View Poll Results: What gear ratio do your run with your 35" tires
4.10
76 |
43.68% |
4.56
59 |
33.91% |
Stock gears
24 |
13.79% |
Other
15 |
8.62% |
11-15-2010, 01:08 AM
Thread Hi-Jack
I was just wondering the same thing to myself. I am running a Ford T-18/Twin stick 205 behind a sound running 360 in a 1984 GW
/Thread Hi-Jack
11-15-2010, 09:41 AM
Originally Posted by _jeff_
if i remember right my 90 gw came with 2.72. yuck!
i went with 3.31 and run 35's most of the time.
i like it well enough for most situations...but sure wish i'd put in a lower gear when i pull my 4-lo lever.
I just picked up an '89 Waggy running 36's. The PO didn't know what gears were in it. Checked the gears and they are... 3.31's. Interestingly, that is comparable to running 2.73's w/29" tires.
Power is adequate around town and on the Interstate. I certainly don't want a hot rod that will out accellerate it's ability to stop.
11-15-2010, 11:11 AM
Always Broke
Hey Dbblankenbaker... welcome to the forum from another 'valley of the sun' member.
01-19-2012, 09:42 AM
I'm glad someone brought this thread back to life. I wanted to give everyone an update. I did end up going with 4.56's and for wheeling it was awesome! Felt like I had a ton of power.
BUT, what I found is that it was completely un-driveable on the highway. At 65mph I was doing 3200rpm and it was just too much. The engine temp would creep up. That being said I went back to 4.10's and I am liking it much better now. It doesnt feel like I am going to blow up the engine when running down the highway. Its also nice having an accurate speedo.
Scott R.
'86 Grand Wagoneer Super Chief 360 / TBI / WT conversion / 35x12.5x16 BFG Mud-Terrains ( Project Link)
01-19-2012, 09:46 AM
360 AMC
Since I posted in this thread, I found some J20 axles and swapped them in with 4.56 gears and 35" tires. It does scream on the freeway too much. But I also have a 700R4 overdrive waiting to go in this spring when the weather warms up enough to do it. So since I don't have to do any highway driving, I'm living with it as is.
If I wasn't going to go with the overdrive, I would have gone with 4.10s.
01-19-2012, 10:21 AM
I split the difference and went with 4.27's.
http://s781.photobucket.com/albums/y...gy%20Wheeling/
79' Wag 360, T-400, QT w/ pt, cs-144, TFI, 4" lift, 33" BFG KM 2's, 15x10 mags, tube bumpers. "Green Machine"
77' Wag 401, T-400, QT, HEI, 4" lift, 35" MTR's, 4.27's, Detroit R / Spartan F, 15x10 steelies, chop-top, full cage, pre-runner bumpers, 8 passenger. "Battle Wagon"
01-19-2012, 01:02 PM
An FYI to FSJ'ers who are thinking of 4.27's/4.30's...
Virtually all 90-97 Isuzu Rodeo's and Honda Passport's came from the factory with Dana 44's in the rear axle, with 4.30 thick gears. Gotta use the old body style, the boxy ones are the ones you want, the curvy ones won't work. Pull two sets, and you've got your gears.
The 4.30 thick gear lets you use your stock 2.73/3.31 gear carriers, saving you the cost of new carriers.
Just some useful tech.
1990 GW:
Mopar 440/727/229/D44F&R
10:1, XE250H, DIY TBI. 4.10 locked f/r, SOA/SF, high steer, all the other fancy goodies. Check out my build on FSJNETWORK.
01-19-2012, 04:27 PM
I have 35's with a 700r/ 241c conversion. I have the upgraded hi and low range kit in the 700r conversion. I also have the 4.27 spicer gears. I also have (just installed) the dakota digital dash. I can cruise at 70mph in OD at a bit over 2600 rpms. I have only had it back for a day so I will re-check the calibration in another couple days on the dashboard for accuracy.
01-19-2012, 04:54 PM
360 AMC
I would check to make sure you're getting into OD with RPMs like that. The way I calculate it, you'd get around 2600 in 3rd gear (1:1) on the highway. If you hit overdrive, you should drop down closer to 1800-1900ish
01-19-2012, 06:43 PM
[quote=Suddendeath]An FYI to FSJ'ers who are thinking of 4.27's/4.30's...
Virtually all 90-97 Isuzu Rodeo's and Honda Passport's came from the factory with Dana 44's in the rear axle, with 4.30 thick gears. Pull two sets, and you've got your gears.
Note on this swap....the Isuzu pinion bearing is bigger than the waggy dana 44. No problem if you are using the bearings that came with your doner. If you are looking to replace the bearings while you have it apart, call up Randy's R&P and tell them you have Isuzu gears and they will put a bearing kit together for you (if you order a standard dana 44 kit, the pinion bearing will be the wrong size)
If anyone is interested in this swap, I have two sets of the Isuzu 4.30 gear sets (with bearings) for sale... I want 100.00 plus shipping for the both of them. Thought the Detroit locker I had was 3.73 and down, but it was a 3.92 and up, so the Isuzu thick cut 4.30's wouldn't work with it.... I had to buy new gears.
01-20-2012, 03:50 PM
hmm, I'ma take a day or 2 and think about this.
Jeeps are Jeeps, keep Jeepin
>It's not about the ten hour drive to get the rust bucket jeep, it's about where your your going when it's done
87GW 99 Durango 5.2 drivetrain, SOA 35in Falken Wildpeak. MT rims
1997 Ram 1500 5.2 33in Falken Rocky Mounts for haulin
01-21-2012, 03:04 AM
I'm only going to 33's, so I am gonna load up 3.92's. But, if I was going to go any bigger, I would probably go with the 4.10's. The 75 is family rig however, and most of mine is still under 5'3".
'75 Wagoneer, bone stock, about to be a whole garage of parts. Tear down starts 3 March, 2012,
see how long it takes to put it back together....
'91 XJ, 3 in Rough Country lift, 33's, Rattle can paint job, roof rack and cheapo off road lights. Diffs and winch next
04-25-2012, 02:06 PM
Gone,Never Forgotten.
well
I'm running 3:31's with 33's & wouldn't have it anyother way. I've got low range for off road so I guess I don't get it. Looks like a waste om money to me. I'm running 3 K at 35 MPH I couldn't stand any lower/ 4:56 with 35 would be doing 3K at about what 55?
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
04-25-2012, 05:07 PM
I ran 35" tires in my 75 waggy with stock D44's loaded with 3.54 gears.
It wasn't a drag racer off the line, but I could cruise at 70 mph and keep up with traffic while being able to talk to my passengers.
Off road the QT did pretty good by providing me plenty of torque.
I did anything from dune running to snow wheling to mud and rock crawling on the Rubicon, it worked fine.
I could have been better with the 4.10 but it was cheaper to stay with the stock axles.
IceMan
05-01-2012, 09:40 AM
I ended up with 4:27 in my wagon with 35"s and an 700r overdrive.
I think that 4:10's would have been fine with its current power curve the way it is. I am not sure what the stock power curve is for an AMC 360 (2100-2500rpm?)
She seems to cruise at 60mph 2000rpm right now, that is if the dakota is calibrated correctly.
05-02-2012, 04:13 PM
Im running 5.38's with 35's. Sure my spedo is off by a lot. Yeah i get really bad gas milage. But when you are on the trails that power makes all the difference
'79 J10/360/T400/Quadratrac/Bone Stock
'78 J20/360/T400/Part time conversion QuadraTrac/6" lift with 35's
05-07-2012, 10:51 PM
I have 4.10s with O/D, but my tires are 40"
01-25-2013, 07:57 PM
so according to the calculator I would need 42 inch tires and 410 to be back to stock I have 272 gears now with 29 inch tires 360 with an auto trans?
01-26-2013, 11:44 PM
It'll act like you have 2.8 ratio
01-27-2013, 03:49 PM
My waggy has 4.10 thick gears. with 33x12.50's on it was a little much at freeway speeds. I was around 3K at 65-70 with the 727. I did swap to a manual Np435/205 and that lowered my RPMs a bit. about a 180-200 RPM difference at freeway speeds.
When I stepped up to 36's, I lowered those RPMs a couple hundred more. The tires (HMMWV Bias Ply Goodyears) were sustantially heavier but once up to freeway speeds, the cruising was much better.
For me, the most significant change to gearing (for the money) was the tranny swap.
The super deep low end gears in 1st (granny) and 2nd was a much bigger difference than the initial differential gear change, and I still had a good ratio on the top end for cruising. With 33's on the truck, I should have kept the 3.31's and been fine with the tranny swap. My truck hasn't been wheeling in 4-Lo since I installed the Granny 4-speed. Just doesn't need it. All in all, the axles gearing cost me about $900 and was a good improvement on the low-end but didn't help at all for highway driving. The trans/T-case swap cost me about $600 and was a way bigger bang for my buck. Low end gears are way deep, and I still had tall gears for street driving in 3rd and 4th gears. The drive train strength improvement is also a major plus and maintenance on a manual is less of a factor. Just took a lot of research and sweat.
A change to axle gearing is necessary for a big tire size jump, but for those considering a trans swap, do that first and see where you are at before you throw money into axle gearing. you may find you are overgeared or spent money that may have suited you better in other places.
ROMANS 12:1-2
'89 GW deceased
Ford 4spd swap Np435/205
Thread Tools |
Display Modes |
