Old 12-28-2016, 10:53 PM
87grandwagn 87grandwagn is offline
360 Build
Hey Guys,
It is time to rebuild the 360 in my 88 GW and I need some help.
I have read all of the build threads and some of them go back a ways so I was wondering what new things might be out there. I am listing below the direction I think we will be heading, I just need some advice on cparts for my engine guy. He is a Chevy kinda fellow.
360 Block - 30 over
compression - ?? I would like 9.5
stock heads - valve job
rockers - 1.6 rollers
Cam - ?
Intake - ?
Ignition - HEI
exhaust - headers/2.5 or 3" duals
I am fine with lope but it needs to idle.
Thought?
Suggestions?
I will also be lifting and changing gear ratios.
Thanks in advance.
Andy
Old 12-29-2016, 07:38 AM
Offy equaflow intake. Performs grind cam. Stick a 5200-5600 rpm governor in the transmission too.
Old 12-29-2016, 01:08 PM
EKWagoneer's Avatar
EKWagoneer EKWagoneer is offline
I think many would say Summit 8600 cam or Comp Cams 10-201-4 cam, 260H grind (or shop around at Comp- there are similar grinds) Intake- Edelbrock Performer or the Offy. On mine I am going with the Comp Cams 260H and Performer intake (when I get there, delayed progress )
Hope this helps
Ely
1973 Wagoneer- nearly stock, work in progress
1/2 1975 Wagoneer- rolling chassis, D44's 6" lift, 35's, work in progress
1992 Chevy Suburban 1500 Silverado, mostly stock, 396,000 miles and counting
I'm a secondhand vegetarian- cows eat grass, I eat cows.
Have A Nice Day!
Old 12-29-2016, 01:10 PM
I wouldn't run another 8600 if I was paid too.
Old 12-29-2016, 01:16 PM
EKWagoneer's Avatar
When I was looking around at cams, I read old threads (here and elsewhere) and some folks thought that it was decent. I guess not?
Ely
Have A Nice Day!
Old 12-29-2016, 02:04 PM
Charles Kline Charles Kline is offline
What make the offy a good choice?
What is the general consensus of the Lunati Voodoo 256/262 cam and lifter Kit?
I'm thinking about going with the stock 4bl intake on the '79's 360.
-Charles
Old 12-29-2016, 03:30 PM
Josh D's Avatar
Josh D Josh D is offline
I'm happy with my CC 268H. Also, worth the extra coin to have hardened exhaust valve seats installed when you get the heads done.
'71 J2000 Gladiator
'95 YJ on Waggy axles
'80 911 Super Carrera
Old 12-29-2016, 09:47 PM
The lunati voodoo I ran was ground 12 degrees off, which is ridiculous, and it seems is typical for them. Once corrected it ran fine but it had nothing over the far cheaper melling performer grind. This was the small voodoo grind.
The offy equaflo is a split single plane. Which flows better at mid range. In theory it would give lesslow end off idle as a performer intake, but in my experience it matches the dual plane performer off idle as well.
As an added bonus it means no edelbrock parts on your motor.
Old 12-29-2016, 09:48 PM
Charles, the stock 4barrel setup is junk.
Old 12-30-2016, 11:38 AM
Thanks for the info Ristow.
I'm in Golden, CO and have to deal with emissions and stock setups. nothing says not stock like BS edelbroke logos everywhere.
in Stock 4bl vs stock 2bl is the 4bl better?
There is a good thread here on the 360, this is where I first heard of the voodoo. This guy seemed to have good results.
http://www.jeepforum.com/forum/f8/wo...360-a-1354590/
Old 12-30-2016, 12:05 PM
a decent working stock 4 barrel would have more snort than the stock 2 barrel. but not much,and you may have hassles getting it working well,due to age,warped top cover and previous "tuning".
going any bigger than the small voodoo cam on a stock low compression block is giving up low end for mid range you dont use. and the melling performer grind is half the cost,and i have used many and never had one need to be corrected on timing. the voodoo was off so far i had to skip a tooth on the cam sprocket and user the retard keyway.
Old 12-30-2016, 12:35 PM
babywag babywag is online now
stock 4bbl square bore intakes are out there too.
the edelbrock egr performer is emissions friendly and "usually" will slide through inspection, but technically not "legal".
Old 12-30-2016, 03:17 PM
That's a good idea tony, Charles. Find a square bore stick intake, put a Holley on it, I have Holley float bowls with charcoal can fittings I can send you. Would look stocking
Old 02-16-2017, 06:03 PM
mellos_J10 mellos_J10 is offline
Noob!
I too am rebuilding my 360 and it's my first motor build. It is hard to sift through everyone's opinion to actually know what the right parts to get are. What all are you planning on doing with yours? I'm trying to find a good EFI conversion and learning how to size a cam and all that jazz. It's a lot of homework!
Old 02-17-2017, 07:35 AM
SC/397's Avatar
SC/397 SC/397 is offline
In my opinion...
I would go with a 268H cam and a Air Gap or Performer intake.
Old 02-17-2017, 11:50 PM
Another Hijack
I have one that I plan on using. I also have a Holley Street Dominator intake but am unsure which one to use. Suggestions?
-Jonny B.
AMC 401 - Pro-FLo 4 FI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 02-18-2017, 05:53 PM
SC/397's Avatar
The Street Dominator is good for gobs of low end torque but will out of steam by 5K. I would step down to the Edelbrock Performer grind type of cam if you are going to use that Intake.
Old 02-21-2017, 09:43 PM
It all depends on what you want from your engine. I like a smooth running no issues engine in a 4x4 I'll do my hot rodding in cars.
I built the 360 for my J10 with a comp 260 cam, KB hyperutectic pistons , (around 8.8 -1 ) performer intake and a 1406 edelbrock carb. I like it, just what I wanted for a close to stock build.
A 268H type cam would be the limit unless you want a choppy idle and stall convertors. pistons for the 360 are much more limited in options than I expected. to get 9.5 you'll probably have to go with Bulltear or something like that. and remember 9.5 is going to take a very minimum of super at the filling station.
Old 11-01-2017, 01:13 PM
SIUADOG's Avatar
SIUADOG SIUADOG is offline
Originally Posted by Charles Kline
I'm in Golden, CO and have to deal with emissions and stock setups. nothing says not stock like BS edelbrock logos everywhere.
A little off subject, but could someone grind off the logos, paint the manifold to match the engine, and sneak through inspection?
By now these trucks probably outdate alot of the inspectors.
Just Empty Every Pocket
1988 Grand Wagoneer
AMC 360
727 TF
No modifications so far... Yeah, I'll probably keep it stock.
Old 11-04-2017, 11:12 AM
DarkMonohue's Avatar
Shakes hands with danger
Why, no! That would be against the law!
I've heard that some unethical people reproduce an as-cast surface on the manifold where the incriminating evidence was ground away by laying a coarse sanding disk on the part and striking it with a hammer. Apparently this is pretty convincing once covered in a coat of OEM paint.
How these outlaws sleep at night, we may never know.
AMC 360 Build or swap?? rustywag General FSJ Tech 36 05-22-2011 08:02 PM
DILEMA: 360 VS. SBC 350 BigGreenMonstaWagoneer General FSJ Discussion 16 02-23-2010 01:01 PM
360 motor build options? 78indian General FSJ Tech 2 04-20-2005 04:47 PM
360 build help stinky General FSJ Tech 14 01-16-2004 01:09 PM
360 Build options billyrb Engine 15 02-04-2002 04:54 AM
