Old 12-26-2012, 04:28 PM
JP's Avatar
JP JP is offline
Where horseshoes are not a game
Fuel is leaking somewhere.... : )
ok, so I have a very strong unburned fuel smell coming from somewhere on the cherokee. Its present all the time and I can smell a mild fuel odor inside the cab even when Its just sitting parked. The main blast of the fumes comes when accelerating. No matter which gear but if you are applying the accelerator it starts smelling like fuel. Especially upon heavy acceleration.
It runs and drives fine and the carb doesnt seem to be the culprit. Not rich....or at least I dont think it is.
Some current variables to consider are:
1. access cap above fuel sender unit is missing and open. Seems like it shoudnt be reaking of fuel whether open or closed but thought It should be mentioned...
2. exhaust has small leak in seem immediatly before the CAT. I wrapped it with muffler tape to see if I was just getting fumes from that and its mildly improved but still very strong.
Its a 258I6 with the 5 speed.....motorcraft 2100 carb.
Any advice is appriciated....
Jon P.
Cherokee Resto thread:
http://www.ifsja.org/forums/vb/showthread.php?t=162358
Old 12-26-2012, 08:38 PM
bg2pres's Avatar
bg2pres bg2pres is offline
If there is no miss in the acceleration, then its either the feedback line from the fuel filter back to the tank, OR the tank itself....
bg2pres
1979 Jeep Cherokee Golden Eagle
1990 Jeep Grand Wagoneer
2012 Jeep Wrangler Unlimited
1981 Jeep Scrambler Laredo CJ8 (sold)
2000 Jeep Wrangle TJ Sahara (sold)
Old 12-26-2012, 09:23 PM
CJ5 CJ5 is offline
Inspect the venting thingies, they have a tendency to leak when the seal gets old. It could be sloshing around on acceleration and causing the fuel to leak there. There are two of them.
Chief Laredo Build Album:http://www.fototime.com/inv/BB4AF31A10748CC
'72CJ - Complete Restore
'81SJ - Loredo Resto Project
'91YJ - Rock Crawler
Old 12-26-2012, 09:52 PM
JP's Avatar
JP JP is offline
Thanks Gentleman
I will check the feedback line tomorrow afternoon. Will I be able to find its location in the haynes manual?
as for the "Vent Thingy's" , perhaps a little more specifc if possible.
Location of said vent thingys?
Thanks
Jp
THIS RESTORATION WILL BE THE MOST DIFFICULT AND EXPENSIVE THING I HAVE EVER ATTEMPTED TO ACCOMPLISH HONEY, I SWEAR!!!
83 Cherokee
resto thread:
Old 12-26-2012, 09:58 PM
CJ5 CJ5 is offline
Thanks
Jp
LOL
The "rollover check valves" are located on the top of tank. One in the front middle on in the rear middle. The both should have hoses that attach to them and run towards the front and join into metal tubes that run along the tranny and up the back of the motor. Fron there they transition back to rubber hose and go to the vapor canister.
Old 12-26-2012, 10:04 PM
JP's Avatar
JP JP is offline
oh! those vent thingys
lol,
can I view/inspect these without dropping the tank?
83 Cherokee
resto thread:
Old 12-26-2012, 10:24 PM
Look for wet spots (if it's not raining there) along the frame. Is the charcoal cannister hooked up? Leaky accel pump on carb? (pump the throttle while looking at the carb. Motor off, but still warm)
Old 12-27-2012, 01:59 AM
svining's Avatar
svining svining is offline
Talking The access cap...
They sell new plastic securing bolts for the sender access cap. There is also an O-ring there. If that is not really..really tight you will get a lot of gas smell.
The Charcoal cannister must be setup to vacuum to rid the filter of excess fuel vapor in the cannister. Mine is off and plugged, but just the vented cap on the gas tank in an enclosed garage will give fuel odor. I am going to put some type of cannister back on mine for just that problem.
Flashlight
"I started with nothing, I still got most of it left"
1982 GW,Stock, No Emissions Equip.
Mallory HEI, AMC 360, Motorcraft 2150
Old 12-27-2012, 07:52 PM
JP's Avatar
JP JP is offline
sorry I am slacking
Instead of running the feedback line for leaks this evening , I went to rocklaurence's shop. Wow, my shirt is still wet from the drool. Shelves of parts, powertrain, interior , and two cool J-Truck's. Ones a stepside! plus I found some visors! Score...
If you haven't utilized his services yet I highly recommend it.
Here's a link to his info. - http://www.ifsja.org/forums/vb/member.php?u=21082
Anyway, I appreciate the advice and will get the trouble shooting started Sat morn.
Thanks,
Jon p.
83 Cherokee
resto thread:
Old 12-28-2012, 04:48 PM
CROCKETTBOONE's Avatar
CROCKETTBOONE CROCKETTBOONE is offline
If you are running a mechanical fuel pump that may be the problem.
An opinion is just that, an opinion. A fact is a fact, and thought to be true. Please dont confuse an opinion with a fact. Life: Its sexually transmitted and always Fatal.
Old 12-28-2012, 07:05 PM
ajminla ajminla is offline
X2 rollover check valves
Try parking on downhill. If your valves are leaking you will find out soon enough.
Get them checked soon as.
'89 Grand Wagoneer
Black with Sand Interior
"The Other Woman"
Old 12-28-2012, 07:43 PM
Jon, great to have you stop by. The fuel return line if not capped could be venting or leaking charcoal canister lines could cause the fumes. BTW, its rocklaurence Vintage Auto Parts12. That's why you couldn't find it.
Old 12-29-2012, 09:53 AM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
I suspect your biggest leak is at the front of the vehicle.
However, you've gotten good advice
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 12-29-2012, 09:38 PM
JP's Avatar
JP JP is offline
Trouble shooting completed
So I followed the advice of the board, and did the fuel odor troubleshoot this afternoon. I’ve taken some photos of the different points of inspection and of the odors perpetrator.
First I checked the fuel filter and its return fuel connection. The photo shows the Y on the carburetor side of the filter and both these hoses appeared to be in decent condition. No leaks or odors were detected either at the idle or during engine acceleration. The fuel return line runs down into a second rubber hose and it was solid as well. From there it runs as a steel line into a central fuel line gathering point attached to the frame, and from there back along the frame and up above the fuel tank itself. None of these connections were wet or leaking so the mystery persisted.
While inspecting the engine compartment I noticed that there were zero fuel odors in that area, but while there were no leaks detected, the cabin of the truck was steadily getting saturated with fuel odor. At this point I decided to remove the rear seat and inspect the access panel area. I was already aware of the absence of the cover to this panel but was surprised at what I discovered upon removal of the seat and carpet.
The fuel sending unit had been repaired/replaced? By the PO, however it was here inside the access panel that I discovered the source of the leaking fumes. The photos show the two fuel lines entering the tank and an unknown rubber plug or seal just under the lip of the access panel. Two of the three connections we not secured. One of the fuel lines moves in and out of the tank, and the unknown plug is pushed up and will not seal. The white goop was apparently an attempt to close these openings ,but it had failed.  When the engine is running and even more so upon acceleration the access panel actually blows a breeze of fuel fumes out of the panel. Most of the flow comes from the rear plug but the entire unit looks wore and faulty.
So….I believe I am correct in assuming that the tank will need to be dropped in order to repair this area and I feel like if I’m going to drop a 30 year old fuel tank I might as well put one of the replacement options from BJ’s offoad back in its place. (Who knows what kind of crap is developed inside the original tank). A replacement sending unit seems to be in order as well. If the pieces shown in the photo will not be included with either of those two replacements what other parts should I order?
I ask the boards advice for this next step…
So…. Mystery solved but still one issue other than the tank left and that’s the fuel access panel cover. Since I have to order the rest I figured I would fabricate a new cover so it is at least sealed off from the inside and might be slightly more tolerable until the replacements are ordered and installed.
I have included photos of this process. Not an overly complicated project but still a Saturday evenings worth of fun. I used stuff that I had in my work rig for shoeing horses so laugh away at the crossover of supplies. If anyone else is missing theirs here’s what I did….
Rather than post these pic here I put them in the main resto thread so as not to double up. Please check out the photos and process there.
heres the link.
83 Cherokee
resto thread:
Old 12-29-2012, 11:05 PM
bg2pres's Avatar
Go get a 40 gallon aero fuel tank... Best investment ever! Keep original tank to put back when needed...... Aerotanks.com
bg2pres
Old 12-30-2012, 07:14 PM
Jon, I have several poly tanks; an '80 Cherokee, 89 Wagoneer. Both have holes where I drained them but maybe you can find something to repair yours. Or an 86 with no holes. I also have the tank mount/skids in like new condition.
Motorcraft 4350 fuel inlet leaking Etcetera General FSJ Tech 2 11-28-2010 11:42 PM
69 Waggy Stalls When Warm kodyharrell General FSJ Tech 11 09-30-2009 11:07 AM
fuel pump stalling issues westcoastflea General FSJ Tech 8 07-21-2009 08:40 AM
Leaking Fuel, Won't Idle 480volt General FSJ Tech 2 05-09-2008 04:13 AM
Wagoneer fuel leaking through vapor canister Tzummie General FSJ Tech 12 08-16-2007 03:27 AM
