Old 02-22-2013, 05:59 PM
shockmaster's Avatar
shockmaster shockmaster is offline
4" lift SUA springs used on a SOA setup
I have a set of front 4" lift springs from a spring under 79 Cherokee chief. How much lift will they provide if I put them SOA on my 73' J2000? It is SOA stock.
No matter where you go or what you do, you live your entire life within the confines of your own mind.
1973 J-2000 bone stock DD
1979 Cherokee Chief wheeler Parted out
78' Waggy w/ 60,000 original miles on it
AMC 360 bored .030 over Flat top pistons, Rv cam, Edelbrock performer intake, Holley 650 cfm Double pumper
Old 02-22-2013, 06:05 PM
FSJ_Daniel's Avatar
FSJ_Daniel FSJ_Daniel is offline
Spring over nets you about 5-6 inches add a 4 inch lift you'll be around 8-9 inches but the spring sizes for the 72 are different as they are outboards with different size bushings
73 J-4000 "/Battillac\" 500 Caddy,400/QT w/low, 44 f&r[3,07\'s],35x12.5 BFGoodrich AT's,Auto Meter gauges,TCI trans.cooler,poly fuel tank,Flex-o-lite 7 blade,poly trans mounts,electric cooling fan,straight pipes loud and proud, Front disc conversion, 6" lift, Rancho RS5000 Shocks,Chrome Cragars
63 j-200 "green turd" 230 ohc 3 spd all stock
Old 02-22-2013, 09:51 PM
0" Lift, they won't bolt up.
'79 is box and hanger mount vs. '73 post mount.
Go compare the two, it will be quite obvious.
Old 02-23-2013, 01:56 AM
'73 was the last year of the 2" wide SOA stock LONG front springs.
Old 02-23-2013, 04:42 AM
Gambler68's Avatar
Rabble Rouser
sell em and put the $$ towards a set of post mount 4" lift springs from Hellcreek. You wont be dissapointed.
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 02-24-2013, 01:59 AM
Tigger4X's Avatar
Tigger4X Tigger4X is offline
Unless you are looking for a crazy amount of lift on your '73 just go SOA. If you want less than an SOA gives you then you will either (A) spend a bundle on custom rear springs to achieve all spring lift or (B) you can get front lift springs and use blocks in the rear. I haven't ever searched for lift springs on a '73 so they might not be available. I honestly don't know. What I do know is that you are gonna get some nasty axle wrap with 4" blocks. I won't touch 'em with a ten foot pole and you holding it.
IF I was in your shoes I'd do one of two things, use the Rancho 44044's (2" lift) with a pair of TT Fabworks spring perches that give some lift and 1" lift shackles or skip all that and just go SOA.
Originally Posted by will e
Old 02-24-2013, 07:30 AM
Ignore this post above please.
Your (or any) '73 J200 is already spring over up front.
You are on 2" wide springs mounted on posts off the side of the frame.
44044's will not fit the front of a '73 JTruck, they will not fit the rear either.
If you would like to study up on spring lengths, widths and bushing sizes please refer to this post from Tom at Hellcreek.
http://www.ifsja.org/forums/vb/showp...15&postcount=2
HellCreek does make a 4" all spring lift for the '63-'73 JTrucks, BJ's carries the same kit.
Old 02-24-2013, 10:17 AM
Tigger4X's Avatar
Thanks for the correction TAD. Didn't know the earlier style was already SOA. :emb:
It would sure save a bunch of work, etc. IF the newer stuff was this way too.
lift or oem replacement springs?? Crazy4Wheelin Off-Road FSJ Tech 13 12-30-2011 08:18 PM
springs, body lift, and tire rub.... 44BZ General FSJ Tech 8 03-10-2010 11:36 AM
4" Lift with blocks vs all springs Sian09 General FSJ Tech 18 03-11-2009 11:44 AM
SOA with lift springs? cajun_lad Off-Road FSJ Tech 22 06-28-2007 07:46 AM
4" lift OR SOA ??? 20ozJolt Off-Road FSJ Tech 16 02-27-2005 05:35 AM
