Old 02-01-2013, 02:40 PM
mdill's Avatar
mdill mdill is offline
Gone. Not Forgotten.
The 258/360/4.0 all had the same bolt pattern/crank offset, crank bolt pattern ... Bolt up deal (there are a couple that might need work (~10:00 and 2:00 o-clock bolts, not used on the I-6 but are on the V8)
Originally Posted by msh227
I know this is an older thread....... but did I miss how you connected the bellhousing to the engine? Does the AX15 bellhousing bolt right to the 360 or did you have to make your own adaptor?
Thanks
Home of ADHD project list
1977 J-10 Honcho 360-T15-D20
Old 02-01-2013, 03:25 PM
Jeepguy77's Avatar
Jeepguy77 Jeepguy77 is offline
You only need an adapter for the tcase. If you go with an NP231 you don't need it. But other NP cases and dana 300 cases need a spacer plate. I found that you can bolt a dana 20 to it with an adapter. Advance has them cheaper than Novak.
Pierce,
77 J10 454, TH400, D20,
Old 02-01-2013, 03:42 PM
mdill's Avatar
There is the wierd ~7/8" that pops up depending on what Jeep case to what tranny you are swaping. (I think Novak has the data on what needs it what does not )
Old 02-01-2013, 05:12 PM
When I test fit the NP208 and NP229 I had to an AX-15 and AW4 ('91 up for 23 spline) the spacer ring was 15/16" thick. Thinner than that and it would bind up the trans and/or tcase.
Old 02-02-2013, 06:25 AM
awesome picture!
Old 02-02-2013, 08:31 AM
MtnYJ MtnYJ is offline
Thanks
The others summed it up pretty well. No adapter was needed on the engine/transmission side. It's been a while, I don't recall exactly which bolt, but one of the stock bellhousing to block bolts from the Waggy was too long to use with the AX-15; difference in thickness of the 727 and AX-15 bell housing castings in that area I believe.
Flint re-posted the picture of the only "adapter" required on that side!
Tim & Sarah
'84 CJ-7, AMC 401
'76 J20, T-18, Dana 20, no floors
'91 GW, AMC 360, AX-15, NP 208, 178K Mi
Rear bumper w/swing-out tire carrier
'93 YJ, 4.0L, 5-SP, flipped Dana 300, Dana 44s
'14 Ram 3500 4x4 CTD
Carolina Full Size Jeep Club President http://www.cfsjc.com
Old 02-03-2013, 09:02 AM
81cherokee laredo's Avatar
81cherokee laredo 81cherokee laredo is offline
Awesome write up someone needs to add this to the archives
Dan
81 Cherokee Laredo- 360 727 NP219 SOA/SF 35 Coopers 4.56 Gears
83 Cherokee - Katy- long term project
89 Grand Wagoneer- 360 727 NP229 31x10.50's on slot rims
Old 02-03-2013, 10:33 AM
Thanks for the writeup.
46 cj2a
51 Willys p/u
'51 Willys Parkway Conversion
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
Old 02-03-2013, 01:33 PM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
Should be the same between the 4.0 and the 360.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 12-08-2015, 12:23 PM
Jonathan M.'s Avatar
Jonathan M. Jonathan M. is offline
Update?
MtnYJ, Hey there, I was looking to do the same swap on my 83 Wagoneer. I have heard both good and bad things about the AX 15 I was just wondering how the swap has gone for you? Have you had any failures or other problems related to the swap?
Jon M.
83 Wagoneer Limited,LQ4 Z06 6.0L,AX-15,NP 208
07 Liberty, 3.7, NSG370, NV 231
Old 12-11-2015, 11:36 PM
Same pattern but different flywheel balance.
Old 11-05-2017, 10:13 AM
Pillow Pillow is offline
Like! I just pulled the manual pedal set from the 73 J4000 to use on the 83 Cherokee. Let's see how that goes.
It looks like a factory hydraulic master exists from 79 on... Hopefully the old and new work together
Thanks for the write-up!
1983 Cherokee Pioneer - in progress LS 5.3 w LS9 cam, NP208, & SM465
1968 J2000 Gladiator truck
1973 J4000 truck (organ donor for Cherokee & J2000)
1971 C-10 w 5.3 LS swap
1979 Porsche 911SC
Daily: 2007 Cadillac DTS
Old 11-09-2017, 01:58 PM
I've got an AX15 in my 81 Cherokee with hydraulic TO bearing lever.
Old 11-09-2017, 06:48 PM
j10jim's Avatar
j10jim j10jim is offline
since we are reviving the old thread, I would like to discuss the tcase shifter and such. I have a 208 behind my 727 and really want to move away from the flag shifter to one like you have. What shifter did you use and what other details can you share?
thanks
1980 J-10<br />Rusty\'s 4 inch lift<br />2 inch body lift,<br />35 in Xterrains on J20 axles<br />4:30 gears<br />Detroits<br />In-Cab cage thru the dash
Old 11-09-2017, 09:05 PM
acct21's Avatar
acct21 acct21 is offline
OP hasn't posted anywhere on the site in over 2 years. I would not recommend holding up your build until he does!
He did mention in one of the earlier posts in the thread that the linkage was recycled 727 shifter linkage. The shifter looks like any bog-standard straight shot floor shifter. You could really use any straight shot (or dog-leg) 208 shifter (or a universal, for that matter), just as long as you know the shift pattern on the 208 (assuming the shift pattern doesn't match what is written on the ball).
This is the Chevy shifter they used for decades. It has a dogleg/"z" gate plate, but only the handle pivots -- the linkage beneath just goes back and forth.
Old 11-09-2017, 09:36 PM
bwwhaler's Avatar
bwwhaler bwwhaler is offline
I can get in touch with him and let him know you have questions about it...
87 GW 360 performer intake Holley 670 HEI
Razor Grill 4"BJ's springs 32's CS-144 Serehill's light and tailgate harness
Old 11-09-2017, 09:56 PM
j10jim's Avatar
ACCT21 thanks for the info. I may have to go that route.
bwwhaler if you could that would be great.
Thanks guys!
Old 11-10-2017, 10:29 PM
thanks
Hi there fellas, it's been a while since I visited here! As far as the shifter goes, if I remember correctly I used the shifter out of the same J truck that donated the NP-208. I don't recall it even being as complex as acct21's pictures - I'm pretty sure I just used the pivot point that bolts to the floor. That pivot holds a simple t-case shifter rod, then the bottom end is connected to the modified 727 linkage pieces. I know that's still not a ton of detail, but it is pretty simple linkage, and works extremely well. There's no binding at all, I can pretty much shift into/out of 4WD with one finger.
We drove the Waggy nearly everyday until Fall 2015, when we lost a head gasket. The transmission swap never gave us a minute worth of trouble. We parked it and decided to build the wife a CJ. The Waggy is the next project, and will be getting an LS, NV-4500, and Dana 300.
Tim & Sarah
'84 CJ-7, AMC 401
Old 11-11-2017, 02:58 PM
Approved
1979 Porsche 911SC
Old 11-12-2017, 10:42 PM
Rod2's Avatar
Rod2 Rod2 is online now
I want your 5th over gear to put in my T-18; of course I want you to do the engineering and the mechanicals.
Rod Skaggs
'73 J4000 'WOOD GO' 360, 2100 MC, T-18, D-20, 60-2 rear, D-44 closed knuckle front with Warn Lock-O-Matics, Eaton E-lockers both, Pertronix module, AC, PS, '77 Firebird tilt column, Hydro-boost, AirLift bags front and rear, 33x15 Goodyear MTR's, Pacer 15x8 aluminum Bullet Holes, Summit line lock, 3rd brake light, MileMarker 12,000 cradle mounted winch
weirdest auto transmission issue on 727 sportsidedan General FSJ Tech 7 10-11-2010 12:42 AM
'91 GW overdrive automatic transmission swap Greg Clark General FSJ Tech 4 07-22-2005 08:20 AM
727 Transmission Noise Kevin718 General FSJ Tech 4 01-25-2004 03:10 PM
AMC/Jeep Manual Transmission Info James 007 General FSJ Tech 0 09-02-2002 07:40 AM
