Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Wanted
Old 05-25-2020, 10:45 AM
AMC V8 oil pressure sender adapter
This adapter is steel with 1/8" NPT female to 3/8" NPT male. It fits on right side of 290 through 401 block near the oil filter.
Looks like this:
Old 05-25-2020, 12:31 PM
Tripwire's Avatar
Tripwire Tripwire is offline
have you looked at lowes or nappa? If no one else pony's one up I have one but its on a block in storage, shoot me a PM in a week or so if you are still desperate, im afraid you will have to take the whole thing though, adapter, T, sender and choke switch
steve
Abort? Retry? Ignore? >
Old 05-25-2020, 12:52 PM
OK. Appreciate your response. So far, anything I have found that will fit the need is made of brass which I am not a fan of. I will be checking True Value, Ace and NAPA when I go to Cortez tomorrow.
Thanks!
Old 05-25-2020, 01:09 PM
Tripwire's Avatar
oh, well forget the stores then as they only have brass, whats wrong with it anyway? it not like you will be doing a lot of screwing/unscrewing of the senders - or am i missing something
steve
Old 05-25-2020, 01:20 PM
Hey Steve. That is what I am thinking too on the stores but I'll be in town anyway. The nearest Home Depot is about 40 miles, Lowes about 75. Hoping to get lucky in the FSJ world.
The 1/8" brass nipple failed to hold pressure. Then there was a chunk of it in the adapter after it easily snapped off. We couldn't get the brass out so drilled it out and welded the hole closed. It's a plug now. At least the Jeep can be driven.
Old 05-25-2020, 01:37 PM
Tripwire's Avatar
Okie dokie let me know and perhaps this coming weekend i can get out to the storage unit to get your part...hope the block wont leak
Old 05-25-2020, 01:51 PM
I just happen to have a plug for the leak.
Old 05-27-2020, 12:48 PM
I have one in a block in garage I can pull and drop in mail if ya want/need one still?
Old 05-27-2020, 01:44 PM
I have other options but prefer the real thing. Sending you PM Tony.
Old 05-28-2020, 07:02 AM
I got what I need coming. Thanks for looking!
Old 06-03-2020, 08:01 AM
Got it. Thanks for the quick turn around on the adapter Tony!
Electrical gremlins in 1987 GW (clock + pegged oil pressure) lars667 General FSJ Tech 5 04-09-2011 07:49 AM
How to Install Oil Pressure Sender in 89 GW? ajminla General FSJ Tech 3 10-12-2010 09:39 AM
Jumping oil pressure jcz1978 General FSJ Tech 1 02-16-2008 03:19 PM
Oil Pressure Troubleshooting ninjaneer General FSJ Tech 6 08-06-2006 03:26 PM
Low oil pressure on rebuild? 78 Arizona Chief General FSJ Tech 6 07-18-2006 08:02 PM
