Old 10-27-2019, 08:10 AM
ClassicQueen ClassicQueen is offline
75 j20 wiring issues
Hi, this is my third attempt at posting
I recently acquired at 75 J20 AMC 360. Truck runs I have not drove it due to concerns with wiring. Ignition button cranks truck without key. Fuel pump runs only when key is in the ON position or all the way towards driver. Gauges do no appear to work except for oil pressure gauge. Neither wiper or lights work. There are parking lights missing, which i could probably source. The battery cannot be kept connected as it gets drained. Voltage regulator is disconnected and appears to have been decommissioned for a long time.
The way things look, I might need to replace all wiring, there are plenty of cut off wires in the cabin as well.
https://photos.app.goo.gl/ZGGifavePd4xjpWPA
Old 10-27-2019, 10:34 AM
Ouch! Rather than trying to patch/save whatcha got... I'd punt. Get a paper copy of the original 75 TSM and wiring diagram and just dump the butchered orig harness. EZWire and Painless offer a generic truck harness. Both are good quality, easy to install, labeled and include a new fuse box. The orig 75 FSJ harness wasn't great in the first place so trying to save it after DSPO butchering IMHO is futile.
Old 10-27-2019, 11:31 AM
letank's Avatar
letank letank is offline
as Joe said, it is a bit of a challenge to redo a wiring system, because one need to understand how the original designers laid out the wires, which is always a puzzle.
the coil pictures has a ceramic resistor to bypass the resistor wire that is part of the original wire loom that runs on the passenger side of the valve cover. Usually those wires get cooked because they are too close to the exhaust manifold.
Starts with the cranking/ignition/charging system to keep it simple
Being a 75 you may still have the prestolite ignition distributor, which has 2 white plastic vacuum canisters on the distributor, those have a bad reputation and where used for years 75-77 or about. One user claim that they can be refurbished or kept up for little care, most people move to the post 78 system called the duraspark
as for charging, time to do the ammeter bypass
EDIT: do not forget to remove that coil to battery wire when you turn off the engine, otherwise the coil will still be powered with a potential risk of fire
EDIT2: for any aftermarket wiring such as painless, you still need to reuse your original wire plugs at the firewall
Michel
Old 10-27-2019, 11:37 AM
fsj454 fsj454 is offline
Long time member
cabin harness
I have a good harness for 1975 glass fuses and steering column
1982 cherokee nt. 454. nv4500 .205. dana 60 f+r. twin stick.hydroboost.hydrolic clutch.rock ram.traction bar.warn 12000 winch.4 wheel disc.flip kit.soa.high steer.cross over steer.4.56 detroit locker.35 spline rear alloy axles. 37s .1990 grand wagoneer aka trusty rusty
Old 10-27-2019, 01:05 PM
ok, is it better to get a harness kit or an original harness?
Old 10-27-2019, 01:07 PM
I'm definitely interested on column mine is pretty beat.
Old 10-27-2019, 05:01 PM
Long time member
transmission
What type of transmission do you have
Old 10-28-2019, 04:20 PM
Not sure of type but it is automatic
Old 10-30-2019, 09:45 AM
Better depends on you. Any hot rod harness will require that you route and terminate the circuits and understand (to some degree) what you are doing. It will be different from the factory wiring, so you will need to rely on your notes and the instructions from the kit to diagnose and repair any issues with the new wiring.
The factory harness can be put back exactly like it came from the factory, and the factory wiring diagram can be used for any subsequent diagnosis and repair.
Personally I would fix the factory wiring unless there had been a fire. You can straighten out the mess if you go one circuit at a time and repair the PO's sloppy changes.
Or, get the harness from fsj454 and install that. Supposedly Zach at Z&M Jeeps (?) has replacement harnesses for these vehicles. Might be worth looking into. http://www.ifsja.org/forums/vb/showthread.php?t=187862
Here's some help with harness repair: https://www.jeepforum.com/forum/f8/b...arted-1340134/
Old 11-12-2019, 02:42 PM
Where could I get a wiring diagram for the the year? I looked in the web and wasn
Old 11-12-2019, 03:04 PM
Suggest you buy the TSM. Less than $25 on CD-ROM from RockAuto. No '75 diagram online that I know of.
https://www.rockauto.com/en/moreinfo...309474&jsn=371
Old 11-19-2019, 08:30 AM
If you go here you can get the 76 TSM in searchable .pdf. It should be close enough. They also have the 74-76 Parts manual which you should download, too. They are super handy.
http://oljeep.com/edge_parts_man.html
Someone makes a new/reproduction harness for these. ZM Jeeps maybe?
In my experience, I find it easiest to fix a factory harness, even one that is butchered as bad as yours. I usually take one circuit at a time and trace it out. Takes a long time but you learn EVERYTHING about how your truck is wired and what is connected to what.
I usually print up a couple copies of the wiring diagram (from the TSM) and just start marking them up as I go. As you verify the harness/circuits, highlight it as done on the diagram. Remove all the extra crap that has been added to your truck that is aftermarket. If there is an aftermarket radio, chuck it. If there is a brake controller, remove it. Etc. Then verify the circuits that need to work even when the key is off (headlights, horn, brake lights, interior lights, etc.). When those all work correctly, move on to the engine. Starter, coil, alt, gauges. When those work, work on anything left over (radio, clock, heater, A/C, etc.). I recognize I just listed about 12 hours of work (or more) but I think it is the best way to fix wiring. I have completely re-wired a vintage car and I have rebuilt harnesses and this seems the most reliable way to be done messing with electrical gremlins.
I also recognize you are going to find ALOT of problems because it sounds like the previous owner(s) worked around bad parts rather than fix them (hence a starter button that cranks without a key). You will find connectors that are totally corroded. When you do, clean or replace them.
Supplies to buy in bulk: Electrical tape (for bundling wires, MUCH better than zip ties), Shrink wrap (to cover terminals as you install/fix them), male and female terminals. Wire labels (I often times use a small label maker if i have to replace a wire with another wire of a different color, I label both sides of it).
Old 11-23-2019, 11:40 AM
Thanks for the info! Very helpful. I will be printing the 76 wiring diagram. It
Old 11-23-2019, 12:36 PM
So is ignition always on bc voltage regulator was bypassed?
Old 11-23-2019, 01:36 PM
What do you mean? Ignition is off when the switch is off.
Where was the VR bypassed? List the wire numbers from the diagram.
Realize that the 6-cylinder Jeeps got the Delco alternator with the regulator inside the alternator. The V8s got the Motorola alternator with an external regulator. Both of these schemes are shown on the same diagram, V8 above and 6 below. It's up to you to understand this and separate the two cases.
Old 11-25-2019, 12:09 PM
VR is completely disconnected from the system, which would be wires: 40, 41,43,44.
Old 11-28-2019, 09:30 AM
Pulled ignition wiring out, are there any updates I should make to improve the wiring?
Happy Thanksgiving!
Old 11-28-2019, 06:47 PM
nograin's Avatar
nograin nograin is offline
Happy Thanksgiving!
No. Especially at this point in the learning curve.
Return it to stock.
If there is an electric fuel pump, get rid of it. Install a factory mechanical fuel pump instead.
The improvements you can make with what you have will be in the quality of how you fix the wiring.
Use the factory type terminals. They are mostly "Packard 56" series.
The wire crimps to the terminal with two pairs of 'wings', one for the wire and wone for the insulation. This is called an 'open barrel' wire crimp.
Buy the correct crimpers to do this.
Make sure the wires have enough length there is slack or 'strain relief' at each connection.
Route the wiring as close to factory as you can figure.
Cover the bundle (aka harness) with split wire loom, or non-adhesive electrical tape.
Support the harness runs so they aren't tugging on connections or hanging on the exhaust manifold or such.
You can buy pretty much any color combination for any gage from Rhode Island Wiring. If you have a marine supply, like West marine, near enough, they have a pretty good selection of colors and wires which can be purchased in any length. (Added benefit is that marine wire is more oil and heat resistant than general purpose automotive wire.)
If you must use a different color insulation, get a set of colored electric tape so you can at least park the ends with the right color or combination.
You may find one of more welded splices in the harness if you unwrap it. Leave them alone. 99.9% of the time they are fine. There are splicing crimps if you must make up or replace, but the welded is best.
There should be one special undersized wire coming off the junction (stud) on the solenoid. This is a fusible link. Its job is to melt if the battery is accidently grounded.
'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
Old 12-15-2019, 01:44 PM
Working thru wiring
So I’m going thru every single wire. I’m stumped at wire 13 red w trace which goes to a welded junction yellow wire at junction goes to VR then red w trace goes to coil and then there a another red wire with trace that has been cut in the wiring diagram for ‘76 this wires connects to an electronic control unit. So the question is was there a ecu on 1975 j20s? ‘74 s diagram does not have it and I don’t se one in my truck
Old 12-16-2019, 04:53 AM
The ecu was an emission unit normally on California vehicle models, not until later usually. Maybe a universal wiring diagram and not specific to your truck is what your looking at?
"COOL " wiring harness building/modification supplies? blazer3664 General FSJ Tech 1 07-04-2011 10:05 AM
1982 J/20 Honcho, We may have to build ;-) ! AMC-J/20 General FSJ Discussion 320 06-14-2011 04:39 PM
Issues with my '74 J20 ehr400 General FSJ Tech 9 06-29-2010 03:15 PM
Wiring old style (early 60s) headlight buckets into new style wiring harness jode General FSJ Tech 3 06-25-2007 10:11 PM
Factory J20 5/4 ton??? Elliott General FSJ Tech 17 09-20-2004 01:55 PM
