Old 08-06-2020, 05:29 PM
Zorm's Avatar
Zorm Zorm is offline
1971 Jeepster commando
anyone seen anybody put one on one of our frames?
83 Cherokee 4dr WT(axles) 4" lift, 351w, nv3550, NP208, installing soon
78 Cherokee Chief 304 (vert)
07 Sea Ray 205 (for sale)
71 F-250 Camper Special 390 (in rewire stage)
HE guides my path, forgives me when I stray and lights my life.
Old 08-07-2020, 02:49 PM
I'd think it would be difficult. The C101 and C104 frame width is the same as the '75 and earlier CJ-5 and CJ-6. The Jeepsters have outboarded rear springs (accommodated by their square rear body corners) but their track width is the same as the corresponding CJ.
Plenty of owners have put Wagoneer axles under their CJs. It's the leas troublesome way to get a 44 front in a CJ. A Wagoneer 44 is only 5" wider than the C104 front 30. You'd need to outboard the front springs, and cut the body for the rears.
Old 08-07-2020, 03:48 PM
Zorm's Avatar
So your saying that a 78 chief frame would be too wide? What about the guys that have put Willys wagons and trucks on SJ frames? Chief body width, 74.8”, 71 commando 73”. Chief wheelbase 108”, commando 104”. All seems close. Maybe with some slights mods to SJ frame, the commando body would work,
Thoughts?
Old 08-08-2020, 09:53 AM
The Commando axle width is 60 " and so is the FSJ Wagons. It'll work
Old 08-09-2020, 10:06 AM
I'm sure that's wrong. C101 front axle width is the same as an early CJ with the 27, 51" WMS to WMS. C104 is the same as the narrow 30 in a CJ, 53" WMS to WMS. Same track width and wheelbase as a corresponding CJ-6. A Wagoneer front 44 is 58" WMS to WMS. This won't go under a CJ or a Jeepster frame without outboarding the front springs. The '72-73 Commando is 104" wheelbase (earlier is 101"), and a Wagoneer is 109". Body width of my CJ-6 is 59", and a Jeepster should be nearly the same. Jeepsters are small.
However, with enough metal work, anything is possible... A Wagoneer is more the size of a JLU Wrangler Unlimited - a lot bigger than a Jeepster/Jeepster Commando.
Old 08-10-2020, 05:04 AM
I thought that they widened the CJs/Jeeps in the early '70s due to rollovers? My CJ5 was close to 60" WMS-WMS..
Old 08-10-2020, 10:44 AM
They widened the axles (without widening the frame, springs or mounts), but that came long after the Jeepster was gone. Last Jeepster Commando (bullnose) was made in 1973, and the wide-track axles started in 1982.
1971 Jeepster Commando Zorm General FSJ Discussion 5 09-04-2017 09:29 AM
Jeepster Commando 67 sportsidedan General FSJ Discussion 27 09-10-2014 06:45 PM
Jeepster Commando Woody... Brizio General FSJ Discussion 10 11-29-2011 07:12 PM
Is the Jeepster Commando a FSJ?? 1cdccop General FSJ Discussion 9 08-16-2010 04:34 PM
73 JEEPSTER COMMANDO INSTRUMENT PANEL JBEES General FSJ Tech 6 03-04-2007 06:36 PM
