  #2901
Old 11-15-2012, 11:01 AM
Parked it back in the garage (hopefully) out of the way of the idiots who have been driving through my place with mud on their plates. Next time they will get a 5 ton surprise blocking their exit except one. My neighbor with the shot gun!
We're on (posted) private property on a private road so this crap isn't going to fly. They banged into and nearly bent my well head!
Old 11-15-2012, 12:08 PM
bruner1981jpce's Avatar
bruner1981jpce bruner1981jpce is offline
Greet em' with a bunch of shotguns and big rifles next time they come anywhere near you! It's your property, protect it. Act a little drunk and/or crazy when you meet them face to face. Not many things could be scarier to someone than the shotgun-wielding drunk/crazy property owner of the property they're trespassing on. Maybe spraypaint signs on a few pieces of wood and nail them up around the property. I'm having way too much fun with this. Best of luck, hope you catch those trespassers!
Andy
'81 Cherokee Laredo W/T 258/Weber 32/36 DGEV/HEI/176/208 AMC 20/Dana 44 3.31 gears
Status: Storage Miles: Less than 140K (as of the talk with the original/previous owner) "The Jeffrey"
Build Thread: http://www.ifsja.org/forums/vb/showthread.php?t=151814 New pics: 5/18/12
Old 11-15-2012, 12:49 PM
Mars's Avatar
Mars Mars is offline
Originally Posted by 69 FSJ
After a little pulling from my dads GMC, a big come-a-long, and about 40 feet of chain, the 69 made it into the barn for winter. Now all I need is the money for non-cracked heads and a full re-build before she can run again. Anybody feel like donating a set of Buick 350 heads to a broke college student?
I may have a set, actually I have a whole engine, if it's not been scrapped yet. came out of a mid 60's skylark.
Wannabe Fabricator
Grumpy on a good day.
Old 11-15-2012, 03:19 PM
blkwarrior's Avatar
blkwarrior blkwarrior is offline
I would put up spike strips (on your property) . That will surely teach them to trespass.
1984 GW
360/727/208/ Edl 1406/ Custom exhaust
Future
Something Sweet with mean capabilities .
Old 11-16-2012, 01:20 AM
The 5 ton is parked in the back driveway now. They can't go down the hill backwards in one piece, so it'll be interesting to see what happens next.
Just my luck I'd forget and drive over them myself.
Old 11-16-2012, 11:33 PM
Rod2's Avatar
Rod2 Rod2 is offline
Put a new heater core in. Auto Zone--$40 + change.
Reattached the battery ground from batt to inner fender lug.
Rod Skaggs
'73 J4000 'WOOD GO' 360, 2100 MC, T-18, D-20, 60-2 rear, D-44 closed knuckle front, Eaton E-lockers both, Pertronix module, AC, PS, '77 Firebird tilt column, Hydro-boost, AirLift bags front and rear, 33x15 Goodyear MTR's, Pacer 15x8 aluminum Bullet Holes, Summit line lock, 3rd brake light, MileMarker 12,000 cradle mounted winch
Old 11-25-2012, 07:54 PM
sXeMike's Avatar
sXeMike sXeMike is offline
Replaced the gas tank. There wasn't really anything wrong with the old one except a couple of leaking gaskets but I had a new one so I replaced it anyway.
Changed the electric choke to manual. (I hate electric chokes)
Installed BJ's 1" lift shackles in the front.
Old 11-25-2012, 07:57 PM
I got the Willys....
Pulled the motor out, tore it apart and decided not to put it back together.
1971 Gladiator
Old 11-25-2012, 08:06 PM
80widelarado's Avatar
80widelarado 80widelarado is offline
got it dirty and stuck, got pulled out washed it then for got the key on and killed my battery.
Old 11-26-2012, 03:00 AM
Jagged's Avatar
Jagged Jagged is offline
Got my trucks a sibling. Now I have to decide what to do with the rust buckets.
Bunch of Jeeps, lots of issues.
Old 11-26-2012, 04:50 PM
Showngo's Avatar
Showngo Showngo is offline
Fixed a fuel leak,hopefylly fixed an antifreeze leak,repaired cracked Great GoogleyMoogely Edelbrock header for the second time,Did the XJ lower steering shaft upgrade,replaced drivers rear wheel cylinder again,2nd time in 1-1/2 years,and that's it.
90 Wagoneer w/65 Wag.grille,Cj7 lights,360 AMC w/edelbrock perf.cam,lifters,timing chain,intake,carb,and,headers,custom SS exhaust w/magnaflow muffler,Black cherry pearl w/cordovan interior.Rusty's 4" lift w/KMC revolver bronze 17 x 9 wheels ,& Toyo MT 295-70-17 tires(33").http://s220.photobucket.com/albums/d...nd%20Wagoneer/
Old 11-26-2012, 07:01 PM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
Rebuilt the GWs front drive shaft. Don't know how long the u-joints I took out were there, but I know that's where they wanted to stay!
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 11-27-2012, 07:35 AM
The Arizona Tour, 1160 miles of fun!
Old 12-16-2012, 06:25 PM
Mr. Goatman's Avatar
Mr. Goatman Mr. Goatman is offline
Put the front axle back in with SOA. YEAH!!! She is back on 4 tires. Pulled NP 229- installed NP 208. Put on J- truck e-brake cable to rear. Found rear brakes are.. eh.. needing help. Might be time for disk? Got most of the front removed for Rhino conversion. Removed stock roof rack. Now I just need brakes, tierod, drag link, drive shafts, shocks, fuel tank installed, many other things....O' my.
Remember; When it comes to tools and toys forgiveness is ALWAYS easier than permission!
Old 12-23-2012, 08:55 PM
GaWag's Avatar
GaWag GaWag is offline
Replaced the valve cover gaskets. Plugged a vacuum leak at the vacuum ball on the firewall. That really settled down the motor. Adjusted the Carb and idle settings. All of a sudden the transmission governor/modulator works. The tyranny now kicks down like it should and scoots! Replaced the muffler with one I had in the shop. It had some holes in it.
Above all, had 2 great days wrenching with my dad. I miss working in the shop with him since I moved to Birmingham.
Steve Powers
www.Bluetorchfab.com
www.Alternatefuel.com
Old 12-23-2012, 09:19 PM
jeffs396's Avatar
jeffs396 jeffs396 is offline
Had to stick it outside for the weekend...
possibly the first time this desert Jeep has ever had snow on it!
Jeff S.
Current 1:1 Jeep(s):
1974 J20...original 401, NP205, TH400, D60, HD44
Lots and lots of scale Jeeps
Old 12-23-2012, 09:42 PM
blkwarrior's Avatar
Drove it like I stole it!
1984 GW
Future
Old 12-24-2012, 07:22 PM
steven79's Avatar
steven79 steven79 is offline
Put a radio and speakers in Thor, now Lenny the motor home it tune less.
Thor - 79 wag ltd <br />366,th400,Q trac d44 f/r 3.54<br />31x10.50x15 Good year at's
I am not a dad,I am a domestic dictator
Old 12-25-2012, 06:23 PM
PNW79J10's Avatar
PNW79J10 PNW79J10 is offline
I got my new toy Got it in the shop and on 4 floor jacks, rear wheels and brakes off. but had to go back to new jersey... new updates in 3 weeks
1979 J10 short-bed
360,D44's 3.54,T18, D20
1963 J200 Step-side ~ new project
Photobucket account: http://s1142.beta.photobucket.com/us...uture%20wishes
