Old 08-10-2020, 11:09 AM
82camo401j10's Avatar
82camo401j10 82camo401j10 is offline
Grinding headers for head bolts?
Anyone else have this problem? I've always used headmans!
304s,360s, seem to fit. But both my 401s I had to extend the notch around
Head bolts! The one with head studs, and heads cut .060, a bunch?
I even ground the stud ends and nuts flat on the 3 that are problem!
Gaskets still seal, but I stay after them, for 500 miles or so. I retighten @50 mile runs.
Ive tried different brands, but headman work best for me.
Old 08-10-2020, 10:35 PM
On my Hedmans and 401 I run Remflex gaskets and the crappy Hedman hardware. I usually hang the header with one hand and start one of the center bolts finger tight. Then I do the one to the front, the one on the very back (all only 2 or 3 turns) then the rest. I have not had to grind anything. Once they are all started I snug them in with an open ended wrench and lastly torque them with a deflection type torque wrench. I need to use a short extension with a swivel head/wobble head or whatever it is called to get the socket on. I have not had to grind anything. The Remflex gaskets are AMAZING. I torque them once and never again. Never had one leak, either.
Old 08-11-2020, 05:48 AM
SC/397's Avatar
SC/397 SC/397 is offline
The heads and head bolts are the same between the 360 and 401.
There are 2 slightly different styles of head bolts. One has a more rounded top than the other.
Old 08-11-2020, 11:05 AM
I use 3/8 head, SS header bolts, their still a pain to start by the dog leg notch.
Gotta start the m all,a turn or 2, before any are tightened.
I've never tried that remflex gasket. If any of mine leak, I'll give them a try.
Torque rating for shock bolts? Campcar_david General FSJ Tech 0 08-28-2004 06:20 PM
ARP Head Bolts Frank in Norway General FSJ Tech 2 03-05-2003 07:13 AM
Bolts for AMC 360 McBain General FSJ Tech 7 12-04-2001 09:44 AM
(TOM) Body Lifts Sitting Bull Suspension and Steering 2 11-04-2001 09:50 AM
Thorley Headers Millerluck General FSJ Tech 7 11-27-2000 03:49 PM
