
plastic solder is often quoted for motorcycle plastic repairs...
Michel
Old 07-17-2020, 10:42 AM
KdkGrizz's Avatar
Thanks 😊
Kodi
360ci 727 and NP208
Old 07-17-2020, 01:50 PM
I used to work with Seal-All glue but they switched formulas and supposedly have one specifically for fuel tanks now. I would swap the tank then add protection if the hole is a rip and you’re dropping it out anyways.
Old 07-17-2020, 09:15 PM
KdkGrizz's Avatar
Talking
[quote=Carnuck]I used to work with Seal-All glue but they switched formulas and supposedly have one specifically for fuel tanks now. I would swap the tank then add protection if the hole is a rip and you.
Well it’s not a rip. It’s a hole, and oddly enough precisely the same size as a 3/8” drill bit. I blame myself, and can’t be mad about it. My 32 year old daughter who grew up working in the garage with me, but hasn’t worked with the old man for 10-12 years. Decided she wanted to help my install sliders. The passenger sent way too smooth. The driver side well not so much. I gave her a piece of steel plate to slide between frame rail and tank..... well she forgot and drilled a hole through the side rail and tank. I can’t be mad.
Kodi
360ci 727 and NP208
Old 07-20-2020, 11:50 PM
letank's Avatar
doing a quick search
https://www.instructables.com/id/Rep...tic-Fuel-Tank/
Michel
Old 07-21-2020, 09:18 AM
Tap hole and run a bolt into it. Poly tanks are very thick. Seal threads and it should be good to go.
Old 07-21-2020, 01:53 PM
SJTD SJTD is offline
I'd put a nut on the inside with the bolt if you can get to it. Maybe with a washer with a big hole to capture an o-ring that's a little thicker than the washer.
I wouldn't bother with a tap. Just run a tight fitting bolt into it.
Sic friatur crustulum
Old 07-22-2020, 07:28 PM
letank's Avatar
I did a few times on my 74 metal tank, worked well, especially when camping in the middle of nowhere... the parts store have some gas sealant goop...
Michel
Old 07-23-2020, 06:37 PM
KdkGrizz's Avatar
Is the tank polypropylene or polyethylene?
Kodi
360ci 727 and NP208
Old 08-04-2020, 09:36 AM
82camo401j10's Avatar
82camo401j10 82camo401j10 is offline
I used fiberglass mat and JB for putty!
Worked several times.
The JB is more flexible when set than FG gel!
Detailed Holley Sniper Install Write Up (AMC 360) posulli88 Fuel Injection 14 05-31-2018 06:51 AM
Venting Plastic Fuel Tank posulli88 General FSJ Tech 3 04-08-2018 10:00 PM
plastic fuel tank strikes again originalrecipekenny General FSJ Tech 0 01-09-2011 07:51 PM
How many miles should it go? 82Laredo General FSJ Tech 9 01-20-2007 10:23 AM
Discovery - cat doesn't taste like chicken 3jeepsdeep General FSJ Tech 13 10-19-2004 01:52 AM
