  #41
Old 05-02-2020, 08:52 PM
78 WIDETRAC's Avatar
Originally Posted by GWNashville
It's a Holley 255 LPH, Part number 12-158. I am installing a Sniper 4-Barrell with a edelbrock intake no EGR. I did have to trim out the sides a little so that the top would fit. I also fill in the little trench next to top wit JD Plastic weld. Really tight fit.
I'm a little confused about these pumps.
The one you are going with does not have a return. Thanks for the PM. and clarification.
Your build is looking awesome. When does the body drop down?
Old 05-07-2020, 07:04 PM
GWNashville's Avatar
GWNashville GWNashville is offline
Nashville GW
Guys
As Rick Serehill would say, I am surprised I did not have a car-becue. I was shocked when I pulled the fuse box. New wiring, not looking forward to this.
Richard
GWNashville
Email:alexhanmusic@comcast.net
1989 Grand Wagoneer 360 c.i.
727 Transmission
Sniper EFI Hyperspark
Serehill Rear Glass and Fog Light Harness.
Old 05-07-2020, 07:32 PM
Crisis averted!!!
Old 05-07-2020, 10:40 PM
DarkMonohue's Avatar
Shakes hands with danger
Whoa! That is crispy. Good catch. What circuits are the roached wires on?
Old 06-01-2020, 09:49 PM
GWNashville
Not sure let you know tomorrow. Starting to rewire in the morning.
Richard
GWNashville
727 Transmission
Old 06-09-2020, 07:09 PM
Any updates? Were you able to start re-wiring?
Old 06-11-2020, 04:17 PM
Nashville GW
I walked out to garage to work on wiring. Got distracted sanded and painted firewall, finished connecting front end to pitman and pitman to steering box, installed heater core, heater fan, new 3/8" fuel line for Snyper, wiper motor, installed Brake Hydroboost (need to Bleed- son coming over Sat to help), finish undercoating. Installed steering shaft. I did get a little wiring done.
Richard
GWNashville
727 Transmission
Old 06-11-2020, 09:27 PM
cu4whln's Avatar
cu4whln cu4whln is offline
What hydra boost did you use? Source?
Is that the Elliot unit ?
1977 "401" 'Da Chief
1979 Chero: "Madness" [Sold]
2001 XJ : Driver 2016 JK 2 door
Round 2- LT Swap: 'Da Chief:
"Madness" build here:
Old 06-11-2020, 09:33 PM
Nashville GW
Jim
I went with Elliotts company Custom Power Brake. I sent you a PM about being about being able to put cannister on either side. Elliott is a good guy.
http://www.custompowerbrake.com/
Tell him I said hello.
Richard
GWNashville
727 Transmission
Old 06-12-2020, 09:58 PM
Nashville GW
Some serious "Red Neck Engineering" went into getting the GW body back on the frame. Lots of help from my Son-in-law Gilbert (center) and my son Alex (Right) greatly appreciated. We really had a blast that day.
Richard
GWNashville
727 Transmission
Old 06-13-2020, 10:16 PM
Nashville GW
Big difference! The most difficult part is getting the old body mounts out. I only broke one mount bolt in the back (felt pretty lucky about that). I soaked the bolts with Blaster for three days straight. I believe this helped a bunch. Glad thats done.
Richard
GWNashville
727 Transmission
Old 06-14-2020, 09:08 AM
cu4whln's Avatar
What mounts are those? Rubber?
Old 06-14-2020, 11:59 AM
Nashville GW
They are the Poly from BJ's. I searched and searched for rubber, but no luck. I like these.
Richard
GWNashville
727 Transmission
Old 06-19-2020, 08:32 PM
Nashville GW
Installing Transfer case 229 and Transmission 727 this week. First time rebuilding TC, those bearing pins were a PITA. Dropped them inside the casing 3 times. Which meant removing parts three times.The trick is less grease not more, so bearing fits easier (Who Knew). My TC was leaking horribly, I hope this takes care of that issue. Except for the previous mentioned pin bearings there was nothing difficult about the rebuild.
Richard
GWNashville
727 Transmission
Old 06-19-2020, 08:43 PM
cu4whln's Avatar
I have a basically new 229 IF that one doesn't work out ....
Yea, NOW I tell you !!
Old 06-19-2020, 09:09 PM
GWNashville
That's how my luck has been going. Gonna focus this week and get moving. Need to talk to you sometime about painting questions.
Richard
GWNashville
727 Transmission
Old 06-19-2020, 09:52 PM
cu4whln's Avatar
Painting what? The plastic?
Old 06-24-2020, 06:21 AM
GWNashville
I purchased the Hydroboost from Elliott at Custom Power Brake. Elliott was easy to deal with and helpful. A heads up, you are gonna need the mounting bracket from the old brake booster to install Hydroboost to the firewall. The cool thing is you can install the hydroboost with the cannister on either side. I choose facing away from the engine, felt like it gave me more room. Elliott suggested hoses to use for the power steering and steering box with a little persuasion they work well.
Richard
GWNashville
727 Transmission
Old 06-25-2020, 08:22 PM
cu4whln's Avatar
Nice hydraboost.. Can you share some details on the hoses and how you routed them?
tia
Old 06-25-2020, 10:03 PM
GWNashville
I'll send you the numbers of the hoses I used, takes a little persuasion to bend the tubing to fit along the frame.
Richard
GWNashville
727 Transmission
New (to me) 1989 Grand Wagnoneer zavock General FSJ Discussion 0 09-09-2016 03:27 PM
Howdy! 1989 Frankenstein Grand Wagoneer dlopeman Introduce Yourself. 1 09-22-2015 06:48 AM
1989 Jeep Grand Wagoneer, 2150, no power valve? dkmcgowan General FSJ Tech 11 02-07-2012 12:43 PM
Guatemalan GW stuck in Nashville ... need help! Greg Taylor General FSJ Discussion 8 11-01-2009 08:03 PM
1989 Grand Wagoneer starscream General FSJ Tech 3 06-08-2009 10:57 PM
