Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > For Sale: Parts and Pieces (To keep our rigs running)
  #41
Old 04-07-2022, 04:07 PM
80Limited 80Limited is offline
Pm sent
Old 04-11-2022, 03:29 PM
JERSEY JOE's Avatar
WIRE HARNESS
I NEED THE WIRE HARNESS THAT CONNECTS THE TRANSMISSION AND TRANSFER CASE TO THE MAIN HARNESS
1987 J-20 401 90% COMPLETED.
1970 AMX CURRENT PROJECT
Old 04-11-2022, 07:46 PM
Pm sent
Old 04-11-2022, 11:45 PM
Johnwog's Avatar
Johnwog Johnwog is offline
Need a right front fender in good condition.
For External Use Only
Old 04-12-2022, 10:50 AM
Pm sent
Old 04-13-2022, 02:34 AM
Johnwog's Avatar
Originally Posted by WI J10
Looks like someone beat me to the door mirrors. If they dont take them please PM me and let me know....very interested
I don't want to hijack this tread, however I PM'ed you
Old 04-13-2022, 07:43 PM
rawdave's Avatar
rawdave rawdave is offline
Muscle Grill
Does this have a muscle grill?
"You fancy people with your shoes."
87 Grand Wagoneer
2009 GMC 5.3L Vortec
Sterling 10.25 Rear
8 Lug J10 Front
TSM Mfg Rear Disk Brake Conversion
33 Gallon Rear Poly Tank
69 J-3000 Pickup
Plans:
2.8 Cummins Diesel Repower
6L90
Atlas Transfer Case
82 J-10 Pickup 258
Leave it as-is except to fix all the issues.
Old 04-14-2022, 01:03 PM
Nope. It had a busted pig nose grille.
Old 04-22-2022, 05:18 PM
jonygeorge's Avatar
jonygeorge jonygeorge is offline
Rear Drivers Tail light section?
I got rear ended and need the rear section of the body that houses the tail light.. I think this would need to be cut or torched out.. Do you have this?
Thanks!
https://photos.app.goo.gl/Y1TNp7znWVpqPKy69
1988 Grand Wagoneer
Ford 460 w 429 heads Performer cam and Shorty Headers. Ford Fuel Injection out of a mustang. Natrual Gas Kit.
NV4500 Transmission NP205 Twin Stick T-case. Up and Running!
Old 04-23-2022, 06:48 AM
Thanks!
Pm sent
Old 05-09-2022, 08:45 AM
bluehwy's Avatar
bluehwy bluehwy is offline
Looking for the firewall piece that sandwiches the accelarator arm below the kick-down switch. And a headlight bezel if they match a '79... Thanks
_____________________________________________
Current: 1979 Wagoneer
Previous: 1988 Grand Wagoneer (found recently behind a bar and passed on buying it back-too far into current build),
1989 Grand-sold to Montana
"And for those brave Right Wing Americans who say it's about... keeping America safe... if you want to fight against a country you need a F-15. You need a something a little more than a gun." ---Brandon
Old 05-09-2022, 04:01 PM
Pm sent
Old 09-24-2022, 01:39 PM
RuidosoKid RuidosoKid is offline
Hi, looking for the digital clock trim cover piece... possibly the clock as well depending on condition and price... - A.J.
Old 09-27-2022, 10:38 AM
I should have one in tan. The clock worked just stubborn on adjusting the time.
Old 09-28-2022, 09:19 PM
Curly5759's Avatar
Curly5759 Curly5759 is offline
Do you have the Charcoal canister?
77 Cherokee S 360/TH400/QT
Old 09-30-2022, 03:32 PM
I do not.
Old 10-13-2022, 09:24 PM
Mwray8909 Mwray8909 is offline
Do you have an oil pan for the 360?
Old 10-15-2022, 06:45 PM
Negative
Old 11-26-2022, 10:43 PM
mudslider's Avatar
mudslider mudslider is offline
Hello, do you have the s shaped tube that goes from the ac condenser to the accumulator? How are the other ac lines? I could use the shifter handle knob at the end of the lever, the speedometer cable that goes to the cruise control box from the tcase would be useful to me as well. Thanks
P.J
Stupidity rules at all times! Famous last words "Hey, watch this" Its 5:00 Somewhere. 1983 J10 In process: 360 ci install
Old 11-27-2022, 07:32 AM
Originally Posted by rebelskypirate
front window lifters, how much?
Are you talking about the window regulators or the lift bars on the windows?
1971 Jeep Wagoneer 1414C with Factory 1972 Engine ngasman General FSJ Discussion 10 11-28-2014 11:27 AM
Options to switch to driver's side t-case in early Wagoneer? mad_science General FSJ Tech 29 08-19-2014 11:00 AM
(Not So) New 86 Grand Wagoneer Orion1188 General FSJ Discussion 9 12-04-2012 02:59 PM
Help with a broken 727-just found a loose part in the pan No_Ecm General FSJ Tech 7 08-07-2003 01:24 AM
