Old 02-07-2010, 02:41 PM
gladman's Avatar
gladman gladman is offline
fuel problem...
I got my new old truck running last week... the PO told me he'd had the gas tank cleaned etc, put on an electric fuel pump and new fuel filter... but, no gas seems to be getting to the carb.
I made sure there is plenty of gas in the tank.
I primed the carb with some gas and would get momentarily fired up and running and then seemingly out of fuel.
I disconnected the fuel filter and took off the gas cap, I can hear the electric fuel pump running but no gas is really running to the carb (set on ACC and disconnected fuel line to the carb to see if I had gas running to the carb.
I siphoned gas through the fuel lines to the point where it connected to the fuel pump and was able to siphon 3 gallons with relative ease.
I connected a fuel line into my gas can, ran it to the fuel pump and into the carb (no fuel filter)
I got gas to the carb, connected the fuel line and she fired up for about a minute and then seemingly no fuel again.
When I disconnected the fuel line to the carb, it again seemed like no fuel was getting to the carb.
The fuel pump appears to be brand new... I'm open to suggestions... this one issue is slowing down some major progress...
Any idears? Thanks!
Old 02-08-2010, 09:09 AM
710 Burner's Avatar
I got nuthin'...but here's a bump for the weekday guys.
Mark B. Jones
Old 02-08-2010, 09:19 AM
Float sticking in carb?
Just a thought, don't see above where you have gone into the carb yet.
Old 02-08-2010, 09:31 AM
El Toro J10's Avatar
El Toro J10 El Toro J10 is offline
x2 on Tad's comment. Also, its sounds like the fuel pump may not be working correctly.
1982 Jeep J10 - 360 5.9L V8 - Automatic Transmission, MC2150 Carb, MDS TFI Upgrade, CS144
Decatur, Georgia
"Do or do not. There is no try." Yoda
Old 02-08-2010, 10:06 AM
gladman's Avatar
Thanks guys. I'm going to try a different fuel pump today and then, if that doesn't solve it, go after the carb... since I haven't been getting fuel to the carb I hadn't considered it... when I have primed it myself or hit it with starting fluid the truck fired right up...
hoping it is a faulty pump! I'll report back and thanks again for the bumps and tips! It can get lonely under the hood! Hoping my manual shows up today! ha ha!
Old 02-08-2010, 02:09 PM
lkmarsh's Avatar
lkmarsh lkmarsh is offline
I have an electric fuel pump from the wrecking yard with a switch, twenty feet of zip cord and battery clamps, and ten feet of fuel line. Mostly use it to steal gas from my Chevelle for the lawn mower, also works to diagnose pump and fuel line/tank problems.
Lyle
68 Chevelle wagon 350/BWT50
68 Impala wagon 327/400
04 Impala LS - Wife's DD
73 Wagoneer parts donor
Old 02-09-2010, 01:39 AM
gladman's Avatar
got the new pump today, I'll get to test it out on wed...
Kind of considering replacing all the plumbing and the tank... I'll get the first part going first, but it seems like it might be a good thing (peace of mind wise) to have the fuel supply completely resolved.
Old 02-10-2010, 12:54 PM
gladman's Avatar
Update: Well, what do you know! It works! Yay!
The fuel pump that the PO had put on there to 'get me home' was the wrong output... I was starvin' the glad!
I got a nice new one (recommended by my local jeep buddy) and put that sucker on with a new filter and she fired like a dream... now, I just need to hook all the plumbing back up, take a couple of pics and drive that girl!
Thanks for your help gents... this one sure proved the 'test everything' no matter what, rule....
Old 02-10-2010, 03:11 PM
letank's Avatar
letank letank is offline
Neat, so which brand and model pump # did you install?
Michel
Old 02-10-2010, 04:23 PM
gladman's Avatar
on the advice of my friend Jeff (a jeep whiz) here is what he told me
"I'd tend to agree that your pump is the issue. I'd go for the E8016S pump (autozone part number). It's a 2.5-5psi pump and those trucks typically like 3psi. You could try to scrounge up a new mechanical fuel pump for it, but it'd likely be hard to find one. If you wanted to go to a 4bbl carb, the part number you want is E8012S. Puts out 5-10psi, so you'd probably run into flooding issues with your existing carb."
I have the 2 bbl, so I got the first one....
Now, postscript, I got the truck all fired and all was well.... but, on my test drive it died on me... ugh... I have an additional problem, crack in the fuel line, clog, sock off in the tank, old tank full of crapola.... something...
I was planning to replace all of it at some point... well, I emailed bj's and just asked them for the parts list, fuel lines, fittings, tank etc... screw it, do it right. Then I have a reliable, working fuel system and can focus my energies on other aspects.
here is the old girl.
Old 02-11-2010, 02:34 AM
Skeeter74 Skeeter74 is offline
Beautiful truck, Gladman.
Originally Posted by Tatsadasayago
"And on the 7th day god created the Full Sized Jeep and he saw that it was good. He gave these mechanical marvels to his chosen ones and they went wheeling in style and comfort!"
80 Wagoneer Limited, 2 bbl 2150, 360, 727TF, NP219, "Moby Dick" Now with Dragonfire HEI, Contour dual fans, CS144,
