Pull the wire harness lead off of the oil sensor, and put an ohmmeter on it.
With the engine off, it should read a low resistance... something like 30-50 ohms.
When the engine is running, it will read higher, something like 200 ohms or so (been a long time since I checked).
Or stop by the local auto parts store and put a meter on their oil pressure sendor for your vehicle. You will at least have a good reading at the low oil pressure side (like with the engine off) and you can compare the two sensor readings.
Or, go to Radio Shack and buy a couple of cheap resistors in the 75-ohm, 150-Ohm, 200-Ohm and 250-Ohm range and wrap the leads around the sensor connection point start the engine and see which resistor give you 80PSI readings... that will tell you the sensor range in resistance.
And...no, at this particular point my Jeep wiring harness is in need of repair, and I cannot at this time go out and measure it for you...
Some help from the collective here? Anyone got a running AMC-360 and a meter?
