Old 09-27-2022, 11:39 AM
mark's Avatar
mark mark is offline
76 cherokee tail light socket
i keep having trouble with one side.the contacts are worn way down and i dont think it has any spring left to it to push outward.i see autozone sells a socket for the 1157 bulb.can i put this in from the outside without removing the housing?
ill need to be quick about this tomorrow at lunchtime at work.or do you have any ideas on how to get the current one to work?
mark<br />76 cherokee chief<br />chevy 502 t-400 np-205<br />dana 60 front corp 14 bolt rear<br />fiberglass fenders and quarters<br />(ABOVE THE LAW)(AND UNDER CONSTRUCTION)<br /> [IMG]<br />[url=http://www.fsjworld.com/mygallery.ten?id=3481[/URL]<br />[/IMG]
Old 09-28-2022, 01:49 PM
inkedmonkey inkedmonkey is offline
The ones I've gotten from the parts store push in from the back side.
Old 09-28-2022, 06:35 PM
mark's Avatar
i couldnt even get the bulb out.i was afraid it was going to break in my fingers.its a new bulb and i didnt have another so i shoved a couple of sheetmetal slivers alongside the bulb in the socket in a spot where it got good contact.all good for now!
Old 09-29-2022, 10:19 PM
cu4whln's Avatar
cu4whln cu4whln is offline
I have a socket I took out for LED conversion.. It's a bit mangled where it seats, but could be put back into a stock housing. from a 77. yours for shipping cost if you want it. has the stock pigtails on the wire still.
1977 "401" 'Da Chief
1979 Chero: "Madness" [Sold]
2001 XJ : Driver - 2016 JK 2 door
Round 2- LT Swap: 'Da Chief:
"Madness" build here:
Tail light and reverse light to body gasket ? Achilles General FSJ Discussion 23 12-18-2020 06:50 PM
Blown Tail light fuse weird effect Mr Carts General FSJ Tech 3 04-05-2017 09:57 PM
tail light Chris1207 General FSJ Tech 2 06-18-2015 02:01 PM
any good sorces for j10 tail light lens-temp cable? mtjeep General FSJ Tech 2 10-27-2008 05:19 PM
Tail light question..... KivaKid General FSJ Tech 8 12-15-2001 04:38 AM
