Old 05-12-2018, 01:36 PM
Rod, main, and Cam bearing recommendations or advice?
just dropped my 401 stuff off at the Machinist. I need to order Rod, Main, and Cam bearings.
I see OEM was Clevite 77s. Anyone have any advice on bearings before I order them? Stay away from certain brands, positive experience with others? This machinst basically said, any name brand is good but they typically use Clevite or King...
Old 05-12-2018, 02:27 PM
I haven't rebuilt a motor in many years so can't attest to quality in 2018 but I've used Clevite in the past and never had premature bearing failure.
Old 05-12-2018, 02:43 PM
King is fine, I opted for Clevite tri metal P series for lt1 rebuild.
Made in USA according to boxes.
Old 05-12-2018, 03:49 PM
gophman's Avatar
gophman gophman is offline
I have king bearings in 2 of my 360's.
Old 05-12-2018, 07:09 PM
ok, copy all. thanks guys.
Looks like cam and main bearings are the same in 360/401 but rod bearings differ. (going off part numbers are rockauto)
Old 05-13-2018, 11:25 AM
OEM was federal mogul,which is junk. if you had clevite they were changed.
i prefer clevite,and also like acl. acl makes an oversize thrust bearing. acl are also full groove mains tho,which means the rods are oiled 360 degrees,which is fine altho not necessary,and will lower oil pressure.
clevite,and the oem were half groove mains. i would run half groove mains given the choice.
Old 05-14-2018, 07:25 PM
Are these not OEM?
-Jonny B.
AMC 401 - Pro-FLo 4 FI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 05-14-2018, 08:03 PM
SC/397's Avatar
SC/397 SC/397 is offline
Yes. They have the "AM" logo on them.
Old 05-15-2018, 12:15 PM
Wow, I've tore a lot of these engines apart and never seen am stamped clevites. Always federal mogul.
Old 05-23-2018, 12:32 AM
mattmopar440's Avatar
Are these not OEM?
are those out of that 401
87' Grand Wagoneer
80' J10 4BT/AX-15/208
74' J10 Go Grabber Green Sold
Inferior Chevy
Old 05-23-2018, 10:48 AM
Yes sir.
Old 06-06-2018, 03:44 PM
fsj454 fsj454 is offline
Long time member
3 3
Motor was made March of 1973 . Clevite 77 is what I use in all my engine builds
1982 cherokee nt. 454. nv4500 .205. dana 60 f+r. twin stick.hydroboost.hydrolic clutch.rock ram.traction bar.warn 12000 winch.4 wheel disc.flip kit.soa.high steer.cross over steer.4.56 detroit locker.35 spline rear alloy axles. 37s .1990 grand wagoneer aka trusty rusty
Old 06-06-2018, 03:55 PM
My motor was built then?!?! That's what those numbers mean?!?! SWEET!!! I have the early stud mount rockers (casting numbers are 3216090-1) but my block casting number was 71-78.
I would assume that means the bearings were made March of 73 or does it mean they were installed in March of 73?
I ordered all Clevite 77 bearings for my rebuild because they seem to have good ratings all over the place, were OEM, and have been around for decades.
Old 06-06-2018, 04:17 PM
Long time member
11 9
My motor bearings have 11 9 .The jeep is a 1990 .vin date nov. 1989 . So vin date and motor date are the same.
Old 06-06-2018, 04:23 PM
Long time member
Manufacturers date .Is your jeep a 1973
Old 06-06-2018, 05:20 PM
Nope. I have a 79 but the engine was swapped in before I bought it so I have no idea/history on the engine.
Old 07-31-2018, 11:43 PM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
A tri metal copper-lead with Babbitt overlay bearing like the OE bearings and Clevite 77 are the heaviest duty bearing. They can handle high loads without failure. However, they wear out quickly. Most have blown through the Babbitt layer by 100,000 miles and after that their performance degrades significantly.
Bi-metal aluminum bearings like King are a medium duty bearing that cannot handle loads as heavy as a tri-metal bearing, but have a longer service life. 200,000 miles from an aluminum bearing is completely do-able. They are more tolerant of crankshaft finish and misalignments too and wear the crankshaft journals less. Modern bi-metal aluminum bearings have nearly the load capacity of the older tri-metal bearings.
The AMC V8s used in standard AMC passenger cars and not Jeeps actually switched to bi-metal aluminum bearings sometime in the mid to late 1970's. The Jeeps kept tri-metal copper-lead bearings because of their anticipated loads and because bi-metal aluminum bearing technology was not what it is today.
I recomend King bi-metal aluminum bearings for stock to mild engines because of their service life in those conditions. High performance builds should still use a tri-metal bearing.
