Old 01-20-2013, 08:34 PM
80widelarado's Avatar
80widelarado 80widelarado is offline
popping noise
ok I did a quick search and didnt see anything. My question is when I turn left or right it doesnt matter I get one pop its hard enough i can feel it in the floor board and I cant see anything wrong right off the bat does anyone have any clue what it could be? I'm scared it could ba as bad as the steering box cracking the frame but I'm just not sure. Do any of y'all have any ideas, or has anybody heard of this before and knows what it is?
Old 01-20-2013, 08:52 PM
Retro93's Avatar
Retro93 Retro93 is offline
Junk Collector
Check the rear hangers on the front springs. They have one rivet and a little Mickey Mouse welding holding them in place. Over time the welds break, leaving the rivet to hold things together. Mine were both loose. When I had them welded up....no more popping.
Old 01-20-2013, 08:59 PM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
What Retro said, and check your upper and lower ball joints too.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 01-20-2013, 09:02 PM
how do you check ball joints?
Old 01-21-2013, 06:35 AM
Oakknoll's Avatar
Oakknoll Oakknoll is offline
I was thinking ball joint too. Jack up the truck so the front tire is about 4" off the ground and slide a 3' piece of pipe under the tire. 6" of pipe go under the tire and you lift up on the other 2 1/2'. You should feel no free movement in the tire/wheel assembly. You should only be lifting on the susspension. If there is movement you need to replace your ball joints.
Peter
1984 J-10
1982 CJ-8
1982 Wagoneer
2007 Commander
2012 Wrangler
1980 Cherokee (for parts)
Old 01-21-2013, 07:54 AM
on my '77 it's the spring/shackle bushings. rubber is gone,and they slide back and forth in the shackle when i turn corners.
popping noise / front u-joints danjohnson67 General FSJ Tech 1 12-08-2009 07:35 AM
Popping noise when turning KaiserMan General FSJ Tech 18 07-13-2007 07:30 AM
popping noise Big Blue Off-Road FSJ Tech 21 04-07-2006 04:55 AM
popping noise?!?!?! ThE_hOsS General FSJ Tech 7 06-15-2003 02:37 PM
Torque induced popping noise jode General FSJ Tech 1 04-09-2002 05:21 PM
