Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Wanted
Old 07-15-2020, 09:58 AM
Wagoneer Taylor's Avatar
Wagoneer Taylor Wagoneer Taylor is offline
401, 0.40 Over Pistons
I am looking for a set of 401 Pistons, at .040 over bore.
I have a set of 401 Pistons at 0.30 over bore for sale or trade.
poppitz123@gmail.com or PM me, thanks.
Some call me Taylor...
Soon to be a 401!
"Soon" is a relative term, also cracked cylinder put a hurt on me
Old 07-17-2020, 03:06 PM
Did you check for core shift?
Old 07-20-2020, 07:16 AM
How would I do this?
Soon to be a 401!
Old 07-20-2020, 08:11 AM
Machine shop can do a sonic test to see. Anything over 0.020 bore it pretty much requires it or overly hot spots cause the block to warp and crush the cylinders as someone else found out the hard way.
Old 07-20-2020, 08:41 AM
Oh then yes I will be having them check this.
Soon to be a 401!
Old 07-21-2020, 04:00 PM
J20 project's Avatar
EEk, everything I ever heard was that about .30 over was the most you want to do in terms of being able to cool the engine...But...in all fairness, I have never done it.
J20
BP Drivetrain...........
775-537-7918
Old 07-22-2020, 07:34 AM
I keep getting stories either way, lots of people say you shouldn't go over 0.020 (I don't disagree with this, there appears to be a lot of info to support it). But on the other hand I get a lot of people saying they have gone to 0.030 all the way to 0.060 without problems.
I'm going to take every precaution I can with this block, it was already 0.030 over and had no signs of over heating or running hot that I could find. It still had all the little disks that a rebuild shop puts on it and the engine was rebuilt in 2001.
I realize that all of you guys are just trying to look out for me and the engine but I'm gonna risk.
Soon to be a 401!
Old 07-22-2020, 12:09 PM
I'm at 030 over without issues. During my build I searched theamcforum about boring and there were lots of posts from folks with 401 blocks that were 040 and 060 without issue. There was also lots of advice to "not go more 030" but I only saw one person at 060 say they had heating issues. There were other seasoned AMC V8 engine builders saying it's not a big deal to go 040 or 060. It would probably be best to have the walls sonic checked to check their thickness but if 030 is fine, I can't imagine an extra 010 would make so much of a difference that you would have problems.
Old 07-22-2020, 02:05 PM
You might try a PM to SC/397 maybe he has something you could use?
He is an AMC engine guru.
Old 07-22-2020, 02:16 PM
I talked to him as well, he said I should be fine. At 0.060 over you will want to sonic check for sure. He also mentioned one of the most important things is to clean out all the water jackets of crud.
I plan on sonic checking anyway.
Soon to be a 401!
Old 08-04-2020, 02:28 PM
Thanks!!!
Have you used the Eutectic pistons before? Ive never heard of them.
Soon to be a 401!
Old 08-04-2020, 04:16 PM
SC/397's Avatar
SC/397 SC/397 is offline
Those listed in the add are forged not Hypereutectic.
But to answer your question NO, I do not use Hypereutectic pistons. They will not take any detonation whatsoever. In my humble opinion, normal old cast pistons are better than hypers.
Old 08-04-2020, 04:24 PM
I just read the post a bit more carefully
Thanks again
Soon to be a 401!
401 Timing with 9:1 compression pistons FSJ Guy General FSJ Tech 15 10-12-2010 02:25 PM
Rebuilt 401 Cam Break In and Dyno Runs crazydog General FSJ Tech 15 07-22-2010 10:29 PM
401 rebuild questions Jeep Craze General FSJ Tech 7 08-07-2009 11:17 AM
Forged 401 pistons no more!!! jeepsr4ever General FSJ Discussion 6 03-25-2009 02:31 PM
401 swap/ balancing info justin'sbig7 General FSJ Tech 1 02-01-2006 02:11 PM
