Old 04-01-2004, 07:51 AM
uthrev uthrev is offline
I read alot of problems that sound like mine, but not exactly. I have three and I don't know if they are related or not. If anyone has some advice, I could sure use it. When driving my truck down the road, all of a sudden I realize it isn't running. I turn the key and it starts right up. Secondly it has started knocking quite loudly when I give it gas. I let it sit for awhile because when it would warm up it would stall and not start until it seemed to cool down. Now it is sqealing loudly on top of all the other problems. If you have any suggestions on any of the problems, please let me know.
Old 04-01-2004, 07:57 AM
FSJ Thing's Avatar
FSJ Thing FSJ Thing is offline
Propane Protagonist
Drain your oil and look for glitter. It sounds to me like your oil pump pooped the bed or your filter is plugged, or for whatever reason your not getting enough oil, especially at higher RPMs. Maybe someone else has an idea, but that's what it sounds like to me, and definitely don't start it again until you check the oil!
The Cherowagladabego Project. Updates coming as soon as I do something update worthy.
Old 04-01-2004, 08:06 AM
AzFrank aka Desertson AzFrank aka Desertson is offline
Question
What yrr Jeep do ya have? If it is '79 or older the problem when driving and it quits running is the igniton modual under the hood mounted on the driverside fender well.It has one lead w/ 4 wires and another lead w/ 2 wires. Its ford ignition modual that will cost around $15-20 from AutoZone.
The next problem I would check would be your timming.('79 its 8deg btc)It maybe to far advanced. I would have to say thats why your having the hard starting problem when warm.
the last sounds like a belt,powersteering, alt, you might replace them all. If you do, take some sand paper and go over the pullies to get rid of any glazing the old belts may have left.
Hope this helped.
Respect our Mother Earth,<br />Pack it in pack it out,<br />and Keep-A-Jeepin\'<br />My \'79 Cherokee motto<br />\"Old an slow and wanna be off road\"<br />Her name,Spirit of Arizona
Old 04-01-2004, 08:51 AM
It's an '84 Jeep J10. I was wondering if may be something electronic? Do you think that the knocking is something to do with egr or connected to bad firing?
Old 04-01-2004, 10:45 AM
Chris Barry's Avatar
Chris Barry Chris Barry is offline
Would installing a MSD 6A solve this problem?
'85 Grand Waggy 360/727/NP229 33X12.5R15 2inch susp lift with 2inch body lift.(wife's DD)
'86 Grand Waggy all stock with custom sagging springs
'85 Baby Cherokee 2.5L(my new DD)
'89 Chevy K2500 flatbed
'87 Ford Ranger
'84 Renault LeCar
'84 Honda Passport
'66 Yamaha MG-1T
http://www.jpricefamily.org/joy/Chris-Cars.htm
Old 04-01-2004, 10:49 AM
jode's Avatar
jode jode is offline
JB Welder
Yeah - the MSD replaces the ignition module
No FSJs for the time being - "I'm working on it, I'm working on it" (think Mike Meyers' SNL skit about the gut)
Old 04-01-2004, 10:50 AM
kreb's Avatar
kreb kreb is offline
mostly yes. you can run the msd inline with your stock ignition box. but if it is bad you will have to replace it. or you can run directly off of the msd.
benjamin
Kreboneer
1991 Grand Wagoneer
360/ 2150
4" Rusty's lift 32x11.5 BFG KM, 1.5" block rear MSD/TFI, Pioneer sound
'85 grill, '78 WT wheels
houston, tx
hermanbloom79@yahoo.com
"if you don't have time to do it right, you don't have time to do it twice." - stolen from another board member who's name i can't recall
Old 04-01-2004, 11:42 AM
GreatWhiteJeep GreatWhiteJeep is offline
Id do a full tune up, cap, rotor, plugs, wires, oil, filter, and new belts. The belts sound like that squeaking.
K & W Offroad and Performance
1983 Jeep Wagoneer
360 Amc V-8
T-18 Tranny
Dana 20 T-case
Dana 60 F & R
