View Poll Results: What gear ratio do your run with your 35" tires
4.10 76 43.68%
4.56 59 33.91%
Stock gears 24 13.79%
Other 15 8.62%
Voters: 174. You may not vote on this poll
Old 05-01-2010, 06:53 PM
srobertsfsj's Avatar
srobertsfsj srobertsfsj is offline
What gears with with 35" tires?
Using this calculator http://www.grimmjeeper.com/gears.html I come up with 4.10 being the closest match to stock RPM at 65mph and 35's. I am on the fence with upgrading to 4.10 or 4.56 to get a little more power. I was wondering what you guys are running with your 35" tires and why?
Scott R.
'86 Grand Wagoneer Super Chief 360 / TBI / WT conversion / 35x12.5x16 BFG Mud-Terrains (Project Link)
Old 05-01-2010, 06:54 PM
The Colonel's Avatar
What is you intended use for your vehicle? Highway? Off road only?
Old 05-01-2010, 06:55 PM
50/50 offroad/highway. Nothing extreme offroad tho, maybe 5 to 8 rated trails.
This is a Waggy with 727/NP228
Scott R.
Old 05-01-2010, 07:39 PM
mattmopar440's Avatar
4:10 are your best bet
with a 3 speed It's going to be a singing @ highway speeds tho 3:73 might be a better thought
87' Grand Wagoneer
80' J10 4BT/AX-15/208
74' J10 Go Grabber Green Sold
Inferior Chevy
Old 05-01-2010, 07:44 PM
3.73 would not be ideal for 35s since your stock gear ratio is probly 3.31 or 3.07 id go with the 4.56s
-Jonny B.
AMC 401 - Pro-FLo 4 FI
F D44 - 4.10, Eaton E-Locker
R M23 - 4.10, Detroit Locker
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Correct my stock gears are 3.31's.
Scott R.
Old 05-01-2010, 08:07 PM
derf's Avatar
derf derf is offline
360 AMC
4.10's would put your RPMs pretty close to stock waggy with 3.31's. Just a hair higher on the freeway. Given the extra rolling resistance of bigger tires, that's probably about right if you're shooting for stock levels of performance.
Try out my gear ratio calculator
Old 05-01-2010, 08:09 PM
JohnnyJ's Avatar
JohnnyJ JohnnyJ is offline
I had 35s on my 75 Wag with 4.10s and it wasn't too bad for highway cruising and still did fine offroad.
I would only run 35s and 4.56s with OD.
Past Project: Stock Class TREC Racer Build Thread
Current project: bringing back my 75 Wagoneer
Old 05-01-2010, 09:43 PM
True, thats why I voted 4.10...forgot its a DD and a 3spd
-Jonny B.
Old 05-01-2010, 09:57 PM
Subic Jeep's Avatar
Subic Jeep Subic Jeep is offline
Talking 4.10
The strongest combination is 4.10 if you change ratio its perfect time to install lockers, its the same amount of work
My 75 Wagoneer, I changed from 3.54 to 4.11 and installed ARB lockers, tires 36x14.5x15 perfect combination very capable offroad. Freeway performance was like stock, fuel consumption 16.2 MPG in 2WD in winter 9.2 MPG in 4WD
I did not renew the ball joints in the Dana 44 so I ripped off the right front wheel and right drive shaft....
I never replaced the right side broken drive shaft just used it as 3WD until I sold it, well this is about 19 years ago... (360/T18/Dana20)
Now lets see if history repeats its self with the Dana 60, 30 spline outer shafts...
Lars
I am in the five bananas category!
Cherokee 1981 officially 1974 huh local irony
Gen 1 GM-SB 350 V8 TBI - TH400 - Klune V - Twin stick NP205 w. Nippon shifter
Dana 60 w. ARB locker, hydraulic assist + GM 14FF w. Detroit locker.4-link rear on LC80 19mm coils
Rancho 5036 Shocks 14 inch travel. 39.5x15.5x15 TSL
Old 05-03-2010, 08:55 AM
Josh D's Avatar
Josh D Josh D is offline
I'm running a short 35" and 4.10's and it's spot on.
'71 J2000 Gladiator
'95 YJ on Waggy axles
'80 911 Super Carrera
Old 05-04-2010, 02:38 PM
I was gonna go 4.56 for 35s but found it was easier and cheaper to find axles with 4.10 and potentially a locker already installed then setting up axles from scratch with 4.56 gears.
Old 05-05-2010, 11:42 AM
madmikeX3's Avatar
madmikeX3 madmikeX3 is offline
I'm running my stock 3.31 gears with 35's on my 80 chero 4 speed. Does real well on gas. Cruises along not screaming at 55-70 MPH and I can still spin the tires.
Just Empty Every Pocket
US ARMY
1980 Jeep Cherokee W/T
“Nice Jeep Bro!!!! Do some Jeep Stuff!!!!.”
Old 05-06-2010, 09:00 PM
will e's Avatar
will e will e is offline
Always Broke
i went with 4.56 in my truck with 35" tires.
My buddy Kevin went with 4.10 and wishes he had 4.56
it winds a little high at 85 mph but when wheel'n it is good to have the gears.
Old 05-08-2010, 12:09 AM
j10jim's Avatar
j10jim j10jim is offline
I went with 4:30's (split the diff between the 4:10 and 4:56). When I get it running good I will post, but around the neighborhood it runs much better than the old 2:89's did!
1980 J-10<br />Rusty\'s 4 inch lift<br />2 inch body lift,<br />35 in Xterrains on J20 axles<br />4:30 gears<br />Detroits<br />In-Cab cage thru the dash
Old 05-08-2010, 05:30 AM
jeeping1974's Avatar
I was going to say what j10jim said, just split the difference (4.27 or 4.30 depending on who you go through for gears). You will still have teh gearing for off road and your onroad RPMs will not suffer that bad.
03 GMC 2500HD - DD/toy hauler
06 Street Glide - Cruiser
Old 05-08-2010, 10:47 AM
Hmm, interesting, didn't even know I could get 4:30 gears. Looks like they are a bit more and would probably be harder to find used. But no I have an even tougher decision, lol.
Scott R.
Old 05-08-2010, 09:42 PM
derf's Avatar
360 AMC
I don't think you can get them for the AMC20. For the Dana 44, you can get 4.27's which are close enough.
Old 05-09-2010, 09:04 PM
El Jefe's Avatar
El Jefe El Jefe is offline
I went 4.10's with 35's and wish I woulda went 4.56's. But my jeep never sees the freeway.
Alex
76 Cherokee Chief
350/th400/d20
d44/14b
4" lift, 35 inch retreads
Old 05-11-2010, 11:48 AM
_jeff_ _jeff_ is offline
if i remember right my 90 gw came with 2.72. yuck!
i went with 3.31 and run 35's most of the time.
i like it well enough for most situations...but sure wish i'd put in a lower gear when i pull my 4-lo lever.
86 stock gears and tires srobertsfsj General FSJ Tech 2 04-28-2010 10:38 AM
Choosing gears ksq2 General FSJ Tech 21 04-15-2010 09:49 PM
What size tires for the Wagoneer? WWI Flying Ace General FSJ Tech 11 03-25-2010 08:51 PM
New tires won't stay balanced RottenDog General FSJ Tech 9 11-12-2003 02:48 PM
Swapping gears from old to new, will it work porkchop Drivetrain 0 08-17-2000 03:56 PM
