Old 01-25-2011, 05:13 PM
JacobNL's Avatar
JacobNL JacobNL is offline
Question Which AMC 360 engines would fit my 1990 GW?
Hello all,
Sadly, last weekend I've blown the engine of my 1990 Grand Wagoneer, so I'm looking for a replacement engine. I've posted a classified on the Dutch Jeep forum for a 360 AMC engine, and so far I've had two responses.
Since I have been offered engines from 1978 and 1979, I'm wondering whether these would fit my car. I know quite a bit about Wagoneers (as in: I've read a lot of forum posts and articles), so I've read that as for engine specs not much has changed over the years since 1978, but I'm not a mechanic.
In short my question is: could I fit a AMC 360 engine from 1978 or newer into my 1990 Grand Wagoneer? I do obviously have a different transmission than some of the older models but I guess that should'nt be a problem.
Thanks in response for replying. If there are any other things to take into consideration I would be happy to hear from you. Any help is appreciated!
Regards,
Jacob
1990 Grand Wagoneer
Old 01-25-2011, 05:19 PM
mattmopar440's Avatar
yes all model 360 amc V8 are the same only difference over the years are the intake and exhaust manifolds
87' Grand Wagoneer
80' J10 4BT/AX-15/208
74' J10 Go Grabber Green Sold
Inferior Chevy
Old 01-25-2011, 05:20 PM
all of em,with the possible exception of the very early ('71-72) engines due to a possible different crank flange.
Old 01-25-2011, 05:30 PM
JacobNL's Avatar
Hi,
@mattmopar440
I guess that since my exhaust manifolds are still intact, I could re-use those? I'm not sure about the intake manifold though, as the engine has overheated. Is that something to take into consideration if I wanted to keep the original carburettor? I have an LPG system installed so keeping it could be important.
@Ristow
I have looked for remanufactured engines (ofcourse, and it's still an option) and I guess I remember one of the sites mentioning that, but I think engines as old as that will probably have too high a mileage to really consider in my case.
Thank you both for your help!
1990 Grand Wagoneer
Old 01-25-2011, 05:31 PM
mdill's Avatar
mdill mdill is offline
Gone. Not Forgotten.
Don't forget to remove the TH400 crank bushing if you get a pre-80 360,
and there might be some accessory bolt size differences that are easy to wok though.
Home of ADHD project list
1977 J-10 Honcho 360-T15-D20
Old 01-25-2011, 05:34 PM
JacobNL's Avatar
Wow! So great to see such useful replies posted in such short time
I'll make sure to tell my mechanic when he swaps the engine, mdill. Thanks!
1990 Grand Wagoneer
Old 01-25-2011, 06:29 PM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
And welcome to the forum!
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 01-25-2011, 07:01 PM
austinaubinoe's Avatar
how exactly did you 'blow' your 360? Is there a whole in the block? I feel like with proper maintenance these motors would be impossible to completely destroy. I mean eventually you will start loosing pressure in the cylinders.
Did you run it dry? I.e did your oil pump go and you not notice?
Need to find the truth on a 360? UTfball68 General FSJ Tech 36 06-29-2008 08:39 AM
1976 AMC 360 VS. 1984 AMC 360 Tim84j20 General FSJ Tech 7 06-14-2008 08:47 AM
258 vs 360 swap Chucks1911 General FSJ Tech 17 02-12-2008 12:47 AM
MoPar 360 swap in........ Dr. Righteous General FSJ Tech 5 07-05-2004 05:51 AM
360 better than 258?? Scruffy Engine 6 07-24-2000 08:04 AM
