Old 09-01-2018, 08:16 AM
auzjtruck auzjtruck is offline
1997 AW4 transmission to AMC 360
hi, I am putting a AW4 transmission out of a 1997 XJ Cherokee behind my freshly built AMC 360 ,and I need to find the wiring diagram for the TCU for that year, they are all diferant color codes for diferant years
Old 09-01-2018, 02:02 PM
Mikel's Avatar
Mikel Mikel is offline
You may want to try an XJ forum, like NAXJA.com
1969 M715 6x6
1963 J300 Swivel frame
Old 09-11-2018, 04:31 AM
still waiting for response
Old 09-11-2018, 09:37 AM
1997 XJ shop manual is not very expensive on CDROM. https://www.ebay.com/itm/1997-Jeep-Cherokee-Shop-Service-Repair-Manual-DVD-Engine-Drivetrain-Electrical/362174633733?epid=1411166879&hash=item54534a5705:g :eIQAAOSwG0taoCSo
RockAuto probably has them too.
Might be better than waiting for someone to reply.
Old 09-11-2018, 02:52 PM
rapom rapom is offline
AX-15 would be a better trans. for your 360. They are stronger than the aw4's as they were used in all xj's with the straight six. AW4's were only used in the 4 cyl. xj's and wranglers.
Old 09-11-2018, 03:37 PM
Mikel's Avatar
AW4's were used behind most 4.0s in XJs and have a great reputation in those applications.
1969 M715 6x6
Old 09-11-2018, 04:29 PM
x2
I've had 2 XJ's 4.0 w/AW4, still have one(96). Excellent AT.
Old 09-11-2018, 04:40 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
You're probably thinking about the AX-5 5 speed used behind the 2.5L, which is a much weaker trans than the AX-15.
The AX-15, and later NV3550, are both great transmissions, if you want a 5 speed.
Honestly, though, neither of those manuals likely come anywhere near what the AW4 can handle. The AW4 is based on the same trans that was in the twin-turbo'd Supra. I've seen a lot of people pushing huge horsepower numbers with built-up stock autos. Regardless of what type of abuse you want to call that, no AX-15 would ever survive.
aa
Old 09-12-2018, 03:30 AM
My bad, that is what I was thinking. 🙄
Old 09-12-2018, 06:32 AM
thanks eveybody for response , have made me feel more confident on using this tranny behind my 360 . i looked up the ebay site for the cd manual ,and ebay want $25 Australian to post from USA , it will cost $75 Aust to buy it, can not understand ebays charges , rip off
Old 09-12-2018, 10:03 AM
Pretty sure the eBay seller determines the shipping charges, not eBay itself.
RockAuto has it for less. Put it in your cart and see what the shipping will be.
https://www.rockauto.com/en/moreinfo...180370&jsn=366
How many XJs were sold in Australia? I expect quite a few. Someone local to you may have it for sale. Search or ask at your local parts store. "Bishko."
Old 09-12-2018, 06:14 PM
80Limited 80Limited is offline
I have put an 93 Aw4/231 behind a 360 a couple years ago. It’s not as hard as you’d think. If you need some help let me know.
Old 09-13-2018, 03:43 AM
thanks I need to know the wiring color and number code for the 1997Aw4
Old 09-13-2018, 08:36 AM
Mikel's Avatar
How do you like it?
1969 M715 6x6
Old 09-16-2018, 08:43 AM
I like the transmission. I did a post on here about it. It was fine with the 3.31s but 3.73 gears would be optimal. Cruises beautifully. No adapters needed.
Old 09-18-2018, 07:15 AM
I remember your post and have tried to find it , it would be good to read it again if I could find it
Old 09-18-2018, 11:06 AM
Do a google search for “AW4 swap complete” under IFSJA.
Old 09-18-2018, 11:51 AM
80limited brings up a good point about axle gearing. Don't know what rig you're considering swapping the AW4 into or your goals doing so. If you're running stock 2.73 or 3.31's the trans will still work but if you're expecting any benefit from 4th gear(OD) you won't see it except maybe(?) on absolutely flat ground. Any hills/grades it'll shift back down into 3rd to maintain speed and power. I wouldn't consider an OD trans with anything higher than 3.54 gears. Even my XJ's with stock 3.54's hunt a on even slight short up hill stretches. You can live with it but if your shooting for better mpgs from an OD trans 4th gear...don't expect it with too high of axle gearing.
Old 09-18-2018, 04:10 PM
Mikel's Avatar
Joe,
What RPMs do your XJs turn at 65MPH? Mine has 30in tires and with the AW4 and 3.55 gears, it should turn about 1950RPM, yet it's at 1500. I wonder if my tach is off...
Thanks
1969 M715 6x6
Old 09-18-2018, 07:16 PM
Joe,
Thanks
Gee Mikel I dunno. It's prolly been a year since I went that fast. I'm a good 2-3 hrs from the nearest interstate but I gotta make run to Colville in E.WA in a few days so I'll try to remember to make a note and let ya know when I get back.
A500 TRANSMISSION ? key General FSJ Tech 7 03-18-2008 12:52 PM
Kick down TH400 Bill Lawton General FSJ Tech 10 09-28-2007 10:07 PM
AMC 360 Timing and 727 Trans Shifting JohnIL General FSJ Tech 1 09-26-2007 12:05 PM
Lock up Transmission on 1986 GW 360 Brownisbetter General FSJ Tech 13 08-30-2007 01:36 PM
727 Transmission Noise Kevin718 General FSJ Tech 4 01-25-2004 03:10 PM
