  #41
Old 07-05-2018, 10:40 PM
Tonight I rented a good 140 amp Lincoln welder and welded up the bumper brackets, the shackle brackets, and front hitch. Wow, what a difference between a good 140 amp welder and my pathetic 85 amp Harbor Freight turd. I feel so motivated at how nice most of my welds are (not all, I have some that look like caterpillars crawling on my front end). It just felt nice to have a victory tonight.
I started to wire wheel the frame horns for paint and my grinder died after one frame horn. I painted it, cleaned up the mess, and am heading in. I go on travel for the next 2 weeks so I can't touch it or the wife will remove my manhood.
I am bringing my power seat bottoms with me on travel so I can clean/rebuild them in my hotel at night. I'll be home on the weekend but hangin with the fam so no FSJ work. Cross your fingers that I get a call from the machine shop soon. I am jones'ing to start putting my engine together (especially after seeing Full Size Jeeper's engine starting to come together)!
Old 07-05-2018, 10:46 PM
asphaltrockdweller's Avatar
I really wish you and Brad would hurry up with your builds already!
Like I am one to talk smack?
Old 07-07-2018, 09:54 AM
bkilby's Avatar
bkilby bkilby is offline
Ha! My build has slowed down. but not done. At this rate, rang will be done before me. Lol. Rang, you should sand blast the frame if it's not too late. I think it cost me $150.00 for mine.
Old 07-10-2018, 09:30 AM
CameraFinn's Avatar
CameraFinn CameraFinn is offline
9 Hours
Wow, 9 hours! That's crazy. Mine probably took 9 weeks just to get the same chassis out and painted and back in.
Hope your machine shop calls you soon, the engine is the coolest part!
Keep up the great work, it looks great.
Finn
You know it's a good morning when the gas gauge works for the whole drive.
1970.5 Gladiator J-4800 Camper Special Custom Cab - 55,000 Miles (Under Reconstruction)
1967 Jeepster Convertible - 8071 Deluxe - 65,000 Miles
Old 07-10-2018, 10:34 AM
It's too late. I would have LOVED to have it blasted/painted but I had to get it installed. The best I could do is pressure wash it and rattle can it. It looks better than it did but it's not nearly as pretty as yours. I'm OK with it, though because it is still light years better than it was.
Keep in mind:
1) My front end was already pretty much stripped so all I had to do was remove the brake line brackets, shocks, and leaf springs. Rear end all I did was cut the soft brake line, and unhook the e-Brake lines. Then 4 U-bolts and 2 shock bolts and the axle came out. Last step was unhook the rear wires, bumper, hitch, and body bolts and out came the chassis.
2) Putting it back in, all I did was bolt up the 6 body bolts, and install the rear springs and u-bolts.
In the grand scheme of things, I didn't do that much. I'm stoked I have a straight chassis but I still have lots of work to do to consider my chassis completely installed.
As I walked out the door to head out on travel, I saw my pile of parts (new rear soft brake line, wheel cylinders, flare nuts, and u-bolts) and it hurt. I felt like my young son just asked me to play catch and I said "No son, I have work to do" and he walked away with a tear in his eye.
Old 07-26-2018, 03:49 PM
No juicy pictures. Last night I finished painting my frame horns and installed my S-10 Steering gear. I also just ordered my cam kit.
Cam Kit at Summit Racing
I found this kit on Amazon for $369/free shipping and Summit matched the price. They are shipping from Nevada so it gets here in 1-3 days. Woo hoo!
My bottom end engine work is done at the shop but I am not sure when I will be able to pick it up. Maybe early next week?
Hopefully tonight I will bolt my front suspension and steering back on. That will allow me to set it back down on it's own weight and let me push it out of the garage so I can sweep and mop under it.
I mentioned earlier that I would be working on my power seat bottoms. Nope. Didn't happen.
Old 07-26-2018, 11:07 PM
FleetFox FleetFox is offline
I'm jealous man, you're moving at light speed. Only new shiny things I've been putting on are bearings and seals..and no one will ever even see them...
Old 07-27-2018, 07:17 AM
Haha! Keep in mind, my rig is a cruiser/driver so most of what I am doing is cleaning and rattle canning. It sounds like alot but it's not really. The pictures make it look better than it is. When I am done it will be reliable and clean. Not spotless, not restored.
Old 07-30-2018, 09:49 PM
OK, last week I was able to stay on schedule. Front suspension and steering in.
Got my cam kit, too. I've never ordered a nice cam like this so it was a total thrill opening it up. I felt like a little kid on Christmas!
Timing chain needs a little love. It has the excess oil holes that need to be brazed.
Hope to pick up my block this week. Next up is painting the firewall and cleaning/re-gasketing my trans. Good times!
Old 07-31-2018, 05:49 PM
bkilby's Avatar
Why braze the holes up? Too much oil is a bad thing? You're moving right along on this project. Good job!
Old 07-31-2018, 06:36 PM
I have seen a few posts about it. Specifically this one:
http://www.ifsja.org/forums/vb/showt...11#post1678711
THere are a few more on here that I have seen but, pretty much anything I see from SC/397 I take seriously.
Old 08-01-2018, 08:41 AM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
dang, alotta GOOD work !
i bet you are excited for sure...
the chassis looks great
ole yeller is getting a new lease on life !
wish i had the know - how and skills you have.
keep us posted.
dave in NC
Old 08-02-2018, 11:35 AM
Oh my goodness! I am in love with my engine parts! Block is home, rotating assembly is home, heads are now at the machine shop. I started painting right away because the cast iron is super bare/raw and I don't want it to flash rust. I hope to assemble the bottom end this weekend. I painted the back because once it's on the stand it will be hard to get the bell housing area.
Check out these pistons and rods! My rods were cleaned and blueprinted, ARP hardware installed, then all balanced. I was shocked at how new they looked. I did not expect them to look this nice. The pistons are so nice I don't want to hide them in the block. The crank was cleaned, polished, and balanced, too but it was in a box and I didn't feel like getting it out to take a picture. It looks brand new. They cleaned up my damper before they balanced the rotating assembly so it looks fantastic as well; just needs a coat of semi gloss black.
As I was driving home from the shop yesterday, I realized I had ALOT of money worth of parts in my trunk. $1300 in machine work, a $380 cam kit, $400 in pistons and rings, close to $200 in bearings. Not to mention the intrinsic value of a 401 crank, block, and factory forged rods. As a wise man once said (Full Size Jeeper) "THESE THINGS ARE NOT CHEAP TO BUILD".
Old 08-02-2018, 03:32 PM
be sure to wd40 all that bare cast & keep/get everything bagged up.
rust is already there if bare you just can’t see it yet.
dunno about up there but down here the air is uber-dirty!!
remember dirt is your enemy.
looks purdy though!
Old 08-02-2018, 11:51 PM
NICE!
Gotta love freshly machined iron.
Old 08-05-2018, 11:23 PM
I don't have any good pictures to show but had a good weekend. I was able to clean my trans up pretty well and replaced all the gaskets and O-Rings except for the input shaft and the pump body. Those will come later (I have them just didn't put them on). Then I took my trans off the engine stand, put the engine block on and started loving on it. Painted it, freeze plugs in, crank in (end play was .005, middle of spec, woo hoo!). I got #1 and #2 in. Opening up the oil scraper rings took FOREVER. Cam is in.
I started installing my timing chain set and had to stop because I couldn't get the extra oil passages brazed. I'm sending it to SC/397 for some help. I also had to wait for my degree wheel to show up (it showed up today after church). So I covered my engine up with towels and a plastic sheet to keep it nice and dry and dust free. I have a pile of parts to bring to my sand blaster this week (timing cover, oil pan, valve covers, etc.) so I can keep some forward progress going while I wait.
Old 08-13-2018, 10:59 AM
These first few pics don't really show anything that great but they represent progress so I feel better about them. This weekend I re-installed my bumper, hitch, and spare tire. They were all off following the chassis swap. The 78 chassis has rivets in two of the bolt holes for the 79+ bumper brackets and it was a biatch getting them drilled out. The upper holes for the bumper bracket didn't line up either, so that took some finagling. This cleared out a huge floor area so my garage feels much less cluttered. I swapped on new Grade 8 U-bolts on my rear axle, too.
From the last week of work, here's my engine and trans. Trans is cleaned and almost ready to go in. I sooooo love AMC blue. Especially with the fresh brass freeze plugs
Also cleaned and prepped my timing cover. When I took it to the media blaster I found it was significantly corroded (not really surprising, just disappointing). Considering the condition of the water pump that was on my rig when I bought it, this could have been much worse.
Water Pump thread
I had to rebuild portions of the flanges with JB Weld. Normally I would buy a replacement cover but the machinist is consuming alllll my money these days. I am satisfied this will hold, though. It was just the flanges that were corroded and I was able to get them pretty solid.
I blasted/painted my valve covers and oil pan in semi-glass black. The picture make it look worse than it is.
Old 08-16-2018, 10:55 AM
bwwhaler's Avatar
bwwhaler bwwhaler is offline
X2...
87 GW 360 performer intake Holley 670 HEI
Razor Grill 4"BJ's springs 32's CS-144 Serehill's light and tailgate harness
Old 08-16-2018, 09:02 PM
looking real good!
Old 08-16-2018, 10:17 PM
bluehwy's Avatar
bluehwy bluehwy is offline
FUN FUN! Thanks for sharing!
Previous: 1988 Grand Wagoneer
Current: 1979 Wagoneer
"Well I've been down so GD long! and it looks like up to me..." Furry Lewis
2009 Summer Event Sponsorships Announcement (ECI / Etc.) billyrb General FSJ Discussion 6 05-14-2009 01:03 PM
