Old 02-12-2015, 09:04 PM
acct21's Avatar
acct21 acct21 is offline
The elusive Jeep/AMC cruise control tester tool
Finally found one of these weird little things -- the AM P-C-1R Cruise Control Tester 7079. It looks a lot like an Atari 2600 cartridge.
You unplug your 'yellow box,' and plug your harness into this instead. The instructions were a little tough to follow, but luckily in the 1990 Jeep Electrical Service Manual there is a section on testing the CC with this same tool. So it looks like all of the years with the 'yellow box' control module use this tester.
So using the flowchart from the 1990 Service Manual I was able to test the system in about 3 minutes! Turns out the 4 amp glass inline fuse some Machiavellian AMC engineer tucked into the power feed (and behind the instrument panel) was slow blown. Judging from the dust cake that fell out of the fuse holder that sucker hadn't been open since the first Bush presidency.
Old 02-12-2015, 09:28 PM
Tripwire's Avatar
Tripwire Tripwire is offline
interesting..... thanks!
Abort? Retry? Ignore? >
Old 02-13-2015, 05:40 AM
Wanna loan that sucker out? Or sell it?
My cruise isnt working and I would love to test it.
Where did you find it? I wouldnt mind having one of my own. Is there a part number on it or anything?
2004 Jeep Liberty
1998 Jeep ZJ 5.9
1994 Jeep ZJ I6
1989 Jeep Grand Wagoneer 360
Old 02-13-2015, 05:59 AM
mdcptman's Avatar
mdcptman mdcptman is offline
Jeep Therapist
Originally Posted by JeepJeepster
WANNA loan that sucker out? Or sell it?
Im thinking there would be a line to use this thing! Where did u find it?
I would almost drive my jeep to Austin and pay u to test it.
88 Grand Wagoneer
360/727/NP208/dana 3.31s
Edelbrock 2131
Holley 600
Hydroboost
Hedman headers
Dual exhaust
MSD6A, TFI
Digital Gauges
Rusty's 2" Lift
31x10.5 15LT15s
Quote From Friend's Mom:
Old 02-13-2015, 09:59 AM
acct21's Avatar
This thing is much more rudimentary than you might think. It is a box with six LED lights that light up in a specific order as you're performing the self-test outlined in the instructions. It really just saves you from rooting around behind the dash with an ohmmeter.
Having said that -- it worked great for me, and I'd be happy to loan it out. PM me and we'll make arrangements. I've got the original instructions and the pages from the 1990 Jeep Service Manual I'll send along with it.
Old 02-13-2015, 11:01 AM
Good deal. Ill shoot ya a PM when I bring the FSJ home this spring. Got a few weeks worth of parts built up waiting to go on.
Where did ya find it?
2004 Jeep Liberty
1998 Jeep ZJ 5.9
1994 Jeep ZJ I6
Old 02-13-2015, 07:02 PM
BugsInMyTeeth's Avatar
BugsInMyTeeth BugsInMyTeeth is offline
Noob!
There would probably be a decent market if you could replicate it. You could sign me up for one.
Old 02-13-2015, 07:07 PM
Woodchomper's Avatar
Woodchomper Woodchomper is offline
Could you open it up and take some pictures? It might not be that hard to reproduce it.
1991 GW 401 /727TF/NP229 /4" Skyjacker /EBL TBI /CS-144
1981 J10 401 /727TF/NP208 /6" Superlift /CS-144
Old 04-27-2017, 10:35 AM
Gibber's Avatar
Gibber Gibber is offline
I've changed out the 4a fuse under the dash....but still cant find the culprit.
Any chance you could loan out that "Cruise Control Tester"?
'89 GW
360
TF727
Dana 44's (2.73)
Baltic Blue/Sand Interior
"Passing everything but Gas Stations"
Old 04-27-2017, 05:32 PM
acct21's Avatar
Yessir. PM me an email.
Old 04-27-2017, 07:46 PM
TexasJ10's Avatar
TexasJ10 TexasJ10 is offline
360 AMC
Just saw one on eBay but it is very pricey
http://www.ebay.com/itm/DANA-ELECTRONIC-CRUISE-CONTROL-TESTER-W-HARNESS-ADAPTER-USED-IN-GOOD-CONDITION-/291890471087?hash=item43f60720af:g:IJMAAOSw8gVX6sk 7
Old 04-27-2017, 08:28 PM
acct21's Avatar
No need to pay that, unless you just want one.
All I ask for is a deposit and $5 for Priority Mail shipping. Happy to lend it out anytime.
Old 04-28-2017, 07:09 AM
Gibber's Avatar
PM sent
'89 GW
360
TF727
Dana 44's (2.73)
Old 09-24-2019, 09:33 AM
pickledtoast pickledtoast is offline
PM set as well.
Old 09-25-2019, 01:27 AM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
My cruise control used to do all kinds of weird stuff. Sometimes it would hold, sometimes it wouldn't, sometimes it would totally flip out and open the throttle wide only to then slam it shut again. It was a trip. I decided to reset the adjustment screws to the recommended initial settings.
It took me four hours of driving back and forth on a quiet country road with the cruise box pulled out still attached to the wires as I turned the adjustments with a screwdriver as I drove to get it adjusted and working right.
Old 09-29-2019, 09:05 AM
1989 cruise control causes brake light problem
I had a 1989 Jeep Cherokee XJ (downsize, not FSJ) that had the same yellow cruise control module as my current Grand Wagoneer. I had that XJ for 25 years. One problem that came up when it was about 20 years old was that the brake lights were on and wouldn't turn off. When I traced the circuit for the brake lights, I found that the brake light wiring went through the cruise control module (presumably to turn off the cruise control when hitting the brakes). I opened up the module and found a burnt section of the circuit board that was shorting out. I was able to repair it and fix the brake lights and the cruise control.
Since the cruise module was being discussed, I thought that I would mention this in case it might help someone at some point.
David
Old 09-29-2019, 11:00 AM
Wonder if the ‘sensors’ or whatever it uses become corroded and it freaks out when it gets erroneous readings? Maybe moving the screws around cleaned the contacts?
I know there is a sensor on the speedo cable but how does it know throttle position? Or does it just keep giving it throttle till it satisfies the speed?
2004 Jeep Liberty
1998 Jeep ZJ 5.9
1994 Jeep ZJ I6
Old 10-14-2019, 11:02 AM
I spent a little time this weekend with some wiring diagrams. I first checked the stalk switch and that ended up being faulty. Some jumper wires to duplicate the function and a test drive resulted in a functioning cruise. New stalk ordered. $21 for the stalk, $25 for the missing yellow cruise brain. Not bad.
Old 11-19-2019, 10:28 AM
dbrownLFK dbrownLFK is offline
Originally Posted by pickledtoast
I spent a little time this weekend with some wiring diagrams. I first checked the stalk switch and that ended up being faulty. Some jumper wires to duplicate the function and a test drive resulted in a functioning cruise. New stalk ordered. $25 for the stalk, $30 for the missing yellow cruise brain. Not bad.
Where/which stalk did you get? Same with the "brain." TGW wants top dollar for the stalk.
Old 11-19-2019, 11:40 AM
I got this stalk from Amazon. Quality is ok, good for the price. $21
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Brain I got off one of the facebook wagoneer pages for $25 shipped with the harness. I see them on ebay often for around $35.
Cruise Control Red20 General FSJ Tech 5 07-30-2011 07:39 AM
Cruise control won't accelerate or decelerate, but works otherwise iroc86 General FSJ Tech 6 07-02-2010 09:38 AM
Cruise Control Adjustment JohnIL General FSJ Tech 1 02-13-2008 11:56 AM
Cruise Control vent box etjeep Off-Road FSJ Tech 0 12-04-2006 12:37 PM
Cruise control (or throttle) sticking?! yipcanjo General FSJ Tech 4 03-31-2005 02:20 AM
