  #61
Old 08-25-2015, 12:26 PM
BA_051 BA_051 is offline
Now in having an idle issue with the TBI... Was great on the old motor... It likes to stall when you pop it in neutral and back off the gas when you come to a light... But it starts right back up and idles perfectly fine... I need to mess around with my idle VE and maybe throttle follower settings...
(12v swap in progress) 1974 Jeep J20, gladiator grill, 12v p7100 cummins, Modified He351, 4" strait piped, NV4500/Ford NP205, D60HP, 14b, 4.56's, 12" lift, 37x12.50x16.5's
Old 09-20-2015, 10:11 AM
It's been a while since my last posts so here's an update...
I enabled the throttle kicker logic and disabled the error code and added about 10% to the idle VE table and no more issues!
I have 500 miles on the motor now, already had its first oil change 300 miles ago...
First and second gear are real hairy on wet/slick roads even with 3.73's and 37"s but will break them loose with ease... Sooo much more low end grunt then the 360/k8600... Pulling 7500 lbs is nothing to it now....
Now it's time for a 5 speed...
Old 01-03-2016, 11:37 PM
How's the engine running?
Do you have a thread on your 5 speed swap?
-Jonny B.
D20 - Twin Stick'd
F D44 - 3.54, Open
R D44 - 3.54, Lock'd
1984 J10 - Parts
1979 Cherokee Chief - Parts
1979 Wagoneer - Sold
1981 Cherokee Chief - Cubed
Old 04-04-2016, 05:41 PM
The 406 runs awesome with the 5 speed. running at 70 mph on the highway is about 2200 rpm and never need to shift it.
I actually have swapped in an NV4500 in early February 2016 but didnt do a build or swap thread on it since it was covered so many times on many forums.
Its from a '95 GM 1 ton and needed a complete rebuild and was 2wd.
It needed a new input shaft, countershaft gear, and 2nd and 3rd gears had small chips... I put in a dodge 29 spline 4wd mainshaft, new GM input shaft, new 1 piece dodge diesel countershaft, new 2nd, 3rd, and 5th gears, all new bearings, syncros, seals, shift forks, the works. Almost everything in it is new except the top cover and parts, reverse idler, 1st gear, and the syncro hubs. Even put on a new cast iron dodge tailhousing.
I bought the advance adapters bell housing adapter to my AMC 406 and the 29 spline input gear adapter for my ford NP205. And I even re-geared my D60HP and 14B to 4.56's at the same time.
But now I am wanting to sell the 406 and swap in a 6.5 NA diesel, specifically from a 2001+ HMMWV...
Old 09-12-2019, 11:06 PM
j2sax's Avatar
j2sax j2sax is offline
406
Just out of curiosity, what was it that you did not like about the 406 that the Diesel would fix? How did it run in the FSJ?
Jesse- Sparta, MO (Near SPfdl MO) J20 4 Door Project, Wag w/ 6" Rusty's, 33x12.5's, 360/727 (for now!), 77 J10, 80 J20, 3 80's Wags, 73 Commando, Lots of AMC Eagles, FSJ parts Rigs and parts
Budget AMC 360 stroker build - 383 Cubes! Greg Taylor General FSJ Discussion 140 05-07-2014 02:26 PM
More stroker build questions (getting closer) IslanderOffRoad General FSJ Tech 20 05-14-2006 08:23 PM
