  #41
Old 11-06-2010, 04:44 PM
Ghinmi's Avatar
Ghinmi Ghinmi is offline
Super Moderator
Well..what transmission are you using? A 2wd AMC one? I haven't started looking yet, but am interested in what the best 2wd one will bolt to a 401.
Here's a few options off the top of my head.
1. Get a 2wd trans from an AMC car. I think the 4.0L in Jeeps uses the same bolt pattern as an AMC so maybe a 2wd XJ trans would work too?
2. Buy a 2wd trans from a Chevy and use an ultrabell or adapter plates. They make an ultrabell for Powerglide, TH350 and TH400. I'm sure they also make adapter plates to run a 700R4.
3. Convert a Jeep TH400 to 2wd. You'll need to swap output shafts and tail housings and machine the case for a speedometer output. Not sure of the years but some early (1974ish) AMC/Jeep TH400s are already machined for the speedometer.
I've done option 3 for my Wagoneer and have no complaints. The Cherokee will be getting an ultrabell and a 2wd chevy trans for safety's sake.
Old 11-06-2010, 06:33 PM
Tigger4X's Avatar
Tigger4X Tigger4X is offline
Theres goes another keyboard! I keep forgetting my drool rag. Some most excellent goodies under that hood. I'd love to hear it scream when you light it up!
Originally Posted by will e
Old 11-06-2010, 07:20 PM
The PIG Smith's Avatar
King Browless
You also could use a Chrysler 2WD style 727 and convert an AMC 727 that came from a later model FSJ.
Same deal as the TH400, swap output shaft and tailhousing.
Bryan Smith
Originally Posted by Jayrodoh
Originally Posted by Lindel
Old 11-07-2010, 01:04 PM
Eugene 1's Avatar
Eugene 1 Eugene 1 is offline
and just as easy to find!
JEEP
2005 Ram 1500 HemI
Old 11-07-2010, 02:35 PM
Gambler68's Avatar
Rabble Rouser
What about a 998/999? Or are they 4WD trans..
I know the 401 Gremlin X's were offered with an auto option..just can't find the exact trans yet.
Just brain building something..
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 11-07-2010, 03:30 PM
A 727 would be better choice over 998/999. Our Eagle has a 998 and it is good tranny behind a I6.
Old 11-07-2010, 03:34 PM
King Browless
Factory 401 powered Gremlin? Hmmmmmmm
I thought the only factory V8 offered was the 304.
Anyways, I think the 727 was the 2WD automatic transmission of choice the mid 70's larger V8 powered AMC cars.
Bryan Smith
Old 11-07-2010, 05:12 PM
Ghinmi's Avatar
Super Moderator
Correct, only V8 available was the 304. Then there was the Randall XR 401 but they came as factory 304 cars. http://www.gremlinx.com/index.php?op...3&It emid=152
Another good place to look for a 727 would be a 1974 International Travelall with the AMC 401 and heavy duty 2wd 727.
Old 11-07-2010, 08:45 PM
Gambler68's Avatar
Rabble Rouser
Thanks for the heads up!
And yeah, the 401 Gremlin I found on that site.
Looks like 2WD 727s came in Eagles for a few years too, then they switched to the lighter trannies because the 727 was overkill for that small of a car.
Old 11-07-2010, 09:54 PM
Ghinmi's Avatar
Super Moderator
I don't think they ever made a 2wd Eagle?
I mocked up the engine today to get some measurements and snapped some pics. I've still got to make an oil pick up & finish the intake before it's ready to go together for real.
http://carphotos.cardomain.com/ride_...4117_large.jpg
http://carphotos.cardomain.com/ride_...4118_large.jpg
http://carphotos.cardomain.com/ride_...4116_large.jpg
Old 11-07-2010, 10:07 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
Very sweet. I really need to stop up and see this stuff in person some day. I'm in Grand Rapids all the time.
aa
Old 11-07-2010, 11:03 PM
lost1's Avatar
lost1 lost1 is offline
Hey man, you need to put up some big flashy warning signs or something... those pictures are NICE!
Originally Posted by Locked and Loaded
Jeeps don't get stuck. People do.
Let the good times roll!
'83 Wagoneer«» 401/TF727/3:31 AMC20
Old 11-08-2010, 10:25 PM
Ghinmi's Avatar
Super Moderator
aa
Next time you're going to be in town let me know and we'll see if we can work something out. Email is ghinmi@yahoo.com
Pulled the body off the frame today (again). Hopefully next time it goes back together it's permanent, lol. I've got to weld up the frame, sandblast everything, paint, and put back together. I already finished the underside of the body, didn't take much work because of how nice the body is. Here's some pics of the body mounts for those interested.
http://carphotos.cardomain.com/ride_...4125_large.jpg
http://carphotos.cardomain.com/ride_...4122_large.jpg
http://carphotos.cardomain.com/ride_...4123_large.jpg
http://carphotos.cardomain.com/ride_...4124_large.jpg
http://carphotos.cardomain.com/ride_...4119_large.jpg
http://carphotos.cardomain.com/ride_...4121_large.jpg
Old 11-08-2010, 10:45 PM
Cecil14's Avatar
I will definitely do that! Might be a bit with all the holidays coming up, but I will definitely make it up there one of these days.
aa
Old 11-09-2010, 09:21 AM
Rompn's Avatar
Rompn Rompn is offline
Thumbs up
Subscribing...
Patrick
INNOVATIVE FABRICATIONS
Old 11-09-2010, 09:27 AM
jeepsr4ever's Avatar
www.Bulltear.com Chief
Things to consider
1. Chromoly is lighter than the steel the frame is made out of and stronger
2. Pitch all glass
3. If you run the 4wd front get the guts out and use some tube caps to plug the holes
4. When your building any kind of horsepower the stock converter will be the next hurdle
5. Pitch the dana 44 in favor of a ford 9" rear it is lighter and stronger
6. Pitch all bumpers and interior
There are a couple of REALLY nice FSJ drag racing jeeps in this country if you google them you will see how much work was put into them.
Cool project!
AMC/Jeep Forum
Old 11-09-2010, 11:45 AM
Ghinmi's Avatar
Super Moderator
Care to elaborate on that? The only ones I know about are mine, the green '73 Wagoneer from WV, and the white J10 with the chevy motor. If there's more out there it'd be cool to see them.
Old 11-09-2010, 12:56 PM
baja's Avatar
baja baja is offline
It's too bad you had to start with such a heavy,solid body...
I know it was probably all you could find at the time, but I don't think the light weight rusty bodies are too hard to find. Now you have all that excess solid steel to deal with, too bad.
All kidding aside, it looks like it's coming together well.
Looks like it will be a lot of fun, smart choice on the GM swing arm frame and suspension. And the full size width of the GM ifs will get the front tires a little farther out in the wheel wells, makes for a little more aggressive look.
I also liked the comment a ways back about the 2wd AMC Eagle, BTW, yes they made them but, they were called Concords, Gremlins and Spirits etc.
Hello, I am Brad. I have JOCD (Jeep Obsessive Compulsive Disorder) If you can admit you might have a problem, is it really a problem?
JEEPS-N-Stuff:
1998, Grand Cherokee, dd.
1987, Grand Wagoneer, Pimped, totalled by hail storm...
1977, CJ5
1976, J10
1949, Willys Jeepsterrr
1948, Willys Jeep truck
1942, Ford 1-1/2ton, Marmon-Herrington 4x4
Old 11-09-2010, 08:05 PM
del's Avatar
del del is offline
living the dream
Wish I could start, heck, even finish a project like that. As soon as you get it finished, let us know where you're planning on running it so we can roadtrip to see it in action...Del
1987 Wagoneer
4" BDS Springs, 31"x10.50's
401/727/229
Old 11-11-2010, 10:27 PM
Ghinmi's Avatar
Super Moderator
Del, you know you're welcome to a ride in either Jeep! I'll be sure to keep you updated.
I've been slacking the last couple days but here's where I'm at right now. The first two pics are at the final ride height (springs removed). It sits a lot lower than the pics show.
http://carphotos.cardomain.com/ride_...4129_large.jpg
http://carphotos.cardomain.com/ride_...4130_large.jpg
http://carphotos.cardomain.com/ride_...4127_large.jpg
http://carphotos.cardomain.com/ride_...4126_large.jpg
Choptop Buildup Thread krek General FSJ Discussion 137 11-18-2018 07:04 AM
Build Thread sticky tgreening General FSJ Discussion 2 01-08-2010 09:13 AM
Making some progress on my Cherokee build Gearhead 1990 Off-Road FSJ Tech 62 10-29-2007 08:27 PM
Azusa off-road videos, pics, and Cherokee review PlasticBoob General FSJ Discussion 12 10-23-2007 05:48 PM
