Old 11-04-2019, 06:42 PM
BA_051 BA_051 is offline
86-91 HVAC head unit vacuum routing
So now it’s winter and getting into the 20’s here in Albuquerque and I desperately need heat... I have completed my heater box and now need to hook up the head unit. I am running the ford SD electric vacuum pump.
The head unit has 4 vacuum lines:
Solid black, rigid: this is the vacuum supply line
Black with red tracer: this is the firewall door flap. Has vacuum in all but off position
Black with green tracer: has vacuum when in heat/def mode and def mode
Black with blue tracer: has vacuum only in def mode.
To sum it up:
Heat mode: vacuum to black/red only
Heat/def mode:vacuum to black/red + black/green
Def mode: vacuum to black/red + black/green + black/blue
Based on the length of the hoses, black/red goes to the firewall door diaphragm
And the black/green and black/blue are the same length.
Does anyone know where the black/green and/or the black/blue lines go? I know one goes to the heat/defrost diaphragm but where does the other go?
1974 Jeep J20, gladiator grill, 6BTA JWAC cummins, Modified He351, 4in exhaust to 5in stack, nv4500/ford np205, 14b kingpin axle, 14b rear axle, 4.56 gears, 37x12.50r16.5 Military tires.
Future mods:
G56 6 speed with dual disk clutch
He351/s475 compound turbos
Vintage air AC and Heat underdash combo unit
40x13.50r17 tires on 17x10 wheels
Old 11-05-2019, 09:20 PM
Well thanks to 78 Widetrac, he is parting a few late model grand wags, we were able to figure it all out.
The 85 and earlier FSJ’s use a different heater duct than the 86-91 FSJs... the early use 2 single action diaphragms. One to open the firewall door and one to move a door between heat and defroster. With no vacuum, it defaults to defroster. Both diaphragms have a single vacuum nipple.
The 86-91 fsjs have a different setup for defroster/heat. It’s a single acting diaphragm for the firewall just like the early models, but the heater and defroster diaphragm is a double action, having 2 vacuum nipples. There is also a different setup internally. There is no spring and the lever arm is longer to allow the double diaphragm to move it to the middle and all the way up for heat/defrost and just heat.
I am going to have to swap the early style with the late style to retain full function of the heater control unit (I am OCD and it has to function fully for me).
I will get pictures comparing both the pre 86 and the 86-91 u it’s when I have a replacement to swap in.
Future mods:
Old 11-05-2019, 09:52 PM
78 WIDETRAC's Avatar
Do you have the dash heater control for the 86+ wag?
Old 11-06-2019, 08:42 AM
That I do! I swapped an entire dash from an 87 or 88 into my 74. I thought the heater duct was the same for all years but it does change from pre-85 to 86-91
But yea, I have swapped everything in to make a new dash cluster panel that holds all 10 gauges. I like the more modern look of the dash in the old school cab/body.
I removed the tailgate and headlamp controls and moved the headlamp switch to the bezel under the column. It
Future mods:
Old 11-07-2019, 04:40 AM
woodrow woodrow is offline
Wow, you put a 88 dash in a 74 vehicle?
I wouldn't think that would be possible.
Love to see pics
Old 11-18-2019, 09:49 PM
Yes I did. It was pretty much bolt in except the parking brake assembly. One bolt isnt used but the other lined up fine.
Ill have to get pics this weekend.
Future mods:
Vacuum Routing AMC 360 4 BBL Intake cma General FSJ Tech 0 08-12-2018 04:02 AM
Edelbrock 1406 Vacuum Port Question etprime General FSJ Tech 7 01-01-2015 09:51 AM
FSJ Vacuum Routing tutorial shimniok General FSJ Tech 6 08-09-2012 11:39 PM
4wd vacuum routing Down Yonder General FSJ Tech 1 10-14-2009 10:49 AM
88 and up stock cassette head unit differences Jeepeta General FSJ Tech 5 11-15-2007 11:37 AM
