  #401
Old 07-27-2020, 11:33 AM
DarkMonohue's Avatar
Shakes hands with danger
There are only a few basic types of oxygen sensors. Is yours wideband or narrowband? Heated or not? How many wires?
I also have some extra bungs here. Let me know if I can send you one.
Old 07-27-2020, 11:52 AM
Your truck looks next level awesome now! Wow! The grill with the 4 headlights looks SOOoooo great!
I think your fueling problems are in your fuel pump/regulator (like babywag said in the other thread). You EFI relies on steady fuel pressure (even as fuel demand increases) and as it drops, your truck runs lean, your EFI tries to add fuel by extending the fuel pulses but that does not work because your pressure is so low.
That's my guess.
Old 07-27-2020, 03:48 PM
Crankyolman's Avatar
OK, I gave everything a good looking over and found no exhaust leak or signs of one. I found a website that says
[quote=other website]
FiTech currently uses a Bosch LSU 4.2 oxygen sensor, also referred to as an O2 sensor. FiTech recommends using a replacement sensor from a
'72 J4500
Old 07-27-2020, 04:21 PM
I believe that's a wideband sensor, and likely the same one the Innovate LC-1 wideband controller in my other car uses.
Does FiTech give you the means to stay in open loop mode so that you're running just on the base tables and not trying to trim mixture based on sensor feedback?
Do they give you a procedure to calibrate the wideband sensor?
Old 07-27-2020, 05:17 PM
Thank you, I'm very happy with how it looks
I'll address the fuel pump issue over in the other thread when I have time.
'72 J4500
Old 07-28-2020, 10:16 PM
I'm currently going to take a short break from freaking out over the running problems and concentrate on some other things for a few days.
Yesterday the Raptorliner arrived so now I need to finish prepping so I can spray that and that will finish the body.
I also need to work on cleaning everything up and mowing the back yard which has become quite overgrown again
On top of that I go back to Wed-Thur-Fri off on Saturday which means I will be working 2nd shift Wed, Thur, Fri, then go to 1st shift Sat, Sun, Mon, and Tue which sucks and I don't know how much I will get done over this next week.
'72 J4500
Old 08-02-2020, 07:44 PM
Today 78 WIDETRAC decided it would be a good day to take a drive up to see me. We had a nice little visit and I got to show off my truck
and he drop off these
Which may not be absolutely perfect but they are close enough for me
Thank you 78 WIDETRAC
'72 J4500
Old 08-02-2020, 09:47 PM
78 WIDETRAC's Avatar
It was nice to meet you, and see your truck in person. It is NICE! I like the door lock mod. They just operated so smooth.
I agree with you on our door locks being hard on keys.
I'll look for a similar kit.
Other than the bit of traffic north, I was a nice drive. Heading south was a total breeze. I was back by 5
I'm glad those will work for you. I had no use for them.
Old 08-03-2020, 07:47 PM
It was really nice to meet up with you. I've never met anybody from the site before.
When we talked about the inner headlights I wish I had taken the trim ring off and shown you exactly how they are mounted.
I really like the power locks and wish I had installed them years ago. I did have to modify the little clam that secures it to the rod but that was just a matter of clamping it into a vice and using a drill bit the same size as the rod to make the groove large enough.
'72 J4500
Old 08-03-2020, 07:54 PM
I'm very close to spraying the bedliner. Basically I need to install the close out panels and the fuel filler hose shroud. I was going to do that a couple days ago but when I dug them out I realized they were in a little rougher shape than I remembered. So I took them to work, sandblasted and mechanically stripped them, did a little bit of repair work and brought them home and primed them and painted the back sides. Now I just need to reinstall them, shoot a little primer and I will be ready to apply the bedliner. That will finish the paint job for the most part. After that it will be reinstall the door cards and figure out what's wrong with the fuel injection.
'72 J4500
Old 08-03-2020, 10:20 PM
ddversatile's Avatar
ddversatile ddversatile is offline
Its really coming along! I really like the colours and how they compliment each other nicely, hopefully the EFI issue is not too hard to fix but dont loose hope on your beautiful old rig!
1968 Jeep Gladiator J-3000 327 Vigilante V8, T-18 transmission, Dana 20 Transfer Case (Twin Stick), Dana 44 full float in the front and semi float 53 in the rear. 4.09 axles
1972 GMC 1500 basket-case (300$ buy )
Old 08-05-2020, 07:57 PM
Thank you,
I hope not to lose hope but Mrs. Cranky kind of has. She was talking about buying a brand new truck today So I better get this project wrapped up soon.
'72 J4500
Old 08-05-2020, 08:07 PM
Today I shot the bedliner
It didn't go very well
It seems what they claim is enough to cover an 8 foot bed is not capable of covering an 8 foot jeep truck bed...well it's almost enough to cover it with one coat but not the tailgate
But it will due until I get some more.
Next is the fuel injection. I spent a little time today rewiring the extra headlight relay to become a fuel pump relay. I plan on running the in tank pump directly off the battery via a relay rather than through the Fitech so I can see what that gets me. I hope to have that done tomorrow but may not, who knows. I understand it may rain tomorrow and Mrs. Cranky could use some time out of the house.
I also need to buy a new pair of shoes. The pair I have been wearing through this whole ordeal have become a bit worn
'72 J4500
Old 08-10-2020, 02:01 PM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
hey cranky,.....my shoe blew out just like that the other day.
I took a pic with my trusty flip phone, and sent to my girlfriend,...
cause anyone who knows me, knows I don't spend on myself or clothing, etc....
but I will spend all I got on restoring a car or truck that I never drive !!!
and I look like a street bum !
truck is looking good.
dave in NC
Old 08-10-2020, 06:06 PM
dave in NC
It's ok, I fixed it
I just took a little gorilla tape and it's all better.
'72 J4500
Old 08-14-2020, 08:07 PM
Well, the fuel injection problem seems to be fixed and I think I have the truck ready for prime time
I plan on driving it to work tomorrow.
I still need to find some new front bumper bolts which are proving to be a bit elusive. It turns out they are 7/16 and the hardware stores around here seem to only carry 3/8'' and 1/2" carriage bolts in stainless steel. I have one more local place to check before I make the drive to McClendon hardware who will most likely have them.
'72 J4500
Old 08-14-2020, 10:00 PM
chubbinius's Avatar
McMaster Carr has carriage bolts and they will ship as well.
http://https://www.mcmaster.com/carr...-size~7-16-14/
Hope that will help save you some searching.
1970 1414X Wagoneer "The Pig"
-Dauntless 350 V8
-D27 front/D44 rear
2006 XK (65th Ann Edition)-DD
Old 08-14-2020, 11:45 PM
Also Parts Dude 4x4 has the chrome automotive grade 7/16" Carriage Bolts. Worked well for my J3600 ran into trouble finding stainless or chrome locally aswell
Old 08-15-2020, 06:31 AM
Thank you, I didn't think of Parts Dude. I like dealing with him
'72 J4500
Old 08-17-2020, 03:40 PM
Well, if it ain't one thing it's another
I've driven my truck two days with no problems but this morning was a whole new story.
It looked like it was going to be a good day. The sun was shining, the birds were singing and I was all happy to be going to work because I got to drive my truck
Ok the sun wasn't up yet and there were no birds but I was happy as I started up my truck and began my daily check of the lights and tires. The truck was running good but as I walked around it I smelled a strong smell of gas. I always have a flashlight in my pocket when working so I took it out and shined it under the truck looking for a leak but found none so then I popped the hood and to my surprise saw a spray of fuel running down the exhaust header which was quickly heating up I quickly shut it down and soon took the air filter off to get a better look figuring it was a loose connection or something.
It wasn't a loose connection, the expensive braided stainless steel high pressure fuel line I bought less than a year ago had failed and was spraying fuel all over under the hood
So now I need to get some new fuel line...well sort of.
I was telling someone at work about my problem and as luck would have it he had some 5/16 high pressure fuel line he gave me. It's not 3/8ths as Fitech prefers and I need to get some fittings for it but it should get me back on the road for little expense.
I'm just glad it didn't happen on my way home and cause a fire yesterday.
'72 J4500
nv 4500 1radj20 General FSJ Tech 3 01-04-2017 06:34 PM
401 towing motor? fsj1978 General FSJ Tech 4 10-18-2007 08:14 AM
401 differences Coondawg General FSJ Tech 17 06-17-2007 12:10 PM
Edelbrock Carb tuning at 4500 ft. Will Morris General FSJ Tech 1 05-28-2006 10:54 PM
NV 4500 Elliott General FSJ Tech 20 11-23-2002 03:26 AM
