Old 01-09-2008, 09:06 PM
4350 Rebuild - Ristow
puttin' a carb together for a pal. thought someone may find it helpful if i showed my work.
4350 motorcraft off a FSJ.
first,remove the top cover screws. 10 of them. they are the larger phillips headed screws. i forgot to snap a pic of the float removal,but pretty simple.pull the pin.
next,remove the clip from the accelerator pump link,at the throttle arm.
there is also a clip on the lower choke link,remove it,to remove the link from the lower arm.
and the top will lift off. this is the underside-what's inside the carb.
here is the main body with the top off.
next,remove the 6 screws holding the throttle body to the bottom of the main body.
and separate them.
next,we'll move to internal dis-assembly.
Old 01-09-2008, 09:17 PM
on the internals,first we'll remove the brass plug,shown here near it's bore,it falls out.note there was a small steel ball next to it,look in the above pic,in the main dis-assembly part,and you'll see it.
next we gently pry the plastic retainer for the needle assy. out to release the needles.
next,the main jets,and needle plunger tube.i used a putty knife as a screwdriver on the tube,it's pretty wide.
accelerator pump ball retainer and check ball...
this is optional to remove.
next...top cover.
Old 01-09-2008, 09:25 PM
on the top cover,we remove the large inlet needle seat,and the smaller plug,i do not know it's purpose.
the accelerator pump plunger,removed by pulling the spring back,and un-hooking from its' arm.
her's the plunger. note the little pin,used to set the pump stroke,that pin is retained by the collar,slid over it when the desired setting is established.
gently pry this cover off,exposing the vent baffle.
the pin for the secondary bell-crank is gently pried out.
this should be an E-clip. remove it,and the secondary linkage in freed...
..releasing the secondarry plunger from the bottom side..
next...throttle body.
Old 01-09-2008, 09:30 PM
on the bottom plate. the throttle body. remove the 2 idle screws.
remove the choke arm..
releasing the pull-off cam.
this brass tube will tap out of the choke housing,releasing the fast idle cam.
leaving the 3 main pieces dis-assembled,ready for dip. i like to loosly re-assemble the main parts before dipping in carb cleaner.....
TO BE CONTINUED.
Old 01-09-2008, 10:10 PM
scantar's Avatar
scantar scantar is offline
Dang, Mike...great pics!
You should do one for a 2150 too...not for me...I'm just asking for a friend.
Old 01-09-2008, 11:56 PM
Gambler68's Avatar
Rabble Rouser
this needs to be archived pronto!
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 01-10-2008, 12:59 AM
mathman's Avatar
mathman mathman is offline
Nice job. Have a couple of questions/additions:
Did you find that one of the screws was longer than the rest? When I did mine recently one was longer and it had a regular slot screw head. The instructions with the kit I used indicated that one should be longer (but the same instructions had an incorrect number of screws.)
I think it's an extra inlet needle and seat - supplies extra fuel under certain situations if I recall correctly.
How necessary is it to remove this? Is it because you dunked it in the carb cleaner? Didn't remove that on mine and wondering if I missed something important.
The service manual advises to use caution removing and installing that tube as it is easily damaged. When tapping it out/in having a support rod in the middle of the tube will help keep it from collapsing.
Looking forward to seeing the assembly process - be interesting to find out what I screwed up in assembling mine (it's still not quite "right")...
David
'78 J-10
'78 J-20
'50 $WD Pickup
Old 01-10-2008, 07:48 AM
janie's Avatar
janie janie is offline
Dexron Impaired
Excellent write-up and pic's Mike. This definitely needs to be archived.
Old 01-10-2008, 09:33 AM
olemisst olemisst is offline
Thanks
I wish you would have posted this about 4 days ago. I've can already tell I did something wrong.
Do you think if the springs on the Accelarator Pump and Secondary Plunger are switch if it will create a problem? I know one is much beefer than the other.
Travis '76 401 Cherokee S
Build Thread
Check Out The Pics
Old 01-10-2008, 11:11 AM
yes,it is a problem. it will give you a weak pump shot on the accelerator pump,and cause your air door on the secondaries to open very late.
mathman,
yes,one longer screw. on that vent,i removed for the carb dip solution. i think i will blank that fitting off,as this carb will be used in a non-emissions application.
Old 01-10-2008, 12:29 PM
caionneach's Avatar
caionneach caionneach is offline
Exclamation Warpage?
Did you detect any warpage between the upper and bottom halves of the carb once apart?
I have a 4350 to install to my 401, and a search of the 4350 on this site revealed that many have had a problem with the pieces being warped after they were separated. In other words, the carb ran fine but needed a rebuild due to age, and after the rebuild the carburetor was warped and did not perform well with the kind of leakage the warping introduced. Several seemed to have this specific problem.
Kenneth
1982 Cherokee
258 cid/T-5 $15 Sunpro Voltmeter gauge
replacement; Quadratec Trailmax Thermal Pro
Seats! 4 inch SKYJACKER suspension lift, 33X12.5 in
BFG Mud Terrain Tires on 15X10 in ProComp Rims.
New BJ's chrome-moly rear axle shafts, 3.73:1 diffs and ARB Air Locker!
Old 01-10-2008, 12:34 PM
I suspect some of the warpage to be caused by over zealous hands twisting body screws too tight or with uneven torque.
Nice work Mike!
I agree, this does need to be archived.
Old 01-10-2008, 06:23 PM
re-assembly begins. there are a few issues i need to deal with before i can fully assemble this,few tattered bolt holes,looks like i don't have the choke pull-off diaphragm,or can't find it anyhow....
but,here is the main assy,from the carb dip.
we'll start with the lower throttle body. putting both idle jets in,3 turn out from gently bottomed.
then,the fast idle cam spindle,and cam. put in as shown. tap spindle fully in,from choke cap side.
then the choke unloader..
put the choke actuating arm on,in relation to the cam and unloader,seen behind.
that takes care of the throttle body for now...
Old 01-10-2008, 06:50 PM
main body next. first,the needle cluster tube,and main jets. put a new gasket on the tube.no gasket on the main jets.
install the tube and jets,firmly,but keep in mind these are soft metals.
next,the needle assy. this o-ring gets replaced. also,see the line on the piston i drew?so i retained factory setting. that is adjustable,for height,with alters when the carb goes to power (rich) mode. those needles replace the power valve enrichment system. low vacuum,the spring pushes the needles up,withdrawing the thick part of the needles from the main jets,reducing flow restriction through them.
insert the spring and plunger...
and install into the body. the needles stick into the holes of the main jets.i have also installed the plastic retainer.
install check ball and ball retainer into the accelerator well.this will be the larger of the 2 steel balls the carb uses.
that takes care of the main body for now...
Old 01-10-2008, 07:01 PM
onto the top cover. the air horn.
remove the old umbrella from the accelerator plunger. this one was so hard i needed to cut it off.
fit the new umbrella,folding it in half as shown,and putting it on the plunger from the side,then rolling it on the rest of the way.
here the pin is installed,i used the middle hole,and the retaining collar is ready to be slid over it.
re-assemble the plunger as shown in the dis-assembly pic,compress the spring,and re-install on its' actuator as shown.
there are 2 inlets,the main needle,and an aux. inlet for high fuel flow situations. this carb had the aux. inlet soldered shut. i'll put the new piece in it's place.
here is both the smaller,aux. inlet,and the larger,needle valve installed,firmly tightened.the accelerator plunger is to the left,installed. the hole i'm pointing the screwdriver at is the emissions vent i'm going to blank off on this carb.
install needle and float.at the moment,i don't have the specific float setting,so i'll use the old standby "parallel with the cover upside down" for now.
next is the secondary air door plunger. take the spring-similar in size to the accelerator pump spring,but much lighter-put the plunger rod through it,then put the rod through the slot in the cover,up towards the top of the carb...
install the bellcrank,starting as shown,it fits one way only.
install the pin,tap into place,then put the link on the door...
then put the other end on the bellcrank,and install e-clip.
getting close to the end now! tha't the primary assembly of the 3 main parts.next we put 'em all together.
TO BE CONTINUED.
Old 01-11-2008, 06:40 PM
final assembly of the main bodies.
flip the middle,main body upside down.there are raised ridges like shown on 2 of the bolt holes. this ensures alignment of the parts,also ensures the gasket is on correctly,as it fits only one way.i like to grease these gaskets.
before the bottom plate is installed,i want to point out the 2 vacuum ports.the small orifice the staples are pointing to. both left and right front ports are "ported" vacuum fitting,little to no vacuum at idle,with vacuum coming in after throttle is opened.it's accomplished simply by putting the ports above the throttle blades.as the blades swing up past those ports,the engines vacuum is exposed.remember,vacuum is under the throttle blades.
notice the right,passenger side orifice is positioned a little higher from the throttle blade than the left,drivers side. that means the right side gets a vacuum signal a bit later than the drivers side.that would make the passenger side port the EGR port,and drivers side the ported DISTRIBUTOR port. the distributor gets vacuum before the egr valve.
position the bottom plate over the main body.drop the 6 screws into place,and snug them,progressively.the allen screws are not stock,i got them since this carb had mis-matched screws when i got it.
flip the carb over. place the small steel ball into shown position. the brass check valve for the accelerator pump is also installed to the right.point down.
the upper gasket also has the locating bosses,indicated by the orange dowels.put the gasket into position.
install the float and needle.the nailhead of the floatpin must be on the shown side,or it will slide out in use.
lower the airhorn into place. you will have the accelerator pump plunger,secondary plunger,float,emulsion tubes....all must be in position,before the top will lower into place. DO NOT FORCE DOWN!
one screw out of the 10 that hold the top on is longer than the rest,it's hole is the one shown by the orange dowel,lower left. all screws will be progressivly snugged down.
after i get the choke pull-off pot for this carb,and do a few things like plug the vent fitting,we'll put all the linkages in place,and do the bench adjustments on the choke.and it'll be ready for service.
Old 01-11-2008, 11:09 PM
J10Joe's Avatar
J10Joe J10Joe is offline
nice write-up, Mike. This goes straight to my bookmarks.
1985 J-10 LWB
258/727/NP208
4" lift, TFI, MC 2100
1988 J20-one of the last ones
8400 GVRW
360/727/208
TFI, Rustolium (brushed)
Fisher/Meyers plow truck
Old 01-11-2008, 11:12 PM
Crazy_Jeepman's Avatar
Sloppy Shifter
If he was not so LAZY!!! I would have had it here this morning. I do have your intake though. I picked it up last night. Joe................he is not really that bad of a guy..............For a Cheese head!! Though his Garage was a MESS! after he bragged in IRC how clean it was
Old 01-12-2008, 12:49 AM
well,there was a wide enough path through the junk for YOU to walk wasn't there?!
Old 01-12-2008, 12:58 AM
Dmntxn77's Avatar
Dmntxn77 Dmntxn77 is offline
Hey watch this...
GREAT write-up!!
