Old 07-01-2019, 11:04 AM
Driftwood's Avatar
Tailgate electrical/mechanical repair
My tailgate needed serious maintenance.
I gutted it of all electrical wiring, mechanical parts, glass, inner & outer wipes, Tailgate Glass Side Channels, and outer tailgate key switch.
I ordered and installed new;
Tailgate Window Lift Pins with Upgraded Clip Design
Tailgate Window Lifter Seal
Tailgate Wipe Inner
Through time I squirreled parts which included;
Lift mechanism w/electric motor
Tailgate Wipe Outer
Tailgate wiring harness
Inner tailgate key switch
Cutoff switch
I also bought a Window Wipe (Window Belt) Molding Removal Tool.
I considered doing the tailgate wiring upgrade. But I strive to keep things stock to keep costs down.
Here are some pics of the work I've completed so far.
The following pic shows my stock lift mechanism.
The one below it I salvaged. It had a nice motor as well as both springs and spring cups on the pins.
The lift pins were toast. And the PO had removed the factory spring and spring cup from this pin.
Also, this pin was missing its retainer clip. Instead, the PO had tack welded a flat washer onto the end of the pin. I had to grind it off so I could remove the window lift channel from it.
The next five pics detail the removal of the guide pin. It is pressed in place. DO NOT GRIND OFF TO MUCH ARM MATERIAL. Or else you will have to install a lock washer with the new lift pins.
Keep the Spring and spring cup. Do not discard.
Old 07-01-2019, 11:09 AM
Driftwood's Avatar
The following pics are of the installation of the new lift pins, springs and spring cups.
Old 07-01-2019, 11:12 AM
Driftwood's Avatar
I installed new Inner Tailgate Wipes. My old ones were devoid of all felt. They are kept in place with two screw and washers. Save your old ones. Do not discard them. If you do, off you go to the junk yard to source replacements.
Old 07-01-2019, 12:56 PM
SJTD SJTD is offline
Take a look at Post #43: http://ifsja.org/forums/vb/showthrea...=164564&page=3
You should open up that lift motor. Might look like mine.
Sic friatur crustulum
Old 07-01-2019, 03:54 PM
lkmarsh's Avatar
lkmarsh lkmarsh is offline
Wow. Just Wow.
Some of the best photography I've seen in a tech write-up. Who's your parts source?
Converted two of my three tailgates to relays to protect the stock switches.
The Impala gets the treatment next week, using a factory reversing relay.
The Jeep tailgate switch is easier to find than the Chevy item, and much cheaper. For now.
Lyle
68 Chevelle wagon 350/BWT50
68 Impala wagon 327/400
04 Impala LS - Wife's DD
73 Wagoneer parts donor
Old 07-01-2019, 06:02 PM
GWNashville's Avatar
GWNashville GWNashville is offline
Awesome job. I need to get after that.
Richard
GWNashville
Email:alexhanmusic@comcast.net
1989 Grand Wagoneer 360 c.i.
727 Transmission
Serehill Rear Glass and Fog Light Harness.
Old 07-03-2019, 12:43 PM
Driftwood's Avatar
Thank you for the advice!
I found Achilles very informative 2015 write-up at http://www.ifsja.org/forums/vb/showp...6&postcount=63
And elskeptico's 2005 write-up at http://www.ifsja.org/forums/vb/showp...88&postcount=1
Old 07-03-2019, 12:48 PM
Driftwood's Avatar
Lock the spring loaded arm prior to removing the electric motor
Remove electric motor. It is secured with three 7/16 bolts.
After removing the motor, remove the small Philips screw.
Old 07-03-2019, 12:51 PM
asudchiman's Avatar
asudchiman asudchiman is offline
Wow. Nice work.
You have been busy.
1985 Grand Wagoneer - [Blue]
1990 Grand Wagoneer - [White]
1991 Grand Wagoneer - Vin#...001 [White]
1991 Grand Wagoneer [Hunter Green]
4rd: 2005 Jeep Wrangler LJ (Sold)
3rd: 1987 Grand Wagoneer (Sold)
2nd: 2005 Grand Cherokee Limited 4x4 Hemi (Sold)
1st: 1993 Wrangler Sahara (Sold)
Blogs:
Primary:My Jeep and Me
Old 07-03-2019, 12:52 PM
Driftwood's Avatar
Remove the cover and set aside.
Grab the splined shaft and remove the gear assembly.
Tap on the splined shaft to separate it from the plastic gear.
Old 07-03-2019, 12:53 PM
Driftwood's Avatar
OH THE JOY!!
Old 07-03-2019, 12:54 PM
Driftwood's Avatar
Both electric motors of mine were in this condition.
Old 07-03-2019, 02:32 PM
Last pichers I can see are from 7/1. The rest are big "-".
Old 07-03-2019, 05:39 PM
scout4bta's Avatar
scout4bta scout4bta is offline
no pics
Same here, no pics from post #8 thru #11.
Found, the perfect Wagoneer to Dieselize, 1989 GW 360, 727, NP208
1980 IH Scout/4BTA/NV4500/Atlas 4.3/DYNO:172(HP),432(ft-lbs)25mpg
Old 07-04-2019, 07:32 AM
Driftwood's Avatar
Went to Lowes for spacers and grease.
The spacers are a perfect fit.
Old 07-04-2019, 07:35 AM
Driftwood's Avatar
Old 07-04-2019, 08:45 AM
scout4bta's Avatar
Excellent!
Old 07-04-2019, 06:22 PM
I thought I was done with my tailgate. Now I have to open it up and do the motor/gear drive like you did.
Fantastic write up! How does it sound now that it is all rebuilt and cleaned up?
79 Cherokee Chief
Old 07-16-2019, 02:25 PM
Driftwood's Avatar
Buttoned up the tailgate today. I also tinted the rear glass.
Old 07-16-2019, 02:28 PM
Driftwood's Avatar
I have a tailgate alignment issue and am not certain if its correctable or if the body is tweaked. You can see the gap below on the left. It is larger than the right hand gap. It causes the passenger side of the rear glass to rub on the inner frame.
Thoughts?!?!
tailgate rust repair help? jeepdreamer General FSJ Tech 3 11-10-2009 06:48 PM
I need some help...tailgate window repair gone wrong YoungClayB General FSJ Tech 9 02-09-2008 02:39 PM
A few tailgate repair questions...with pics YoungClayB General FSJ Tech 4 01-14-2008 02:47 AM
How to get tailgate down first, then Tailgate Repair GrandWagonero General FSJ Tech 1 04-03-2006 07:51 AM
Tailgate rust (How hard to repair?) mtnbikerman General FSJ Tech 1 10-06-2003 03:38 AM
