Old 06-18-2019, 11:18 AM
gophman's Avatar
gophman gophman is online now
Oil pump to gears clearance
A bit of background, my '73 360 j4500 had extremely low hot idle oil pressure when I first got it. I replaced the oil pump gears with a Melling kit and and dressed the filter adapter as it was scored, it still had only approx 5 psi hot idle with 20/50 oil (cheap mechanical gauge) I checked crank bearing clearances and all came in within spec apart from one big end that was about 1/2 thou out. I have pulled the timing cover off as motor is out at the moment and plastigaged the gear to adapter clearance and I have 4 thou.
I know you are shooting for 1.5-2 thou ideally but how much of a difference in pressure is around 2 thou less clearance going to net me? I'm pulling the cam tomorrow to check condition of the cam bearings.
Old 06-19-2019, 11:17 AM
gophman's Avatar
I think I found the issue, front cam bearing delaminated and the rest worn.
Old 06-19-2019, 03:55 PM
Crankyolman's Avatar
That's what drove me to rebuild my engine
'72 J4500
Old 06-19-2019, 04:57 PM
jeepman1's Avatar
jeepman1 jeepman1 is offline
Cam bearings
Didn't change cam or rod bearings, I have great oil pressure for a while, then its gets hot (normal) and she goes way down.. I think I'll try a man. gauge and see what it really has.
: 98 9er
'83 Honcho j10
'12 Liberty Ltd.. wifes
'19 Chaparral H2o Dlx sport 21
fuel pump Mike7009 General FSJ Tech 10 03-29-2011 05:17 PM
Electric Fuel Pump Installation w/ relay leostevo General FSJ Tech 0 03-21-2011 06:07 PM
fuel pump stalling issues westcoastflea General FSJ Tech 8 07-21-2009 08:40 AM
Electric Fuel Pump BigAWagoneer General FSJ Tech 3 03-05-2005 11:12 AM
How hard is it to change out an oil pump marine02 General FSJ Tech 33 07-26-2003 06:04 AM
