Old 05-10-2018, 08:39 AM
Valve stem seals...360 '88
So I know Felpro seals are problematic, and that they aren't correct.
I have some from a whole gasket kit, a white set, and a black set.
Can I measure them to see if they're ok to use?
Or is there an off the shelf seal from someone else that is better, and does anyone have part#?
My '88 is going through oil @ an alarming rate, and I'm hoping that changing them will reduce this some.
Old 05-10-2018, 09:09 PM
Are you changing them in the vehicle or do you have the heads off ? if they're off check the guides , if they're shot seals won't help a lot.
Stock valve seals aren't really seals they're more like oil deflectors. " umbrellas " actually. if they fit semi snug on the stem and have a diameter that covers the guide that's about all you're looking for.
If you're machined for positive seals then the choice of seals is more important. I like the viton ones they seem to work well. DO NOT use the white teflon seals unless you like smoke.
Old 05-11-2018, 08:25 AM
Changing in the jeep, if they were off I wouldn't be asking.
@130K+ I'm sure the guides are worn, but the seals are likely original as well.
Old 05-12-2018, 08:29 AM
A lot of the time they're cracked and laying on the bottom.
I've had good luck with the green viton umbrellas on worn guides . they stop more oil than stock seals . I think they're as good as it gets short of new guides.
Old 05-12-2018, 09:12 AM
Unless I'm missing something I don't see anyone that offers Viton seals(ready to install) for AMC heads.
Questions in 1st post...
Originally Posted by babywag
So I know Felpro seals are problematic, and that some aren't correct.
Ones I already have...Guessing from mid-late '90's from AMC full engine gasket kit stored indoors.
Nylon 5P00557 measure ~ .372 ID
Polyacrylate 5P00555 measure ~ .342 ID
Given above choice(s), I'd probably install the Nylon ones, BUT if there is a better set I can buy and install???
Old 05-12-2018, 07:46 PM
gophman's Avatar
gophman gophman is offline
the nylon ones aree too loose a fit, I did and a week later had to do it again this time with the rubber ones.
Old 05-12-2018, 09:14 PM
I can't remember if AMC is 11/32 or 3/8 but both available. all that matters is stem diameter the rest is universal on umbrellas.
Big block Mopar's are 3/8 and I think AMC is as well. if not chevy's are mostly 11/32 and those of course are easy to get.
Old 05-13-2018, 09:31 AM
68glad's Avatar
68glad 68glad is offline
Local napa used bb chevy ones when they did my heads if memory serves. Memory is getting bad though. Worked fine.
68 gladiator- 455/400/20 r.i.p.
78 wagoneer- 401, drw60, drw70, 203/205, 38's, oba, obw, hydroboost, dual p/s pump, bla bla bla
Would valve covers from an 89 360 fit my 76 401? mattparliament General FSJ Tech 3 03-28-2012 04:49 PM
360: how to tell a bad lifter from a worn cam from a burned valve? elskeptico General FSJ Tech 32 03-08-2011 02:08 PM
Valve Stem Seals, Which ones? Mxlt General FSJ Tech 14 06-01-2008 10:01 PM
Valve seals srobertsfsj General FSJ Tech 2 07-08-2006 11:25 AM
