View Poll Results: What gear ratio do your run with your 35" tires
4.10 76 43.68%
4.56 59 33.91%
Stock gears 24 13.79%
Other 15 8.62%
Voters: 174. You may not vote on this poll
  #61
Old 01-27-2013, 04:16 PM
CutterN55's Avatar
Originally Posted by Hippie Metal
I was just wondering the same thing to myself. I am running a Ford T-18/Twin stick 205 behind a sound running 360 in a 1984 GW
/Thread Hi-Jack
Hippie, you are running a near identical trans/t-case combo as me. I'd buy some bigger axles with something between 3.73's or 4.10's in them already if I were you. 4.10 with 36's is more than enough gear for me with the deep Ford trans gears. You are already geared lower than a stock waggy as it is. If you are like me, I only street drive 2nd-4th and If I recall correctly, 2nd in the Ford T-18 is deeper than the stock 727's 1st gear.
ROMANS 12:1-2
'89 GW deceased
Ford 4spd swap Np435/205
Old 02-04-2013, 12:26 PM
BillyWagoneer's Avatar
BillyWagoneer BillyWagoneer is offline
yeah im about to do the same thing and im gonna run 4.10's just for highway sanity. if you want lower gearing have someone go through your transfer case and build that up this way you have when you need it on the trail.
87 gwag
De Smogged
Promar Amc 360 Ci
.60 Over
Melling MTA-1 Cam
MSD Multi Spark TFI
Holley TA
Performer Intake
Hedmann Full Length
True Dual side pipes
TF 727 & np229
B&M Shift Kit
12 Bolt rear & D44 front
4.10's and ARB lockers
SOA & shackle flip
33 12x5's
Empty wallet
Old 12-03-2013, 05:58 PM
Originally Posted by madmikeX3
I'm running my stock 3.31 gears with 35's on my 80 chero 4 speed. Does real well on gas. Cruises along not screaming at 55-70 MPH and I can still spin the tires.
My Cherokee project is running 33x10s with 3.31 gears and AX15 five speed. It should be at approx 2K rpm in OD at 65 mph
Old 12-01-2015, 08:13 PM
firedog firedog is offline
I put 4.56 in mine. We go to Moab every year. Wheeled like a monster on all the hardest trails Moab has to offer, and drives around town getting groceries like a champ. Been very happy with 4.56 for gearing selection with my 35".
Best of luck
Old 12-02-2015, 06:31 PM
sma97tj's Avatar
sma97tj sma97tj is offline
my 89 has 2.72s in it
Old 11-14-2019, 07:18 PM
fsj454 fsj454 is offline
Long time member
Talking 456
I am running Dana 60s front and rear with 4,56s with 37s with nv4500 and Chevy 454 . I am very happy with this combo
1982 cherokee nt. 454. nv4500 .205. dana 60 f+r. twin stick.hydroboost.hydrolic clutch.rock ram.traction bar.warn 12000 winch.4 wheel disc.flip kit.soa.high steer.cross over steer.4.56 detroit locker.35 spline rear alloy axles. 37s .1990 grand wagoneer aka trusty rusty
Old 11-18-2019, 06:17 PM
Gadzooks2's Avatar
Gadzooks2 Gadzooks2 is offline
It has a lot to do with your motor/trans combination and what you want to do with the truck. I went with 4:88 with 35's but I have a 4spd auto and quite a bit of LS power. The 4spd with lockup allows it to go faster than I ever want to on the highway and the 88's pin you back in the seat through the gears real good in the dirt. With all stock motor and 3spd auto, you should decide if you want acceleration or mileage since there's essentially no power to work with anyway. Going to 35's all stock I think at least 4:10's would keep you from accelerating like a snail.
78' J-9, 96' XJ
86 stock gears and tires srobertsfsj General FSJ Tech 2 04-28-2010 10:38 AM
Choosing gears ksq2 General FSJ Tech 21 04-15-2010 09:49 PM
What size tires for the Wagoneer? WWI Flying Ace General FSJ Tech 11 03-25-2010 08:51 PM
New tires won't stay balanced RottenDog General FSJ Tech 9 11-12-2003 02:48 PM
Swapping gears from old to new, will it work porkchop Drivetrain 0 08-17-2000 03:56 PM
