the bearing at the bottom of my 76 Cherokee steering column has completely come apart. I only see the inner race on the shaft in the eng compartment. its flopping around.the column is a non tilt and in excellent shape otherwise.is this going to be a very hard fix?
how hard is this going to be? steering column
mark<br />76 cherokee chief<br />chevy 502 t-400 np-205<br />dana 60 front corp 14 bolt rear<br />fiberglass fenders and quarters<br />(ABOVE THE LAW)(AND UNDER CONSTRUCTION)<br /> http://<br />[URL=http://www.fsjworl...91;/URL]<br />Tags: None
If it's just the bottom bearings, shouldn't be too hard. Search the technical forum and go to Tom Collins Ol' Jeep to get the steering column tech sheet. Should be a clip, nylon bushing and bearings on the bottom end.
Good luck.79 Cherokee S (current project)
Originally posted by markthe bearing at the bottom of my 76 Cherokee steering column has completely come apart. I only see the inner race on the shaft in the eng compartment. its flopping around.the column is a non tilt and in excellent shape otherwise.is this going to be a very hard fix?Ken's:
1966 Super Wagoneer
5.7L 2BBl. Th700R4. NP-208. Opens. 3.31s. 4core. 4Discs. PS,PB,AC,CC,Cassette.
(Soon to be TBI)
is it the same as any gm era column?mark<br />76 cherokee chief<br />chevy 502 t-400 np-205<br />dana 60 front corp 14 bolt rear<br />fiberglass fenders and quarters<br />(ABOVE THE LAW)(AND UNDER CONSTRUCTION)<br /> http://<br />[URL=http://www.fsjworl...91;/URL]<br />
Originally posted by markis it the same as any gm era column?Ken's:
1966 Super Wagoneer
(Soon to be TBI)
yes .just the bearing.can I just pull the end from a chevy column?mark<br />76 cherokee chief<br />chevy 502 t-400 np-205<br />dana 60 front corp 14 bolt rear<br />fiberglass fenders and quarters<br />(ABOVE THE LAW)(AND UNDER CONSTRUCTION)<br /> http://<br />[URL=http://www.fsjworl...91;/URL]<br />
I have one from my 75 I got from crown.
if ya want I can send it to you..(don't need it)
PM me an address.Ken's:
1966 Super Wagoneer
(Soon to be TBI)
pm sent........thanks kenmark<br />76 cherokee chief<br />chevy 502 t-400 np-205<br />dana 60 front corp 14 bolt rear<br />fiberglass fenders and quarters<br />(ABOVE THE LAW)(AND UNDER CONSTRUCTION)<br /> http://<br />[URL=http://www.fsjworl...91;/URL]<br />
thanks ken, got it yesterday and im gona try to put it in today.
im a little confused though ....does the bearing push into the plastic pc?
do I do this before I install it on the shaft?mark<br />76 cherokee chief<br />chevy 502 t-400 np-205<br />dana 60 front corp 14 bolt rear<br />fiberglass fenders and quarters<br />(ABOVE THE LAW)(AND UNDER CONSTRUCTION)<br /> http://<br />[URL=http://www.fsjworl...91;/URL]<br />
thanks! the bearing is perfect.
my old one is sliding up and down the shaft so its not frozen on the shaft at all.i took the nut off of the clamp that couples the upper part of the steering shaft to the bottom of the column but that bolt needs to be removed completely I guess.i was pounding on it with a punch and a hammer so hard that I thought I might damage something in the column so I stopped for now.
im gona try an air chisel on the bolt next time I get to it again.
there is not much room in this area with the bb chevy and the headers.mark<br />76 cherokee chief<br />chevy 502 t-400 np-205<br />dana 60 front corp 14 bolt rear<br />fiberglass fenders and quarters<br />(ABOVE THE LAW)(AND UNDER CONSTRUCTION)<br /> http://<br />[URL=http://www.fsjworl...91;/URL]<br />
yea that bolt has to come off complete for the u joint to be removed.
then pull the retaining clip and remove bearing.Ken's:
1966 Super Wagoneer
(Soon to be TBI)
