Old 12-09-2012, 08:52 PM
nc wagoneer's Avatar
nc wagoneer nc wagoneer is offline
Is this a t15?
So, the j20 I just bought shows up with a t15 as stock. The trans was swapped out with one from a jxxxx custom and I wanted to see if I could verify its a t15. Has data plates worn off on trans and no shifter knob. Feels like 3 gears plus reverse but the clutch is 100% gone ski can't tell. It feels like there is only 4 gates total. Thanks
Sorry, was using my dads phone due to the low light and it takes smaller pictures than mine.
"BROWED AND PROUD"
Old 12-09-2012, 09:13 PM
Hard to see in your pic, but yes.
13-07 or T15 will be cast in to the side of the case. There is a tag from the factory - you can see it in your picture. Try harder to read it.
Old 12-09-2012, 09:17 PM
Dumpy's Avatar
Dumpy Dumpy is offline
Sure looks like it. Good, tough 3 speed
Justin
'72 J2000 360 4bbl T18 D20
Old 12-09-2012, 09:53 PM
I knew about the tag, I looked at it first but everything is worn off Good to know though. I may switch to a t18 in the future just wanting to know for now
"BROWED AND PROUD"
Old 12-09-2012, 11:45 PM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
As far as 3 speeds go, the T-15 is the one to have. I got many good years of service out of mine, lots of miles on it.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 12-10-2012, 06:38 AM
Originally Posted by nc wagoneer
I knew about the tag, I looked at it first but everything is worn off ...
Can't wear off. The numbers are stamped into the metal.
Take it off, clean it and read it.
