Old 02-04-2006, 12:35 PM
Spectre's Avatar
Spectre Spectre is offline
I'm nearing the end of the installation of an analog Holley EFI system. I've got most of it figured out, but my instructions are rather vague on where I should connect a couple of wires.
Situation: 86 GW, TFI upgrade in place already.
1. The white tach pickup wire: does this go to the negative side of the TFI coil? The aged manual isn't very clear. On the one hand it says to install it on the negative terminal, on the other it says to *not* connect anything to the terminals of a capacitive discharge ignition (which the Duraspark appears to be).
2. The red main power lead/relay setup: Do you connect this to the red wire on the Duraspark box, as the instructions imply, or do you just tie the relay to switched power?
Pictures would be appreciated. I'm hoping to get this thing reassembled and started tonight, it's really starting to irritate me because it's been apart for the better part of a month and I need to give the space up. Any assistance would be appreciated.
Edit: Deleted old thread due to hijack - reposted to get to the top again. [img]smile.gif[/img]
[ February 04, 2006, 06:37 PM: Message edited by: Spectre ]
"Battlewagon": 1986 Jeep Grand Wagoneer (w/ Tow Pack) - Urban Assault Wagon under construction - TFI, TBI, CS144, Aftermarket Sanden, Explorer Power Seats, 4" Lift, 16" AHI wheels and much much more; click here for a full list of modifications and gear, links to writeups/posts and more info.
Daily Driver: Modified 1987 Jaguar XJ6 Vanden Plas.
Old 02-04-2006, 01:10 PM
Michael's Avatar
Michael Michael is offline
Spectre. It is an 86 should be same as mine. Call me. 817-283-8339
1994 YJ
Amc 360
TF727
Stak 3 speed
44" Pitbull Rockers on Trailworthy H1's
Rockwells
76' Wagoneer
401....new project
Tow Rig Daily Driver// 2007 6.7 CTD Dually
Old 02-04-2006, 01:11 PM
Michael's Avatar
Connect it to the opposite of what it says. The green wire I believe on your coil....call me.
1994 YJ
Amc 360
TF727
Stak 3 speed
Rockwells
76' Wagoneer
401....new project
Old 02-04-2006, 01:25 PM
Michael's Avatar
White wire to the green wire on the coil, this is for the tach signal. It will not work going to the negative wire, yellow...
Red wire to relay goes to 12v source, then the other side of the relay goes to a 12v switched source. The full instructions are on Holleys website. Or just call me. Sounds like you are almost there.
What did you do with the pink wire???? My instructions were wrong.
1994 YJ
Amc 360
TF727
Stak 3 speed
Rockwells
76' Wagoneer
401....new project
Old 02-04-2006, 02:30 PM
Spectre's Avatar
Power went out in the garage, so I had to knock off for the night. I'll call you in the AM when I get back to it. I'm working on the thing in Coppell, btw.
Old 02-04-2006, 02:34 PM
derf's Avatar
derf derf is offline
360 AMC
If you need an extra set of hands in the AM give me a call. 817-456-9758
Try out my gear ratio calculator
Old 02-04-2006, 02:36 PM
Spectre's Avatar
That would be appreciated - I'll give you a ring too. [img]smile.gif[/img]
Old 02-05-2006, 01:01 AM
Michael's Avatar
I am up and around give me a ring, I am just south of grapevine/colleyville so I am not too far, I have nothing major going on today, I can spare a couple of hours. I downloaded Holleys instructions to my laptop to be safe. I can bring them with me, but I remember most of it in my head.
1994 YJ
Amc 360
TF727
Stak 3 speed
Rockwells
76' Wagoneer
401....new project
Old 02-05-2006, 01:03 AM
Michael's Avatar
my mobile is 817-675-8102
1994 YJ
Amc 360
TF727
Stak 3 speed
Rockwells
76' Wagoneer
401....new project
Old 02-05-2006, 03:14 AM
AM Woody AM Woody is offline
Thumbs up
Sounds like you guys have it handled, but I should be around today in case you want me to look at anything on mine.
- Andy M.
89 Grand Wagoneer: White/Cordovan. Factory tow package. Gradually undoing PO's mods - it seemed like a nice build at the time.
Status: Operational
Old 02-06-2006, 12:22 AM
Michael's Avatar
Spectre did you get it running? Sorry I had to leave out on you early, call me and let me know how it is doing!!!
1994 YJ
Amc 360
TF727
Stak 3 speed
Rockwells
76' Wagoneer
401....new project
Old 02-06-2006, 03:00 AM
Spectre's Avatar
Nope, I had a weird power problem - 12V on one side of the rig, 5V at the relays. I'm still trying to figure that one out. I know it's not resistance wire.....
Old 02-06-2006, 05:48 AM
Michael's Avatar
This does not make sense Spectre. Since you power up the relay with battery voltage and 12v swictched......obviously something is not right. Call me tonight if you end up looking at it.
What did you use for the 12v switched side of the relays????
1994 YJ
Amc 360
TF727
Stak 3 speed
Rockwells
76' Wagoneer
401....new project
Old 02-06-2006, 06:09 AM
Spectre's Avatar
I tapped into the appropriate wire on the solenoid.
What I'm getting is 12V into the relay and 5V out.
Old 02-06-2006, 06:19 AM
Michael's Avatar
So you have 5v out to the ecu? Try swapping in another relay.
1994 YJ
Amc 360
TF727
Stak 3 speed
Rockwells
76' Wagoneer
401....new project
Old 02-06-2006, 06:47 AM
Spectre's Avatar
Yeah, I bypassed the relays entirely, ran 12V to the computer. Nothing. The ECU *is* tripping the fast idle solenoid and I have the TPS adjusted correctly, but it's not firing the injectors. Any ideas on how to get those to fire or check them?
Old 02-06-2006, 08:52 AM
Spectre's Avatar
Got it running, beginning to troubleshoot odd running conditions. [img]smile.gif[/img]
