Old 07-14-2019, 12:01 PM
Overland_az's Avatar
Overland_az Overland_az is offline
350 SBC emissions
Just picked up an 88 Grand Wagoneer with a Mr. Goodwrench 350 sbc crate engine swap. Originally had a 360...Vehicle came from northern az and didn't require emission testing up there. The area I'm at does require emission. Not sure what emissions stuff goes with a crate engine. Do I just throw a cat on it and call it a day? Or is it more in depth? Noob here lol
Old 07-14-2019, 12:23 PM
You're going to have to get "official" info from the the local county/state agency requiring your smog tests. Regardless of what the internet says, "they" are the ones that will allow or kill a non-factory motor swap.
Old 07-14-2019, 12:31 PM
I know that engine swaps have to be the same year or newer and you must carry over the emissions from the donor vehicle. This being a crate engine I'm not sure what emissions it should have but I guess I could ask a shop or the local agency for clarification.
Old 07-14-2019, 12:38 PM
tread carefully rumor has it certain inspections will get it blacklisted in AZ and you won't be able to register it.
easiest would be like an 88 gm tbi engine.
not sure but suspect a carburetor won't fly?
Old 07-14-2019, 06:46 PM
Interesting... even thought the original 360 was carb. You think a 350 carb will bean issue?
Old 07-14-2019, 07:24 PM
No 1988(or newer) GM 350 had a carb AFAIK.
If they are following EPA regs engine has to be 1988 or newer and whatever emissions replacement came with would need to match.
Telling them it's a "crate" engine may not be a good idea?
Old 07-14-2019, 07:43 PM
Oh gotcha. Yeah I'm gonna take it to local shop that got my 73 J4000 to pass emissions and see what they say. I just want to get the registration and title in my name. Then the build can start.
Old 07-16-2019, 11:24 AM
In California, you can transfer title w/o a smog check but you can't register w/o a smog check. We are able to set it in a "Planned Non-Operation" status that basically hit's pause on the registration. Maybe you can do that too?
Old 07-16-2019, 02:11 PM
I was reading over the Arizona revised statues and title transfer w/o registration is an option though hardly ever done. I'm taking it to a shop next week to see how in depth I'd have to go to get it through emissions. From there I'll determine which route I'm gonna go.
Old 07-16-2019, 11:19 PM
Crankyolman's Avatar
Man, I feel sorry for you guys in states that require all that BS. I'm so glad I don't have to go through it.
'72 J4500
Old 07-24-2019, 03:45 PM
It really depends on the state - you should look into the laws for your state. In Portland they just check to make sure you have a cat with an undercar mirror and do a sniffer test, they don't even pop the hood.
1984 GW
360
Comp 260H
Magnum Roller Rockers
Wiseco -21cc Forged Pistons
Performer Intake
Holley SA 670
MSD 8523
Dakota Digital custom cluster
Serehill headlamp harness
NWMP aux tank
1987 GW deceased
...but the parts live on
Opinions needed on emissions questions...Denver area Strode General FSJ Tech 26 12-22-2011 02:01 PM
Wooooo!!!!! Almost passed emissions! Dr. Marneaus General FSJ Tech 25 08-26-2011 07:04 PM
Trouble Passing Emissions AND? BrianAg95 General FSJ Tech 12 05-11-2009 01:49 PM
Emissions equipment on GW - same all years? Scramblin_Jim General FSJ Discussion 3 04-21-2007 07:12 PM
Emissions? Laws? Mike Z General FSJ Tech 7 01-13-2001 11:39 AM
