Old 09-30-2022, 07:53 PM
warmblood58 warmblood58 is offline
Pulled air vent cover under windshield . . Questions
Hello all, just pulled the grill /air vent cover under windshield/windshield wipers (tons of dried debris that I vac'd out) the drivers side drops off and goes straight down (passenger side is closed) I assume this just funnels water straight down to a drain? I want to rinse this area out but do not want to flood cabin - safe to do so? Thanks. I think I will secure some light mesh to the underside of this grill after painting to eliminate debris from passing through grill and collecting in this area - no rust! I got lucky!
Old 09-30-2022, 10:55 PM
SJTD SJTD is offline
The cowl vent supplies air to the vents in the driver and passenger kick panels and the heater inlet.
These cavities and the heater are often full of leaves which hold water and cause rust. There is a small drain in each side.
Maybe you can see in there through the vents with a light to see how bad it is. How well is the passenger side blocked? Leaf proof? water proof?
You can run a vacuum hose down there but it's better to pull the vent covers off. A pain on the right side if you have AC. Get the leaves out before flushing the dirt.
Would be good to pull the heater off but two nuts are behind the AC.
Sic friatur crustulum
Old 10-01-2022, 06:18 AM
Thanks! Exactly the info I was looking for - will make a log extension for my vac and wiggle it around to capture what I can, thanks again and see what I can access via lower vents.
Old 10-01-2022, 04:54 PM
Theodore Theodore is offline
Hey, warmblood58, there was a great post on this back in December
https://www.fsjnetwork.com/forum/vie...208703#p208703
Like, the previous poster, I would also recommend pulling the heater core box - I cleaned mine as part of a/c & heater core refresh a few months ago - it was 1/2 full of leaves.
BJs Off-road has a good video on YouTube
https://youtu.be/jdfE9-zWamQ
Passenger side
Hand-cleaned
Scrubbed with soap & water
Drivers side
Gallon-worth of compost
Old 10-02-2022, 07:22 AM
Wow, will do! Did this on my '83 Dodge pickup, will follow up on lower vents with GW. Seems like creating some kind of screen filter under cowl cover would be a good idea to keep pine needles, leaves, etc out would be a good idea.
Old 10-02-2022, 07:57 AM
inkedmonkey inkedmonkey is offline
Oh yeah. I epoxied some screen to the backside of my panel after cleaning everything out.
Old 10-02-2022, 10:59 AM
Just remembered. You can pull the heater blower rather than the whole housing which is a pain.
Old 10-03-2022, 01:37 PM
I had the trifecta in mine: Mouse house in the heater core area, leaves up about halfway past the kick vents, and holes in my heater core housing!
00 Baby Cherokee
AMC 258 Valve Cover Vent Harrinad General FSJ Tech 3 05-28-2021 07:31 AM
Drivers side fresh air vent cable Driftwood Wanted 8 09-01-2020 06:56 AM
Educate me please - Air filter cover Crist Clapper General FSJ Discussion 5 06-14-2011 05:54 AM
How do I remove the cowl vent cover cdlongjr General FSJ Tech 7 12-24-2009 10:10 AM
Valve Cover Vent thingy Weelspin General FSJ Tech 3 09-09-2001 09:45 AM
