View Poll Results: What gear ratio do your run with your 35" tires
4.10 76 43.68%
4.56 59 33.91%
Stock gears 24 13.79%
Other 15 8.62%
Voters: 174. You may not vote on this poll
Old 08-05-2010, 10:23 AM
4.27's?
Old 08-06-2010, 10:21 AM
overland_YJ's Avatar
overland_YJ overland_YJ is offline
i have a 90 GW, freshened 360, TF727, 4:10's, 35-12.50 tires, ARB in front and lock-rite in the rear.
i pull a (1600lbs) camping tent trailer sometimes, i also pull a car hauler with trail rig on it sometimes (5500lbs total), do some mild wheelin and it gets about 50/50 on road and off road. i was stock with 3:31's so figured the jump of almost a full ratio to 4:10's would be a big differance..... it wasn't. i wish i had gone to the 4:56's. i still might. the biggest time i wish i had gone lower is on those long hills pulling the heavy trailer, the small trailer is not as bad but i still wish i had gone lower. even when i am not pulling a trailer there are times i could use the lower gears.
these things arent race cars, you'll like the lower gears better IMHO.
1990 GW, 6" lift, 35" KM2's....a work in progress
Old 08-06-2010, 11:47 AM
CutterN55's Avatar
4.10's. for highway/offoad. I have them with 33's for now...and bought them knowing I'd go to 35's or 36's. With the doubled ratio in 4lo it's plenty of gear.
If I throw a T-18(T-18A if I can get one) and/or a dana 300 (4:1 would be sweet) I'll go to 36's and have good highway miles and lots of grunt for wheelin.
ROMANS 12:1-2
'89 GW deceased
Ford 4spd swap Np435/205
Old 08-06-2010, 12:31 PM
shimniok's Avatar
shimniok shimniok is offline
I run 3.73's with 33's which gets me back to the stock gearing (which was 29" tires with 3.31 gears). Hwy rpms are 2600-2800 depending on speed. Never feel like I'm winding out the engine too much. Power isn't superb on the mountain climbs, but glad I went with that gearing instead of 4.10's because I'm pretty sure it'd bug me to be spinning 3000+ rpm at hwy speeds.
Michael
PS: I can also shift into 2nd running around 55-65 without feeling like something will explode, and 2nd solves power problems on the mountain climbs.
Old 08-06-2010, 12:35 PM
will e's Avatar
will e will e is offline
Always Broke
Michael
LOL, the solution is to turn up the radio, then you can't hear the engine.
Old 08-06-2010, 12:51 PM
Gambler68's Avatar
Rabble Rouser
I run 3.54 with 33 MTs and spin 2800-3000 from 55-70, 3500+ from there up.
There is a difference with an auto and a stick too which gearing you want to use.
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 08-06-2010, 01:03 PM
CutterN55's Avatar
I was thinking that too, I looked at that neat little gear ratio calculator, and it shows 3rd gear in the 727 and 4th gear with the T18 both to have a 1.00 ratio. not sure if that matters or not.
the rpms at 65 are only a couple hundred different with 4.10's and 35's.
727 showing 2500 and T18 showing 2700. not sure why the difference if both are 1.00 in the top gear.
ROMANS 12:1-2
'89 GW deceased
Old 08-06-2010, 01:38 PM
Gambler68's Avatar
Rabble Rouser
I would think it'd be a matter of the auto slush and using a liquid filled torque converter, vs a static unvarying load on a gear driven stick transmission.
Old 08-06-2010, 08:40 PM
temps425's Avatar
temps425 temps425 is offline
I really like 410s on my 35s. I wouldn't go any lower. Its low end power vs top end speed
Old 08-06-2010, 08:49 PM
shimniok's Avatar
That sounds wrong. The non-lockup torque converter will mean slightly higher rpms than the manual, if anything. If the calculator isn't sophisticated enough to consider/predict torque converter slip then they should be exactly the same.
Old 08-06-2010, 10:20 PM
It depends on the condition of the clutch & pressure plate on the manual and the overall condition of the auto tranny. I gained about 1.7 mpg when I put the rebuilt 727 in my GW. Is there an option to select worn out 727?
Old 08-06-2010, 11:41 PM
CutterN55's Avatar
Hey I switched the RPMs with the 727 and the T18. Had a rough few days.
The T18 was showing 2550 and the 727 showed 2700 at 65mph with the same data.
I used the Grimmjeeper calculator and here was my inputs...
727
NP229
4.10's
35's
T18
NP208
4.10's
35's
Both T-cases have same Lo ratio's I think... 2.61
The T-18 is lower by a little under 200 RPM's at 65, but I'm still not sure why if they both have a 1.0 ratio at final drive gear. Maybe it's the torque converter like you said.
ROMANS 12:1-2
'89 GW deceased
Old 08-07-2010, 07:10 AM
jeeping1974's Avatar
One thing I'm surprised nobody asked including me (Unless I over looked it) is what is the vehicle going to be used for?
Obviously on-road, but how much off-road are you going to be doing and is it just Class VI roads or something more challenging? Are you planning to go out once a month? Every weekend? Once In a while?
Why not same up for a underdrive unit (i.e. Black Box, Klune, etc.) then you can keep your gears for the street and still have plenty of gearing for off-road.
03 GMC 2500HD - DD/toy hauler
06 Street Glide - Cruiser
Old 08-07-2010, 09:38 AM
srobertsfsj's Avatar
srobertsfsj srobertsfsj is offline
50/50 on/off-road, snow and ice on-road in the winter. I like to drive to the closer trails but will trailer on the long haul trips (Ouray, Moab, New Mexico). I use to like to try the tougher trails but I am getting tired of tearing everything up so I usually do 8 out of 10 or below rated trails.
Scott R.
'86 Grand Wagoneer Super Chief 360 / TBI / WT conversion / 35x12.5x16 BFG Mud-Terrains (Project Link)
Old 08-07-2010, 10:03 AM
will e's Avatar
Always Broke
I double my vote for 4.56
Old 08-07-2010, 09:29 PM
shimniok's Avatar
That's the only thing that would make sense. And that's also pretty close to what I see on mine (727) altho I have a low stall converter so it is a little tighter. I am at ~ 2600 @ 65.
Old 08-08-2010, 04:22 AM
If you trust your FSJ to make the longer trips, 4.10 gears (maybe even 3.92 gears) and an underdrive unit or doubler would be great then. I know it's more money overall, but just some food for thought.
Old 08-08-2010, 07:11 AM
Blake Blake is offline
I used to have a Scout II that was running 33's on the stock d44's with 4:10's. Stock 727.
It was geared to low on the hwy. Hwy speeds kinda sucked. Low range sucked as well because the crappy D20 'case only had a 2:1.
I think you should run some "thick" 4:10 gears in your stock axles on 35's.
Old 08-22-2010, 10:27 PM
68_Gladiator's Avatar
68_Gladiator 68_Gladiator is offline
is this all based on stock motors? ill be running 4.10's and 35's but my motor has 450 flywheel hp estimated 350-385 wrhp. will be a 50/50 on/off road daily driver. not trying to jack the thread
"Go Brow or go home"
1973 J2000
Old 08-27-2010, 06:32 PM
AlsChopShop's Avatar
because it will see the road, go with 4.10s. more options that way in used axles, too.
Al
86 stock gears and tires srobertsfsj General FSJ Tech 2 04-28-2010 10:38 AM
Choosing gears ksq2 General FSJ Tech 21 04-15-2010 09:49 PM
What size tires for the Wagoneer? WWI Flying Ace General FSJ Tech 11 03-25-2010 08:51 PM
New tires won't stay balanced RottenDog General FSJ Tech 9 11-12-2003 02:48 PM
Swapping gears from old to new, will it work porkchop Drivetrain 0 08-17-2000 03:56 PM
